查看: 1715|回复: 0
[分享] How to sync UCS with current view like command UCS+V
已领礼包: 859个
发表于 2014-6-10 23:48:46 | 显示全部楼层 |阅读模式
How to sync UCS with current view like command UCS+VBy Philippe Leefsma
Here is how to achieve the same functionality than command UCS+V using .Net API:
// Use: Sync UCS with Current view like command UCS V
// Author: Philippe Leefsma, September 2011
[CommandMethod("UcsV"
public static void UcsV()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    Autodesk.AutoCAD.GraphicsSystem.Manager mng =
        doc.GraphicsManager;
    short cvport = (short)Application.GetSystemVariable("CVPORT");
    Autodesk.AutoCAD.GraphicsSystem.View view =
        mng.GetGsView(cvport, true);
    Vector3d direction = (view.Target - view.Position);
    direction = direction.MultiplyBy(1 / direction.Length);
    Vector3d upVector = view.UpVector;
    upVector = upVector.MultiplyBy(1 / upVector.Length);
    Vector3d xAxis = direction.CrossProduct(upVector);
    Matrix3d ucs = Matrix3d.AlignCoordinateSystem(
        new Point3d(0, 0, 0),
        Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis,
        new Point3d(0, 0, 0), xAxis, upVector, direction);
    ed.CurrentUserCoordinateSystem = ucs;
GMT+8, 2026-11-3 10:43 , Processed in 0.426795 second(s), 28 queries , Gzip On.
