查看: 1836|回复: 0
[分享] ChGeCurveCurveInt2d
已领礼包: 1268个
发表于 2014-7-12 08:32:00 | 显示全部楼层 |阅读模式
[ 本帖最后由 st788796 于 2014-7-12 09:06 编辑 ]\n\n#ifndef CH_GECURVECURVEINT2D_H
#define CH_GECURVECURVEINT2D_H
#ifndef ACGEXCONFIGARRAY
#define ACGEXCONFIGARRAY
typedef AcArray<AcGeXConfig> AcGeXConfigArray;
#endif
#include <gecint2d.h>
class ChGeCurveCurveInt2d : public AcGeCurveCurveInt2d
public:
        ChGeCurveCurveInt2d() {}
        ChGeCurveCurveInt2d(const AcGeCurve2d& curve1,const AcGeCurve2d& curve2,
                const AcGeTol& tol = AcGeContext::gTol);
                const AcGeInterval& range1,const AcGeInterval& range2,
        ChGeCurveCurveInt2d(const ChGeCurveCurveInt2d& src);
        ChGeCurveCurveInt2d& set(const AcGeCurve2d& curve1,const AcGeCurve2d& curve2,
                const AcGeTol& tol=AcGeContext::gTol);
        ChGeCurveCurveInt2d & orderWrt1();
        ChGeCurveCurveInt2d & orderWrt2();
        void getParams(AcGeDoubleArray& ps1,AcGeDoubleArray& ps2) { ps1 = params1; ps2 = params2; }
        void getXConfigs(AcGeXConfigArray& cs1,AcGeXConfigArray& cs2) { cs1 = confs1; cs2 = confs2;        }
        void getIntPoints(AcGePoint2dArray& ps) { ps = pnts;        }
protected:
        AcGeXConfigArray confs1,confs2;                // 曲线交点的config
        AcGeDoubleArray params1,params2;    // 曲线交点参数
        AcGePoint2dArray pnts;       // 曲线交点
inline ChGeCurveCurveInt2d::ChGeCurveCurveInt2d(const AcGeCurve2d& curve1,const AcGeCurve2d& curve2,
        const AcGeTol& tol)
        : AcGeCurveCurveInt2d(curve1,curve2,tol)
        int i,intNum;
        intNum = numIntPoints();
        confs1.setLogicalLength(intNum);
        confs2.setLogicalLength(intNum);
        params1.setLogicalLength(intNum);
        params2.setLogicalLength(intNum);
        pnts.setLogicalLength(intNum);
        for (i=0; i<intNum; i++) {
                pnts[i] = intPoint(i);
                getIntConfigs(i,confs1[i],confs2[i]);
                getIntParams(i,params1[i],params2[i]);
inline ChGeCurveCurveInt2d& ChGeCurveCurveInt2d::set(const AcGeCurve2d& curve1,const AcGeCurve2d& curve2,
        const AcGeTol& tol)
        AcGeCurveCurveInt2d::set(curve1,curve2,tol);
        int i,intNum;
        return *this;
        const AcGeTol& tol)
        : AcGeCurveCurveInt2d(curve1,curve2,range1,range2,tol)
        int i,intNum;
        const AcGeTol& tol)
        AcGeCurveCurveInt2d::set(curve1,curve2,range1,range2,tol);
        int i,intNum;
        return *this;
inline ChGeCurveCurveInt2d::ChGeCurveCurveInt2d(const ChGeCurveCurveInt2d& src)
//        AcGeCurve2d *cu1,*cu2;
//        AcGeTol tol;
//        cu1 = src.curve1();
//        cu2 = src.curve2();
//        tol = src.tolerance();
//        *this = ChGeCurveCurveInt2d(*(src.curve1()),*(src.curve2()),tol);
        *this = src;
inline ChGeCurveCurveInt2d & ChGeCurveCurveInt2d::orderWrt1()
        if (!numIntPoints()) return *this; // 没有交点
        int i,intNum;
        bool bAlready = true; // 是否已经是按照curve1排序
        for (i=1; i<intNum; i++) {
                if (params1[i] < params1[i-1]) {
                        bAlready = false;
                        break;
        if (!bAlready) {
                int j,min;
                for (i=0; i<intNum-1; i++) {
                        min = i;
                        for (j=i+1; j<intNum; j++) {
                                if (params1[min]>params1[j]) min = j;
                        if (min != i) {
                                params1.swap(i,min);
                                params2.swap(i,min);
                                confs1.swap(i,min);
                                confs2.swap(i,min);
                                pnts.swap(i,min);
        return *this;
inline ChGeCurveCurveInt2d & ChGeCurveCurveInt2d::orderWrt2()
        int i,intNum;
                if (params2[i] < params2[i-1]) {
                        bAlready = false;
                        break;
        if (!bAlready) {
                int j,min;
                        min = i;
                                if (params2[min]>params2[j]) min = j;
                        if (min != i) {
                                confs1.swap(i,min);
                                confs2.swap(i,min);
                                pnts.swap(i,min);
        return *this;
#endif // CH_GECURVECURVEINT2D_H
GMT+8, 2026-11-3 03:10 , Processed in 0.467749 second(s), 28 queries , Gzip On.
