查看: 2040|回复: 3
[分享] 点在多边形内部
已领礼包: 859个
发表于 2014-7-10 11:00:38 | 显示全部楼层 |阅读模式
http://www.cnblogs.com/dwdxdy/p/3230647.html
  1.         //  The function will return YES if the point x,y is inside the polygon, or
  2.         //  NO if it is not.  If the point is exactly on the edge of the polygon,
  3.         //  then the function may return YES or NO.
  4.         bool IsPointInPolygon(Point3dCollection pts, Point3d pt)
  5.         {
  6.             int i, j;
  7.             bool c = false;
  8.             for (i = 0, j = pts.Count - 1; i < pts.Count; j = i++)
  9.             {
  10.                 if ((((pts[i].Y <= pt.Y) && (pt.Y < pts[j].Y)) ||
  11.                     ((pts[j].Y <= pt.Y) && (pt.Y < pts[i].Y)))
  12.                     && (pt.X < (pts[j].X - pts[i].X) * (pt.Y - pts[i].Y) / (pts[j].Y - pts[i].Y) + pts[i].X))
  13.                 {
  14.                     c = !c;
  15.                 }
  16.             }
  17.             return c;
  18.         }
复制代码
已领礼包: 859个
 楼主| 发表于 2014-7-10 20:39:11 来自手机 | 显示全部楼层
bool IsInsideCurve(Curve curve, Point3d testPt)
            if (!curve.Closed)
                // cannot be inside
                return false;
            Point3d ptOnCurve = curve.GetClosestPointTo(testPt, false);
            if (testPt == ptOnCurve)
                return true;
            if (!curve.IsPlanar)
                return false;
            // check its planar
            Plane plane = curve.GetPlane();
            // make the test ray from the plane
            double epsilon = 2e-6; // ( trust me on this )
            Point3dCollection IntersectionPoints = new Point3dCollection();
            Vector3d normal = plane.Normal;
            Vector3d testVector = normal.GetPerpendicularVector();
            using (Ray ray = new Ray())
                ray.BasePoint = testPt;
                int nGlancingHits = 0, numberOfInters = 0;
                bool bRetryWithOtherRayDirection;
                do
                    bRetryWithOtherRayDirection = false;
                    IntersectionPoints.Clear();
                    ray.UnitDir = testVector;
                    // fire the ray at the curve
                    curve.IntersectWith(ray,
                        Intersect.OnBothOperands,
                        IntersectionPoints,
                        IntPtr.Zero,
                        IntPtr.Zero);
                    numberOfInters = IntersectionPoints.Count;
                    if (numberOfInters == 0)
                        return false;
                    nGlancingHits = 0;
                    for (int i = 0; i < IntersectionPoints.Count; ++i)
                        double hitParam;
                        try
                            //This try/catch block circumvents an issue with GetParameterAtPoint API
                            hitParam = curve.GetParameterAtPoint(IntersectionPoints[i]);
                        catch
                            bRetryWithOtherRayDirection = true;
                            testVector = testVector.RotateBy(5.0 * Math.PI / 180.0, normal);
                            break;
                        double inParam = hitParam - epsilon;
                        double outParam = hitParam + epsilon;
                        //Loop back inside the curve if param is falling outside of range
                        if (inParam < curve.StartParam)
                            inParam = curve.EndParam - epsilon + (curve.StartParam - inParam);
                        if (outParam > curve.EndParam)
                            outParam = curve.StartParam + epsilon + (curve.EndParam - outParam);
                        IncidenceType inIncidence = CurveIncidence(curve, inParam, testVector, normal);
                        IncidenceType outIncidence = CurveIncidence(curve, outParam, testVector, normal);
                        if (inIncidence == IncidenceType.kIncidenceToFront || outIncidence == IncidenceType.kIncidenceToFront)
                            break;
                        if ((inIncidence == IncidenceType.kIncidenceToRight && outIncidence == IncidenceType.kIncidenceToLeft) ||
                            (inIncidence == IncidenceType.kIncidenceToLeft && outIncidence == IncidenceType.kIncidenceToRight))
                            nGlancingHits++;
                while (bRetryWithOtherRayDirection);
                return ((numberOfInters + nGlancingHits) % 2
已领礼包: 859个
 楼主| 发表于 2014-7-10 20:41:13 来自手机 | 显示全部楼层
            if (!curve.Closed)
                // cannot be inside
                return false;
                return true;
                return false;
            // check its planar
                do
                        IntersectionPoints,
                        IntPtr.Zero,
                        IntPtr.Zero);
                        return false;
                    nGlancingHits = 0;
                        double hitParam;
                        try
                        catch
                            break;
                            break;
                            nGlancingHits++;
                return ((numberOfInters + nGlancingHits) % 2.
已领礼包: 859个
 楼主| 发表于 2014-7-10 20:43:08 | 显示全部楼层
            if (!curve.Closed)
                // cannot be inside
                return false;
                return true;
                return false;
            // check its planar
                do
                        IntersectionPoints,
                        IntPtr.Zero,
                        IntPtr.Zero);
                        return false;
                    nGlancingHits = 0;
                        double hitParam;
                        try
                        catch
                            break;
                            break;
                            nGlancingHits++;
                return ((numberOfInters + nGlancingHits) % 2  == 1
GMT+8, 2026-11-3 13:20 , Processed in 0.447863 second(s), 34 queries , Gzip On.
