查看: 1887|回复: 3
[他山之石] 删除空白layouts
发表于 2014-6-19 23:42:55 | 显示全部楼层 |阅读模式
http://www.jtbworld.com/
  1. (defun c:DeleteEmptyLayouts (/ layouts layout i)
  2.   (vl-load-com)
  3.   (setq        i        0
  4.         layouts        (vla-get-Layouts
  5.                   (vla-get-activedocument (vlax-get-acad-object))
  6.                 )
  7.   )
  8.   (if (> (vla-get-count layouts) 2)
  9.     (vlax-for layout layouts
  10.       (if (= (vla-get-ModelType layout) :vlax-false)
  11.         (if (< (vla-get-count (vla-get-block layout)) 2)
  12.           (progn (princ (strcat "\n" (vla-get-name layout) " deleted"))
  13.                  (setq i (1+ i))
  14.                  (vla-delete layout)
  15.           )
  16.         )
  17.       )
  18.     )
  19.   )
  20.   (cond        ((> i 1) (princ (strcat "\n" (itoa i) " layouts deleted")))
  21.         ((= i 0) (princ "\nNo layouts deleted"))
  22.   )
  23.   (princ)
  24. )
已领礼包: 3199个
发表于 2014-6-20 17:02:43 | 显示全部楼层
乱了:
  1. (defun c:tt (/ layouts layout i)
以前见过,这个感觉没什么意义,
发表于 2014-6-20 20:13:41 | 显示全部楼层
谢谢楼主的奉献!
发表于 2014-9-5 12:25:38 | 显示全部楼层
能不能删除空格?
GMT+8, 2026-11-6 10:16 , Processed in 0.556520 second(s), 35 queries , Gzip On.
