查看: 3520|回复: 3
[分享] Highlight AutoCAD Entity in Your Own Way with Highlight Overrule
已领礼包: 859个
发表于 2014-6-23 21:53:02 | 显示全部楼层 |阅读模式
Highlighting an AutoCAD entity is usually used as a visual hint that the entity is selected by user. Sometimes, when you develop an AutoCAD application, you may want to highlight some entities in interest in a way that is a bit different from AutoCAD does regularly, so that the entities would visually stand out to catch user's attention.
One way to do your own entity highlighting would be to use TransientGraphics object, which I have discussed previously here.
Now, I'd like show how to customize entity highlighting with Overrule, more precisely, HighlightOverrule. Do use Overrule, you need to use AutoCAD 2010 or later.
Scenario: there are polylines drawing in default color (white). When the mouse cursor hovers on it or clicks on it, AutoCAD highlights the polyline in the same color. I'd like the color to be different when highkighted.
Here is the code:
class MyHighlightOverrule.cs
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
namespace HighlightOverruleSample
    public class MyHighlightOverrule : HighlightOverrule
        private int _colorIndex = 1;
        private int _oldColorIndex;
        public MyHighlightOverrule()
            AddOverrule(RXClass.GetClass(typeof(Polyline)), this, true);
        public int ColorIndex
            set { _colorIndex = value; }
            get { return _colorIndex; }
        public override void Highlight(
            Entity entity, FullSubentityPath subId, bool highlightAll)
            Polyline pline = entity as Polyline;
            if (pline == null) return;
            Database db= entity.Database;
            Document dwg=Application.DocumentManager.MdiDocument;
            using (DocumentLock dl = dwg.LockDocument())
                using (Transaction tran = db.TransactionManager.StartTransaction())
                    pline.UpgradeOpen();
                    _oldColorIndex = pline.ColorIndex;
                    pline.ColorIndex = _colorIndex;
                    pline.DowngradeOpen();
            base.Highlight(entity, subId, highlightAll);
        public override void Unhighlight(
            Database db = entity.Database;
            using (DocumentLock dl = _dwg.LockDocument())
                    pline.ColorIndex = _oldColorIndex;
            base.Unhighlight(entity, subId, highlightAll);
class Commands.cs
using Autodesk.AutoCAD.EditorInput;
    public class Commands
        private static MyHighlightOverrule _hlOverRule = null;
        [CommandMethod("MyHLOn")]
        public void TurnOnMyHighlight()
            if (_hlOverRule == null)
                _hlOverRule = new MyHighlightOverrule();
            MyHighlightOverrule.Overruling = true;
        [CommandMethod("MyHLOff")]
        public void TurnOffMyHighlight()
            if (_hlOverRule == null) return;
            MyHighlightOverrule.Overruling = false;
        [CommandMethod("HLColor")]
        public void SetHighlightColor()
            Document dwg = Autodesk.AutoCAD.ApplicationServices.
                Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            PromptIntegerOptions opt = new PromptIntegerOptions(
                "\nEnter color index (a number form 0 to 7):");
            PromptIntegerResult res = ed.GetInteger(opt);
            if (res.Status == PromptStatus.OK)
                _hlOverRule.ColorIndex = res.Value;
发表于 2014-6-27 10:09:38 | 显示全部楼层
学习测试了一下,有2个问题:
1.加载后,先执行HLcolor命令会系统崩溃 ,原因 private static MyHighlightOverrule _hlOverRule 还没有初始化。可在SetHighlightColor函数中处理解决
2.亮显的重定义对 块图元 不起作用,不知如何解决。
已领礼包: 859个
 楼主| 发表于 2014-6-27 12:57:09 来自手机 | 显示全部楼层
还没有学到这个 OverRule
块图元的颜色修改可以看eachy的"图层合并"帖子讨论,块图元改颜色需要块内图元为Byblock
发表于 2014-6-27 13:28:28 | 显示全部楼层
确实如此
GMT+8, 2026-11-3 13:19 , Processed in 0.390189 second(s), 34 queries , Gzip On.
