查看: 2780|回复: 3
[分享] Add arc at polyline vertex
已领礼包: 859个
发表于 2014-6-11 23:27:10 | 显示全部楼层 |阅读模式
1.    static class Extensions
2.    {
3.        /// <summary>
4.        /// Adds an arc (fillet), if able, at each polyline vertex.
5.        /// </summary>
6.        /// <param name="pline">The instance to which the method applies.</param>
7.        /// <param name="radius">The arc radius.</param>
8.        public static void FilletAll(this Polyline pline, double radius)
9.        {
10.            int j = pline.Closed ? 0 : 1;
11.            for (int i = j; i < pline.NumberOfVertices - j; i++)
12.            {
13.                i += pline.FilletAt(i, radius);
14.            }
15.        }
16.
17.        /// <summary>
18.        /// Adds an arc (fillet) at the specified vertex.
19.        /// </summary>
20.        /// <param name="pline">The instance to which the method applies.</param>
21.        /// <param name="index">The index of the verex.</param>
22.        /// <param name="radius">The arc radius.</param>
23.        /// <returns>1 if the operation succeeded, 0 if it failed.</returns>
24.        public static int FilletAt(this Polyline pline, int index, double radius)
25.        {
26.            int prev = index == 0 && pline.Closed ? pline.NumberOfVertices - 1 : index - 1;
27.            if (pline.GetSegmentType(prev) != SegmentType.Line ||
28.                pline.GetSegmentType(index) != SegmentType.Line)
29.            {
30.                return 0;
31.            }
32.            LineSegment2d seg1 = pline.GetLineSegment2dAt(prev);
33.            LineSegment2d seg2 = pline.GetLineSegment2dAt(index);
34.            Vector2d vec1 = seg1.StartPoint - seg1.EndPoint;
35.            Vector2d vec2 = seg2.EndPoint - seg2.StartPoint;
36.            double angle = vec1.GetAngleTo(vec2) / 2.0;
37.            double dist = radius / Math.Tan(angle);
38.            if (dist > seg1.Length || dist > seg2.Length)
39.            {
40.                return 0;
41.            }
42.            Point2d pt1 = seg1.EndPoint + vec1.GetNormal() * dist;
43.            Point2d pt2 = seg2.StartPoint + vec2.GetNormal() * dist;
44.            double bulge = Math.Tan((Math.PI / 2.0 - angle) / 2.0);
45.            if (Clockwise(seg1.StartPoint, seg1.EndPoint, seg2.EndPoint))
46.            {
47.                bulge = -bulge;
48.            }
49.            pline.AddVertexAt(index, pt1, bulge, 0.0, 0.0);
50.            pline.SetPointAt(index + 1, pt2);
51.            return 1;
52.        }
53.
54.        /// <summary>
55.        /// Evaluates if the points are clockwise.
56.        /// </summary>
57.        /// <param name="p1">First point.</param>
58.        /// <param name="p2">Second point</param>
59.        /// <param name="p3">Third point</param>
60.        /// <returns>True if points are clockwise, False otherwise.</returns>
61.        private static bool Clockwise(Point2d p1, Point2d p2, Point2d p3)
62.        {
63.            return ((p2.X - p1.X) * (p3.Y - p1.Y) - (p2.Y - p1.Y) * (p3.X - p1.X)) < 1e-8;
64.        }
65.    }
已领礼包: 859个
 楼主| 发表于 2014-6-12 02:27:06 来自手机 | 显示全部楼层
仅仅是两直线段倒角
发表于 2014-6-12 21:56:39 | 显示全部楼层
C#好学不?
入门容易,再提高还要学很多 C# 本身的东西  详情 回复 发表于 2014-6-12 22:21
已领礼包: 859个
 楼主| 发表于 2014-6-12 22:21:00 | 显示全部楼层
入门容易,再提高还要学很多 C# 本身的东西,AutoCAD Net API 不再觉得是高不可攀的咚咚,而且比 ARX 好学多了
现在也能看懂一些 ARX 代码了
GMT+8, 2026-11-3 10:43 , Processed in 0.533468 second(s), 35 queries , Gzip On.
