查看: 1704|回复: 1
[分享] DeleteShortLinesDynamicallyCmd
已领礼包: 859个
发表于 2014-6-13 03:00:23 | 显示全部楼层 |阅读模式
[CommandMethod("DeleteShortLinesDynamically")
public void DeleteShortLinesDynamicallyCmd()
   Database db = HostApplicationServices.WorkingDatabase;
   TransactionManager tm = db.TransactionManager;
   using (Transaction tr = tm.StartTransaction())
       dynamic btr = new MyDynamicObject(SymbolUtilityServices.GetBlockModelSpaceId(db));
       foreach (var ent in btr)
           if (ent.IsKindOf(typeof(Line)) && ent.Length < 0.1)
               ent.UpgradeOpen();
               ent.Erase();
       tr.Commit();
已领礼包: 859个
 楼主| 发表于 2014-6-13 03:03:15 | 显示全部楼层
public class MyDynamicObject : DynamicObject
   public MyDynamicObject(ObjectId oid)
       ObjectId = oid;
   public ObjectId ObjectId { get; private set; }
   private DBObject dbobject;
   public DBObject DBObject
       get
           if (dbobject == null)
               dbobject = ObjectId.GetObject(OpenMode.ForRead);
           return dbobject;
   public override bool TryGetMember(GetMemberBinder binder, out object result)
       try
           object xxx = DBObject.GetType().InvokeMember(binder.Name, BindingFlags.GetProperty, null, DBObject, null);
           result = xxx == null ? null : promoteId(xxx);
           return true;
       catch
           result = null;
           return false;
   public override bool TryInvokeMember(InvokeMemberBinder binder, object[] args, out object result)
       try
           object xxx = DBObject.GetType().InvokeMember(binder.Name, BindingFlags.InvokeMethod, null, DBObject, args);
           return true;
       catch
           result = null;
           return false;
   public override bool TrySetMember(SetMemberBinder binder, object value)
       try
           DBObject.GetType().InvokeMember(binder.Name, BindingFlags.SetProperty, null, DBObject, new object[] { value });
           return true;
       catch
           return false;
   public override bool TryConvert(ConvertBinder binder, out object result)
       try
           if (binder.ReturnType == typeof(IEnumerable))
               result = testIEnum(DBObject);
           else if (binder.ReturnType == typeof(ObjectId))
               result = ObjectId;
           else
               result = DBObject;
           return true;
       catch
           result = null;
           return false;
   object promoteId(object value)
       if (!(value is ObjectId))
           return value;
       return new MyDynamicObject((ObjectId)value);
   static object testIEnum(object value)
       if (!(value is AttributeCollection ||
           value is ObjectIdCollection ||
           value is SymbolTable ||
           value is SymbolTableRecord ||
           value is IEnumerable<ObjectId>))
           return value;
       return makeIEnum(value);
   static IEnumerable<MyDynamicObject> makeIEnum(object value)
       foreach (ObjectId oid in (IEnumerable)value)
           yield return new MyDynamicObject(oid);
   public bool IsKindOf(Type type)
       return DBObject.GetRXClass().IsDerivedFrom(RXClass.GetClass(type));
GMT+8, 2026-11-3 10:42 , Processed in 0.177587 second(s), 30 queries , Gzip On.
