查看: 1801|回复: 0
[分享] Turn on/off the running osnap
已领礼包: 859个
发表于 2014-6-13 01:24:44 | 显示全部楼层 |阅读模式
Turn on/off the running osnapBy Balaji Ramamoorthy
To turn on or off the running osnap, simply set the SNAPMODE system variable to 1 or 0.
Here is a sample code :
// Turn-off running osnap
Application.SetSystemVariable("SNAPMODE", 0);
// Turn-on running osnap
Application.SetSystemVariable("SNAPMODE", 1);
The various osnap options are governed by the value of the OSMODE system variable. Here is a post that describes setting of the OSMODE system variable. The values that the OSMODE system variable can take can be found in the AutoCAD documentation.
Prior to AutoCAD 2009, If object snap (Osnap) is turned off, AutoCAD adds 16384, to the current setting for the variable OSMODE. This allows applications to identify the current setting for OSMODE.
For instance, when you activate the "endpoint" object snap and Osnap is enabled, OSMODE contains 1 as its value. If object snap is disabled, OSMODE will contain 16385 as its value (1 + 16384).
Here is a sample code for this :
Int16 osmode = (Int16)Application.GetSystemVariable("OSMODE");
String msg = String.Empty;
if ((osmode & 16384) == 0)
    msg = String.Format
                "OSnaps are Disabled. Value of OSMODE = {0}",
                osmode
else
    msg = String.Format
                "OSnaps are Enabled. Value of OSMODE = {0}",
                osmode
GMT+8, 2026-11-3 10:37 , Processed in 0.457911 second(s), 28 queries , Gzip On.
