查看: 1995|回复: 0
[分享] Exception with GetPointAtDist
已领礼包: 859个
发表于 2014-6-11 23:20:44 | 显示全部楼层 |阅读模式
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Geometry;
using AcBr = Autodesk.AutoCAD.BoundaryRepresentation;
using Autodesk.AutoCAD.Runtime;
namespace Autodesk.AutoCAD.DatabaseServices
   public static class PolylineExtensionMethods
      /// <summary>
      /// Returns true if the given Polyline forms a
      /// closed boundary and its Closed property is
      /// false.
      /// The result is true if any of the
      /// following conditions are true:
      /// 1.  Any segment intersects any other segment.
      ///      Regardless of the value of the Closed property.
      /// 2.  Any vertex lies directly on any segment.
      ///     or is coincident with any other vertex,
      ///     including zero-length segments, regardless
      ///     of the value of the Closed property
      /// 3.  If the first and last vertices are coincident,
      ///     AND the PolyLine's Closed property is false,
      ///     the polyline is considered effectively closed.
      ///  4. A Closed polyline with < 3 vertices.
      /// The test is intended to be consistent with the
      /// REGION command's testing of boundary entities.
      /// </summary>
      public static bool IsEffectivelyClosed( this Polyline pline )
         int numverts = pline.NumberOfVertices;
         if( numverts < 3 )
            return pline.Closed;
         if( !pline.Closed && pline.StartPoint.IsEqualTo( pline.EndPoint ) )
            return true;
         Point3dCollection points = new Point3dCollection();
         pline.IntersectWith( pline, Intersect.OnBothOperands, points,
            IntPtr.Zero, IntPtr.Zero );
         if( !pline.Closed )
            numverts -= 2;
         return points.Count != numverts;
GMT+8, 2026-11-3 10:43 , Processed in 0.392078 second(s), 28 queries , Gzip On.
