查看: 1676|回复: 0
[分享] Finding the group name to which entity belongs
已领礼包: 859个
发表于 2014-6-12 03:35:00 | 显示全部楼层 |阅读模式
Finding the group name to which entity belongsBy Virupaksha Aithal
Groups are stored as persistent reactors in the AutoCAD entity so, “DbObject::GetPersistentReactorIds” API can be used to identify the group associated with AutoCAD entity. Below code shows the procedure to use “GetPersistentReactorIds” to identify the group’s to which a selected entity is belongs.
[CommandMethod("FindGroup")]
static public void FindGroup()
    Document doc =
        Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    PromptEntityResult acSSPrompt =
        ed.GetEntity("Select the entity to find the group");
    if (acSSPrompt.Status != PromptStatus.OK)
        return;
    using (Transaction Tx =
        db.TransactionManager.StartTransaction())
        Entity ent = Tx.GetObject(acSSPrompt.ObjectId,
                                OpenMode.ForRead) as Entity;
        ObjectIdCollection ids = ent.GetPersistentReactorIds();
        bool bPartOfGroup = false;
        foreach (ObjectId id in ids)
            DBObject obj = Tx.GetObject(id, OpenMode.ForRead);
            if (obj is Group)
                Group group = obj as Group;
                bPartOfGroup = true;
                ed.WriteMessage(
                    "Entity is part of " + group.Name + " group\n");
        if(!bPartOfGroup)
            ed.WriteMessage(
                   "Entity is Not part of any group\n");
        Tx.Commit();
GMT+8, 2026-11-3 10:41 , Processed in 0.322862 second(s), 28 queries , Gzip On.
