查看: 2345|回复: 4
[求助] 如何让这三条command命令形成的图形和文字成一个整体
发表于 2014-7-10 16:29:02 | 显示全部楼层 |阅读模式
(command "_.pline" "non" pt1 "W" "0"  "" "non" pt2 "non" pt4 "")(command "_.pline" "non" p2 "W" "0"  "" "non" pt_mid "non" p1 "non" p3 "")(command "text" "j" "c" "non" p4 300 0 str)
如何让这三条command命令形成的图形和文字成一个整体,我想让他们能够整体按一定的方向镜像
已领礼包: 859个
发表于 2014-7-10 17:18:24 | 显示全部楼层
(setq ss (ssadd))
(ssadd (entlast) ss)
(command ".mirror" ss "" ....)
已领礼包: 12493个
发表于 2014-7-10 21:13:47 | 显示全部楼层
  1. (setq s1 (entlast) ss (ssadd))
  2. (command "_.pline" "non" pt1 "W" "0"  "" "non" pt2 "non" pt4 "")
  3. (command "_.pline" "non" p2 "W" "0"  "" "non" pt_mid "non" p1 "non" p3 "")
  4. (command "text" "j" "c" "non" p4 300 0 str)
  5. (if s1
  6. (while (setq s1 (entnext s1)) (ssadd s1 ss))
  7. (setq ss (ssget "X"))
  8. )
  9. (command "_.MIRROR" ss "")
  10. (while (> (getvar "CMDACTIVE") 0) (command PAUSE))</P>
 楼主| 发表于 2014-7-11 10:26:47 | 显示全部楼层
谢谢zxq0220, 你的程序完全满足要求,我还想请教一下,如果这三条command命令之间插入了其它语句如:
            (setq pt1_mid (mid_pt p2 p3)
                  p4         (polar pt1_mid (* 0.5 pi) 100)
            ;;文字起点
            (if (not (setq str (getreal "\n请输入标高±0.000:")))
             (setq str 0.000)
           (setq str (if (/= str 0)
            (rtos str 2 3)
             "%%P0.000"
怎么做到让这三条command命令形成的图形和文字成一个整体,再镜像
已领礼包: 1268个
发表于 2014-7-11 23:51:08 | 显示全部楼层
中间再加多少语句都没有关系(没有生成实体)
GMT+8, 2026-11-6 11:15 , Processed in 0.401399 second(s), 37 queries , Gzip On.
