查看: 1825|回复: 0
[分享] 读写资源文件代码
已领礼包: 859个
发表于 2014-7-5 12:53:12 来自手机 | 显示全部楼层 |阅读模式
  引用 using System.Resources;
  写资源文件代码如下:
            ResourceWriter rw = new ResourceWriter("Greeting1.dll");
            Bitmap b = new Bitmap("hhw.gif");
            //add some strings to the file
            //rw.AddResource("Greeting", "Welcome to Microsoft .Net Framework!Test");
            //rw.AddResource("PasswordException", "Sorry, that is not the correct password.");
            //rw.AddResource("Purchase", "Please select an item to purchase from the store:");
            //rw.AddResource("Goodbye", "Thank you for visiting Microsoft .Net Framework!");
            rw.AddResource("flag",b );
            rw.Generate();
            rw.Close();
读资源代码
            ResourceReader rr = new ResourceReader("Greeting1.dll");
           String s = "";
           //iterate through the reader, printing out the name-value pairs
           foreach (DictionaryEntry d in rr)
                Console.WriteLine(d.Key + ":" + d.Value.ToString ()) ;
                if (d.Key.ToString () == "flag")
                    Bitmap b = new Bitmap((Bitmap)d.Value);
                    b.Save("a.gif");
                    break;
           //close the reader
           rr.Close();
GMT+8, 2026-11-3 14:06 , Processed in 0.371564 second(s), 28 queries , Gzip On.
