查看: 2318|回复: 1
[分享] CreateDbObj
已领礼包: 1268个
发表于 2014-7-12 08:27:11 | 显示全部楼层 |阅读模式
#include "stdafx.h"
#include "StdArx.h"
#include "CreateDbObj.h"
#include "GeUtilities.h"
Acad::ErrorStatus
createSpline(const AcGeNurbCurve3d& crv, AcDbSpline*& spl)
        AcGe::EntityId type;
        if (crv.isDegenerate(type)) {
                return Acad::eDegenerateGeometry;
        int degree;
        Adesk::Boolean rational,periodic,closed;
        AcGeKnotVector knots;
        AcGePoint3dArray controlPoints;
        AcGeDoubleArray weights;
        int i;
        crv.getDefinitionData(degree,rational,periodic,knots,controlPoints,weights);
        closed = crv.isClosed();
        AcGeDoubleArray splknots;
        for(i=0;i<knots.length();i++)
                splknots.append(knots[i]);
        spl = new AcDbSpline(degree,rational,closed,periodic,controlPoints,splknots,weights);
        if (spl->isNull()) {
                return Acad::eNotNewlyCreated;
        } else {
                return Acad::eOk;
Acad::ErrorStatus
createSpline(const AcGeNurbCurve2d& crv, AcDbSpline*& spl, double z)
        int degree;
        AcGePoint2dArray controlPoints2d;
        int i;
        crv.getDefinitionData(degree,rational,periodic,knots,controlPoints2d,weights);
        points2dTo3d(controlPoints2d,controlPoints,z);
        for (i=0; i<knots.length(); i++)
        } else {
                return Acad::eOk;
Acad::ErrorStatus
createSpline(const AcGePoint3dArray& crv, AcDbSpline*& spl)
        spl = new AcDbSpline(crv);
        } else {
                return Acad::eOk;
Acad::ErrorStatus
createSpline(const AcGePoint2dArray& crv, AcDbSpline*& spl, double z)
        AcGePoint3dArray crv3d;
        points2dTo3d(crv,crv3d);
        spl = new AcDbSpline(crv3d);
        } else {
                return Acad::eOk;
Acad::ErrorStatus
createRegion(const ChGeLoop2d& loop,AcDbRegion*& pRg, int genType, double z)
        AcDbVoidPtrArray pLoop,pRgs;
        AcDbSpline *pSpl;
        AcDb3dPolyline *poly;
        AcDbLine *pLine;
        AcGePoint3dArray pnts;
        int i,len,j,jlen;
        len = loop.length();
        pLoop.setLogicalLength(0);
        for (i=0; i<len; i++) {
                if (loop[i].length()>1) {
                        points2dTo3d(loop[i],pnts,z);
                        if (genType==1) {
                                pSpl = new AcDbSpline(pnts);
                                pLoop.append(pSpl);
                        } else if (genType==2) {
                                poly = new AcDb3dPolyline(AcDb::k3dSimplePoly,pnts);
                                pLoop.append(poly);
                        } else if (genType==3) {
                                jlen = loop[i].length();
                                for (j=1; j<jlen; j++) {
                                        pLine = new AcDbLine(pnts[j-1],pnts[j]);
                                        pLoop.append(pLine);
        pRg->createFromCurves(pLoop,pRgs);
        len = pLoop.length();
        if (genType==1) {
                        delete (AcDbSpline*)(pLoop[i]);
                        delete (AcDb3dPolyline*)(pLoop[i]);
                        delete (AcDbLine*)(pLoop[i]);
        len = pRgs.length();
        if (len != 1) {
                        delete (AcDbRegion*)(pRgs[i]);
                return Acad::eInvalidInput;
        pRg = (AcDbRegion*)(pRgs[0]);
        return Acad::eOk;
已领礼包: 1268个
 楼主| 发表于 2014-7-12 08:27:51 | 显示全部楼层
#ifndef CREATE_DBOBJ_H
#define CREATE_DBOBJ_H
// 与创建Db对象的函数
// Note:
//                1. 所有创建的Db对象都没有加入数据库中, 创建成功后有必要释放
//                对象内存空间。
#include "TypeDef.h"
#ifdef _DBXEXP_
#define DLLIMPEXP __declspec(dllexport)
#else
#define DLLIMPEXP
#endif
*        Purpose:
*                create a spline entity.
*        Argument:
*                crv                [in], AcGeNurbCurve3d entity.
*                spl                [out], returned spline pointer.
*        Return:
*                Acad::eOk, 成功.
*                Acad::eNotNewlyCreated, 给出的参数不能创建相应的实体
*                Acad::eDegenerateGeometry, 曲线为退化实体
extern DLLIMPEXP Acad::ErrorStatus
createSpline(const AcGeNurbCurve3d& crv, AcDbSpline*& spl);
*        Purpose:
*        Argument:
*                crv                [in], AcGeNurbCurve2d entity.
*                z                [in], z-axis coordinate, default=0.0f.
*        Return:
*                Acad::eOk, 成功.
createSpline(const AcGeNurbCurve2d& crv, AcDbSpline*& spl, double z=0);
*        Purpose:
*        Argument:
*                crv                [in], 3d points.
*        Return:
*                Acad::eOk, 成功.
createSpline(const AcGePoint3dArray& crv, AcDbSpline*& spl);
*        Purpose:
*        Argument:
*                crv                [in], 2d points.
*        Return:
*                Acad::eOk, 成功.
createSpline(const AcGePoint2dArray& crv, AcDbSpline*& spl, double z=0);
*        Purpose:
*                从Loop2d创建Region对象.
*        Argument:
*                loop2d        [in], loop2d.
*                pRg                [out], 创建的region对象指针.
*                genType [in], 1使用spline创建Loop, 2使用polyline创建loop, 3使用line
*        Return:
*                Acad::eOk, 成功.
createRegion(const ChGeLoop2d& loop,AcDbRegion*& pRg, int genType=1, double z=0);
#endif // CREATE_DBOBJ_H
GMT+8, 2026-11-3 13:05 , Processed in 0.423272 second(s), 30 queries , Gzip On.
