查看: 1743|回复: 0
[分享] Displaying entities in different colors using DrawableOverrule
已领礼包: 859个
发表于 2014-6-13 02:24:16 | 显示全部楼层 |阅读模式
Displaying entities in different colors using DrawableOverruleBy Balaji Ramamoorthy
Recently, a developer wanted to know a method to display the entities in different colors to visually represent the results of a drawing comparison. A way to set the color for entities including those that are nested is explained in Kean's blog post :
Changing the colour of nested AutoCAD entities through .NET Another way to show the entity in different colors would be to use of DrawableOverrule. But, the WorldDraw of the DrawableOverrule class does not use the color setting from the DrawableTraits for some entities such as MText. To overcome this limitation, the drawable is cloned inside the WorldDraw method before being assigned a new color.
Here is a sample code using this approach. Some of the helper methods to highlight / unhighlight and pick nested entities are from Kean's blog post that I mentioned about previously.
<p
using Autodesk.AutoCAD.GraphicsInterface;
using System.Collections.Generic;
public class MyDrawOverrule : DrawableOverrule
    public static List<ObjectId> _redIds = new List<ObjectId>();
    public static List<ObjectId> _yellowIds = new List<ObjectId>();
    public override bool WorldDraw(Drawable drawable, WorldDraw wd)
        Entity mydrawable = drawable.Clone() as Entity;
        short colorIndex = 1;
        if (_yellowIds.Contains(drawable.Id))
            colorIndex = 2;
        wd.SubEntityTraits.Color = colorIndex;
        mydrawable.ColorIndex = colorIndex;
        return base.WorldDraw(mydrawable, wd);
    public override int SetAttributes(Drawable drawable,
                                        DrawableTraits traits)
        return base.SetAttributes(drawable, traits);
public class ColorizeClass : IExtensionApplication
    static MyDrawOverrule _do = null;
    [CommandMethod("Colorize")]
    public void ColorizeMethod()
        Document doc = Application.DocumentManager.MdiActiveDocument;
        Editor ed = doc.Editor;
        if (_do != null)
            ed.WriteMessage("Overruling is already active");
            return;
        Transaction tr = doc.TransactionManager.StartTransaction();
        using (tr)
            List<FullSubentityPath> paths1;
            SelectNestedEntities(   ed,
                                    out MyDrawOverrule._redIds,
                                    out paths1,
                                    "Red"
            List<FullSubentityPath> paths2;
                                    out MyDrawOverrule._yellowIds,
                                    out paths2,
                                    "Yellow"
            _do = new MyDrawOverrule();
            Overrule.AddOverrule(
                RXObject.GetClass(typeof(Entity)),
                _do,
                true);
            List<ObjectId> ids = new List<ObjectId>();
            ids.AddRange(MyDrawOverrule._redIds.ToArray());
            ids.AddRange(MyDrawOverrule._yellowIds.ToArray());
            _do.SetIdFilter(ids.ToArray());
            Overrule.Overruling = true;
            if (MyDrawOverrule._redIds.Count > 0)
                UnhighlightSubEntities(paths1);
            if (MyDrawOverrule._yellowIds.Count > 0)
                UnhighlightSubEntities(paths2);
            tr.Commit();
        ed.Regen();
    private static bool SelectNestedEntities
            Editor ed,
            out List<ObjectId> ids,
            out List<FullSubentityPath> paths,
            String colorName
        paths = new List<FullSubentityPath>();
        // Loop until cancelled or completed
        PromptNestedEntityResult rs;
        do
            rs = ed.GetNestedEntity(
                String.Format("\nSelect entity to color {0}: ",
                colorName));
            if (rs.Status == PromptStatus.OK)
                ids.Add(rs.ObjectId);
                FullSubentityPath path = FullSubentityPath.Null;
                path = HighlightSubEntity(rs);
                if (path != FullSubentityPath.Null)
                    paths.Add(path);
        } while (rs.Status == PromptStatus.OK);
        return (rs.Status == PromptStatus.Cancel);
    // Ask the user to select a number of sub-entities.
    // These will have their ObjectIds and their sub-entity
    // paths (returned from the HighlightSubEntity() helper)
    // added to collections that are returned to the caller.
            Editor ed,
            out ObjectIdCollection ids,
        ids = new ObjectIdCollection();
        do
            rs = ed.GetNestedEntity("\nSelect nested entity: ");
                    paths.Add(path);
        // Cancel is the status when "enter" is used to
        // terminate the selection, which means we can't
        // use it to distinguish from an actual
        // cancellation.
    // Unhighlight a set of sub-entities
    private static void UnhighlightSubEntities(
                                List<FullSubentityPath> paths)
        for (int i = 0; i < paths.Count; i++)
            ObjectId[] ids = paths.GetObjectIds();
            Entity ent
                = ids[0].GetObject(OpenMode.ForRead) as Entity;
            if (ent != null)
                ent.Unhighlight(paths, false);
    // Highlight a sub-entity based on its nested
    // selection information.
    // Return the calculated sub-entity path, so
    // the calling application can later unhighlight.
    private static FullSubentityPath HighlightSubEntity(
                                    PromptNestedEntityResult rs)
        // Extract relevant information from the prompt object
        ObjectId selId = rs.ObjectId;
        List<ObjectId> objIds = new List<ObjectId>(rs.GetContainers());
        // Reverse the "containers" list
        objIds.Reverse();
        // Now append the selected entity
        objIds.Add(selId);
        // Retrieve the sub-entity path for this entity
        SubentityId subEnt
            = new SubentityId(SubentityType.Null, System.IntPtr.Zero);
            = new FullSubentityPath(objIds.ToArray(), subEnt);
        // Open the outermost container, relying on the open transaction...
        Entity ent = objIds[0].GetObject(OpenMode.ForRead) as Entity;
        // ... and highlight the nested entity
        if (ent == null)
            return FullSubentityPath.Null;
        ent.Highlight(path, false);
        // Return the sub-entity path for later unhighlighting
        return path;
    void IExtensionApplication.Initialize() { }
    void IExtensionApplication.Terminate()
        if (_do != null)
            Overrule.Overruling = false;
            Overrule.RemoveOverrule(
                _do);
</p
GMT+8, 2026-11-3 10:45 , Processed in 0.383268 second(s), 28 queries , Gzip On.
