查看: 1692|回复: 0
[分享] Draw Order Problem with Dynamic Block
已领礼包: 859个
发表于 2014-6-11 22:10:58 | 显示全部楼层 |阅读模式
        [CommandMethod("DOinBlock")]
        public static void RunMyCommand()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            //Ask user to select a block. In real world, I use code
            //to select all targeting blocks by its name, so that
            //user does not have to select block manually
            PromptEntityOptions opt = new PromptEntityOptions(
                "nSelect a block:");
            opt.SetRejectMessage("\nInvalid: not a block.");
            opt.AddAllowedClass(typeof(BlockReference), true);
            PromptEntityResult res = ed.GetEntity(opt);
            if (res.Status == PromptStatus.OK)
                SetDrawOrderInBlock(dwg, res.ObjectId);
                ed.Regen();
            else
                ed.WriteMessage("\n*Cancel*");
            Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        private static void SetDrawOrderInBlock(Document dwg, ObjectId blkId)
            using (Transaction tran = dwg.TransactionManager.StartTransaction())
                BlockReference bref = (BlockReference)tran.GetObject(blkId, OpenMode.ForRead);
                BlockTableRecord bdef = (BlockTableRecord)tran.GetObject(bref.BlockTableRecord, OpenMode.ForWrite);
                DrawOrderTable doTbl = (DrawOrderTable)tran.GetObject(bdef.DrawOrderTableId, OpenMode.ForWrite);
                ObjectIdCollection col = new ObjectIdCollection();
                foreach (ObjectId id in bdef)
                    if (id.ObjectClass.DxfName.ToUpper() == "HATCH")
                        col.Add(id);
                if (col.Count > 0)
                    doTbl.MoveToBottom(col);
                tran.Commit();
GMT+8, 2026-11-3 10:43 , Processed in 0.406420 second(s), 28 queries , Gzip On.
