查看: 2411|回复: 0
[原创] 练习 绘制 RotatedDimension
已领礼包: 859个
发表于 2014-6-28 08:06:26 | 显示全部楼层 |阅读模式
  1.         [CommandMethod("addrtd")]
  2.         public static void MyAddRotatedDim()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Editor ed = doc.Editor;
  6.             Database db = doc.Database;
  7.             Transaction tr = db.TransactionManager.StartTransaction();
  8.             PromptPointResult psr1 = ed.GetPoint("\nFirst Point");
  9.             if (psr1.Status != PromptStatus.OK) return;
  10.             PromptPointResult psr2 = ed.GetPoint("\nSecond Point");
  11.             if (psr2.Status != PromptStatus.OK) return;
  12.             PromptPointResult psr3 = ed.GetPoint("\nLocation");
  13.             if (psr3.Status != PromptStatus.OK) return;
  14.             using (tr)
  15.             {
  16.                 try
  17.                 {
  18.                     BlockTableRecord btr = (BlockTableRecord) tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
  19.                     Entity  rd = AddRotatedDimension(psr1.Value, psr2.Value, psr3.Value) as Entity ;
  20.
  21.                     btr.AppendEntity(rd);
  22.                     tr.AddNewlyCreatedDBObject(rd, true);
  23.                     tr.Commit();
  24.                 }
  25.                 catch (Exception)
  26.                 {
  27.                     throw;
  28.                 }
  29.             }
  30.         }
  31.         private static RotatedDimension AddRotatedDimension(Point3d p1, Point3d p2, Point3d p3)
  32.         {
  33.             Database db = Application.DocumentManager.MdiActiveDocument.Database;
  34.             ObjectId dst = db.Dimstyle;
  35.             Vector3d v = p1.GetVectorTo(p2);
  36.             Vector2d nv = new Vector2d(v.X, v.Y);
  37.             double an = nv.Angle;
  38.             return new RotatedDimension(an, p1, p2, p3, "", dst);
  39.         }
GMT+8, 2026-11-3 19:09 , Processed in 0.382761 second(s), 28 queries , Gzip On.
