查看: 1685|回复: 2
[分享] GrUtilities
已领礼包: 1268个
发表于 2014-7-12 08:46:35 | 显示全部楼层 |阅读模式
#include "stdafx.h"
#include "stdarx.h"
#include "GrUtilities.h"
#include "dbxutil.h"
#include "geassign.h"
void drawInfo(const AcGePoint3d& p1, const AcGePoint3d& p2,short color)
        ads_point ucsP1,ucsP2;
        acdbWcs2Ucs(asDblArray(p1),ucsP1,Adesk::kFalse);
        acdbWcs2Ucs(asDblArray(p2),ucsP2,Adesk::kFalse);
        acedGrDraw(ucsP1,ucsP2,color,0);
void drawInfo(const AcGePoint3d& pWcs,short color)
        ads_point p,p1,p2,p3,p4;
        double size = 5;
        acdbWcs2Ucs(asDblArray(pWcs),p,Adesk::kFalse);
        struct resbuf rb;
        if(acedGetVar("VIEWSIZE",&rb) == RTNORM)
                size = rb.resval.rreal * 0.05;
        p1[0] = p[0] - size;
        p1[1] = p[1] - size;
        p1[2] = p[2];
        p2[0] = p[0] + size;
        p2[1] = p[1] - size;
        p2[2] = p[2];
        p3[0] = p[0] + size;
        p3[1] = p[1] + size;
        p3[2] = p[2];
        p4[0] = p[0] - size;
        p4[1] = p[1] + size;
        p4[2] = p[2];
        acedGrDraw(p1,p2,color,0);
        acedGrDraw(p2,p3,color,0);
        acedGrDraw(p3,p4,color,0);
        acedGrDraw(p4,p1,color,0);
void drawInfo(const AcGePoint3dArray& ar,short color)
        AcGePoint3d p,last,first;
        first = last = ar[0];
        for(int i=1;i<ar.length();i++)
                p = ar[i];
                drawInfo(p,last,color);
                last = p;
        drawInfo(first, last,color);
void drawInfo(const AcGeBoundBlock3d& block,short color)
        ads_point p1,p2,p3,p4,p5,p6,p7,p8;
        AcGePoint3d blockP1,blockP2;
        AcGePoint3d wcsBlockP1,wcsBlockP2;
        block.getMinMaxPoints (wcsBlockP1,wcsBlockP2);
        acdbWcs2Ucs(asDblArray(wcsBlockP1),asDblArray(blockP1),Adesk::kFalse);
        acdbWcs2Ucs(asDblArray(wcsBlockP2),asDblArray(blockP2),Adesk::kFalse);
        p1[0] = blockP1.x;
        p1[1] = blockP1.y;
        p1[2] = blockP1.z;
        p2[0] = blockP2.x;
        p2[1] = blockP1.y;
        p2[2] = blockP1.z;
        p3[0] = blockP2.x;
        p3[1] = blockP2.y;
        p3[2] = blockP1.z;
        p4[0] = blockP1.x;
        p4[1] = blockP2.y;
        p4[2] = blockP1.z;
        p5[0] = blockP1.x;
        p5[1] = blockP1.y;
        p5[2] = blockP2.z;
        p6[0] = blockP2.x;
        p6[1] = blockP1.y;
        p6[2] = blockP2.z;
        p7[0] = blockP2.x;
        p7[1] = blockP2.y;
        p7[2] = blockP2.z;
        p8[0] = blockP1.x;
        p8[1] = blockP2.y;
        p8[2] = blockP2.z;
        acedGrDraw(p5,p6,color,0);
        acedGrDraw(p6,p7,color,0);
        acedGrDraw(p7,p8,color,0);
        acedGrDraw(p8,p5,color,0);
        acedGrDraw(p1,p5,color,0);
        acedGrDraw(p2,p6,color,0);
        acedGrDraw(p3,p7,color,0);
        acedGrDraw(p4,p8,color,0);
void drawInfo(const AcGeCurve3d* crv,short color)
        AcGeInterval iv;
        double lb,ub;
        crv->getInterval(iv);
        iv.getBounds(lb,ub);
        double param = lb;
        double step = (ub-lb) / 100;
        AcGePoint3d p1,p2;
        p1 = crv->evalPoint(lb);
        acdbWcs2Ucs(asDblArray(p1),asDblArray(p1),Adesk::kFalse);
        while(param < ub)
                param += step;
                p2 = crv->evalPoint(param);
                acdbWcs2Ucs(asDblArray(p2),asDblArray(p2),Adesk::kFalse);
                acedGrDraw(asDblArray(p1),asDblArray(p2),color,0);
                p1 = p2;
        p2 = crv->evalPoint(ub);
void drawAxis(const AcGePoint3d& org,const AcGeVector3d& vec, double len, short color)
        AcGePoint3d p1,p2,p3;
        AcGeVector3d vecNormal,vec1,vec2;
        vecNormal = vec.normal();
        vec1 = vecNormal.perpVector();
        vec2 = vecNormal.crossProduct(vec1);
        p1 = org;
        p2 = p1 + vecNormal*len;
        p3 = p2 + vecNormal*len/4;
        AcGeCircArc3d cir(p2,vecNormal,len/8);
        acdbWcs2Ucs(asDblArray(p3),asDblArray(p3),Adesk::kFalse);
//        drawInfo(&(cir));
        AcGeInterval iv;
        double lb,ub;
        cir.getInterval(iv);
        double param = lb;
        p1 = cir.evalPoint(lb);
        acedGrDraw(asDblArray(p1),asDblArray(p3),color,0);
        while(param < ub)
                param += step;
                p2 = cir.evalPoint(param);
                acedGrDraw(asDblArray(p2),asDblArray(p3),color,0);
                p1 = p2;
        p2 = cir.evalPoint(ub);
评分
参与人数 1贡献 +3 收起 理由
SmallBlackCat + 3 很给力!经验;资料分享奖!
查看全部评分
已领礼包: 1268个
 楼主| 发表于 2014-7-12 08:47:10 | 显示全部楼层
#ifndef GR_UTILITIES_H
#define GR_UTILITIES_H
// 与acedGrXXX()相关的函数
// Note:
*        Purpose:
*                Draw a box with acedGrDraw in the current viewport, all
*                position is in WCS
extern void        drawInfo(const AcGeBoundBlock3d& block,short color=3);
*        Purpose:
*                Draw a line with acedGrDraw in the current viewport
extern void
drawInfo(const AcGePoint3d& p1, const AcGePoint3d& p2,short color=3);
*        Purpose:
*                Draw a rectangle with acedGrDraw in the current viewport
*                pWcs is center, size is 5
extern void drawInfo(const AcGePoint3d& pWcs,short color=3);
*        Purpose:
*                Draw a polygon with acedGrDraw in the current viewport
extern void drawInfo(const AcGePoint3dArray& ar,short color=3);
*        Purpose:
*                Draw a curve with acedGrDraw in the current viewport
extern void drawInfo(const AcGeCurve3d*,short color=3);
*        Purpose:
*                Draw an axis with acedGrDraw in the current viewport
extern void drawAxis(const AcGePoint3d& org,const AcGeVector3d& vec, double len, short color=3);
#endif // GR_UTILITIES_H
已领礼包: 1268个
 楼主| 发表于 2014-7-12 18:42:52 来自手机 | 显示全部楼层
标记下 getInterval
AcGeCurveCurveInt3d
GMT+8, 2026-11-3 07:35 , Processed in 0.411842 second(s), 36 queries , Gzip On.
