查看: 2289|回复: 0
[分享] Polyline LineSeg Angle
已领礼包: 859个
发表于 2014-7-10 20:24:13 来自手机 | 显示全部楼层 |阅读模式
  http://forums.autodesk.com/autodesk/attachments/autodesk/152/33740/1/Code.txt
     [CommandMethod("Test")]
        public void Test()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect a polyline: ");
            peo.SetRejectMessage("Only a polyline.");
            peo.AddAllowedClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline), true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK) return;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    Autodesk.AutoCAD.DatabaseServices.Polyline pline = (Autodesk.AutoCAD.DatabaseServices.Polyline)tr.GetObject(per.ObjectId, OpenMode.ForRead);
                    if (pline.Closed)
                        for (int i = 0; i < pline.NumberOfVertices; i++)
                            LineSegment3d l1;
                            LineSegment3d l2;
                            if (i == pline.NumberOfVertices - 1)
                                l1 = pline.GetLineSegmentAt(i);
                                l2 = pline.GetLineSegmentAt(0);
                            else
                                l2 = pline.GetLineSegmentAt(i + 1);
                            Vector3d v1 = l1.StartPoint - l1.EndPoint;
                            Vector3d v2 = l2.EndPoint - l2.StartPoint;
                            double angle = v1.GetAngleTo(v2);
                            bool res = IsInsideCurve(pline, l1.StartPoint + (l2.EndPoint - l1.StartPoint) * 0.5);
                            if (res)
                                ed.WriteMessage("\nAngle between {0} and {1}: {2}", i, 0, Converter.AngleToString(angle, AngularUnitFormat.Degrees, 2));
                            else
                                ed.WriteMessage("\nAngle between {0} and {1}: {2}", i, 0, Converter.AngleToString((2 * Math.PI) - angle, AngularUnitFormat.Degrees, 2));
            catch
                ed.WriteMessage("\nInvalid polyline.");
        enum IncidenceType
            kIncidenceToLeft = 0,
            kIncidenceToRight,
            kIncidenceToFront,
            kIncidenceUnknown
        IncidenceType CurveIncidence(Curve curve, double param, Vector3d dir, Vector3d normal)
            Vector3d deriv1 = curve.GetFirstDerivative(param);
            if (deriv1.IsParallelTo(dir))
                // need second degree analysis
                Vector3d deriv2 = curve.GetSecondDerivative(param);
                if (deriv2.IsZeroLength() || deriv2.IsParallelTo(dir))
                    return IncidenceType.kIncidenceToFront;
                else
                    if (deriv2.CrossProduct(dir).DotProduct(normal) < 0)
                        return IncidenceType.kIncidenceToRight;
                    else
                        return IncidenceType.kIncidenceToLeft;
            if (deriv1.CrossProduct(dir).DotProduct(normal) < 0)
            else
          bool IsInsideCurve(Curve curve, Point3d testPt)        {
            if (!curve.Closed)
                // cannot be inside
                return false;
            Point3d ptOnCurve = curve.GetClosestPointTo(testPt, false);
            if (testPt == ptOnCurve)
                return true;
            if (!curve.IsPlanar)
                return false;
            // check its planar
            Plane plane = curve.GetPlane();
            // make the test ray from the plane
            double epsilon = 2e-6; // ( trust me on this )
            Point3dCollection IntersectionPoints = new Point3dCollection();
            Vector3d normal = plane.Normal;
            Vector3d testVector = normal.GetPerpendicularVector();
            using (Ray ray = new Ray())
                ray.BasePoint = testPt;
                int nGlancingHits = 0, numberOfInters = 0;
                bool bRetryWithOtherRayDirection;
                do
                    bRetryWithOtherRayDirection = false;
                    IntersectionPoints.Clear();
                    ray.UnitDir = testVector;
                    // fire the ray at the curve
                    curve.IntersectWith(ray,
                        Intersect.OnBothOperands,
                        IntersectionPoints,
                        IntPtr.Zero,
                        IntPtr.Zero);
                    numberOfInters = IntersectionPoints.Count;
                    if (numberOfInters == 0)
                        return false;
                    nGlancingHits = 0;
                    for (int i = 0; i < IntersectionPoints.Count; ++i)
                        double hitParam;
                        try
                            //This try/catch block circumvents an issue with GetParameterAtPoint API
                            hitParam = curve.GetParameterAtPoint(IntersectionPoints);
                        catch
                            bRetryWithOtherRayDirection = true;
                            testVector = testVector.RotateBy(5.0 * Math.PI / 180.0, normal);
                            break;
                        double inParam = hitParam - epsilon;
                        double outParam = hitParam + epsilon;
                        //Loop back inside the curve if param is falling outside of range
                        if (inParam < curve.StartParam)
                            inParam = curve.EndParam - epsilon + (curve.StartParam - inParam);
                        if (outParam > curve.EndParam)
                            outParam = curve.StartParam + epsilon + (curve.EndParam - outParam);
                        IncidenceType inIncidence = CurveIncidence(curve, inParam, testVector, normal);
                        IncidenceType outIncidence = CurveIncidence(curve, outParam, testVector, normal);
                        if (inIncidence == IncidenceType.kIncidenceToFront || outIncidence == IncidenceType.kIncidenceToFront)
                            break;
                        if ((inIncidence == IncidenceType.kIncidenceToRight && outIncidence == IncidenceType.kIncidenceToLeft) ||
                            (inIncidence == IncidenceType.kIncidenceToLeft && outIncidence == IncidenceType.kIncidenceToRight))
                            nGlancingHits++;
                while (bRetryWithOtherRayDirection);
                return ((numberOfInters + nGlancingHits) % 2. == 1
GMT+8, 2026-11-3 13:20 , Processed in 0.429028 second(s), 28 queries , Gzip On.
