查看: 1941|回复: 0
[分享] CSharp启动AutoCAD
已领礼包: 859个
发表于 2014-7-21 17:20:47 | 显示全部楼层 |阅读模式
http://www.cppblog.com/mzty/archive/2008/06/17/53649.html
CSharp启动AutoCAD
一 我们可以通过AutoCAD安装以后提供的COM接口启动AutoCAD。
COM组件为:
AutoCAD/ObjectDBX Common 17.1 Type Library
(Autodesk.AutoCAD.Interop.Common.dll).
AutoCAD 2009 Type Library (Autodesk.AutoCAD.Interop.dll)
  1. public static void Way1()
  2. {
  3.     const string progID = "AutoCAD.Application.17.1";
  4.     AcadApplication acApp = null;
  5.     try
  6.     {
  7.         acApp = (AcadApplication)Marshal.GetActiveObject(progID);
  8.     }
  9.     catch
  10.     {
  11.         try
  12.         {
  13.             Type acType = Type.GetTypeFromProgID(progID);
  14.             acApp = (AcadApplication)Activator.CreateInstance(acType,true);
  15.         }
  16.         catch
  17.         {
  18.             MessageBox.Show("Cannot create object of type "" +progID + """);
  19.         }
  20.     }
  21.     if (acApp != null)
  22.     {
  23.         // By the time this is reached AutoCAD is fully
  24.         // functional and can be interacted with through code
  25.         acApp.Visible = true;
  26.         acApp.ActiveDocument.SendCommand("_MYCOMMAND ");
  27.     }
  28. }
复制代码
  1. public static void Way2()
  2. {
  4.     const string exePath = @"E:\Program Files\Autodesk\ACADM 2009\acad.exe";
  5.     AcadApplication acApp = null;
  6.     // Let's first check we don't have AutoCAD already running
  7.     try
  8.     {
  9.         acApp =(AcadApplication)Marshal.GetActiveObject(progID);
  10.     }
  11.     catch { }
  12.     if (acApp != null)
  13.     {
  14.         MessageBox.Show("An instance of AutoCAD is already running.");
  15.     }
  16.     else
  17.     {
  18.         try
  19.         {
  20.             // Use classes from the System.Diagnostics namespace
  21.             // to launch our AutoCAD process with command-line
  22.             // options
  23.             ProcessStartInfo psi = new ProcessStartInfo(exePath, "/p myprofile");
  24.             psi.WorkingDirectory = @"c:\temp";
  25.             Process pr = Process.Start(psi);
  26.             // Wait for AutoCAD to be ready for input
  27.             // This doesn't wait until AutoCAD is ready
  28.             // to receive COM requests, it seems
  29.             pr.WaitForInputIdle();
  30.             // Connect to our process using COM
  31.             // We're going to loop infinitely until we get the
  32.             // AutoCAD object.
  33.             // A little risky, unless we implement a timeout
  34.             // mechanism or let the user cancel
  35.             while (acApp == null)
  36.             {
  37.                 try
  38.                 {
  39.                     acApp = (AcadApplication)Marshal.GetActiveObject(progID);
  40.                 }
  41.                 catch
  42.                 {
  43.                     // Let's let the application check its message
  44.                     // loop, in case the user has exited or cancelled
  45.                     Application.DoEvents();
  46.                 }
  47.             }
  48.         }
  49.         catch (Exception ex)
  50.         {
  51.             MessageBox.Show("Cannot create or attach to AutoCAD object: "+ ex.Message);
  52.         }
  53.     }
  54.     if (acApp != null)
  55.     {
  56.         acApp.Visible = true;
  57.         acApp.ActiveDocument.SendCommand("_MYCOMMAND ");
  58.     }
  59. }
GMT+8, 2026-11-3 13:20 , Processed in 0.375620 second(s), 28 queries , Gzip On.
