查看: 2329|回复: 0
[原创] 练习 LispFunction PointsBox
已领礼包: 859个
发表于 2014-7-23 21:04:53 | 显示全部楼层 |阅读模式
  1.         [LispFunction("Points_Box")]
  2.         public static ResultBuffer GetPointsBox(ResultBuffer rb)
  3.         {
  4.             TypedValue[] values = rb.AsArray();
  5.             Extents3d ext = new Extents3d();
  6.             for (int i = 1; i < values.Length - 1; i++)
  7.             {
  8.                 ext.AddPoint((Point3d)values[i].Value);
  9.             }
  10.             Point3d p1 = ext.MinPoint;
  11.             Point3d p2 = ext.MaxPoint;
  12.             TypedValue[] val = new TypedValue[6];
  13.             val[0] = new TypedValue((int)LispDataType.ListBegin);
  14.             val[1] = new TypedValue((int)LispDataType.Point3d, p1);
  15.             val[2] = new TypedValue((int)LispDataType.Point3d, new Point3d(p2.X, p1.Y, p1.Z));
  16.             val[3] = new TypedValue((int)LispDataType.Point3d, p2);
  17.             val[4] = new TypedValue((int)LispDataType.Point3d, new Point3d(p1.X, p2.Y, p2.Z));
  18.             val[5] = new TypedValue((int)LispDataType.ListEnd);
  19.             return new ResultBuffer(val);
  20.         }
和 (apply 'mapcar (cons 'min pts)) 对比
命令: TT
选择对象: 指定对角点: 找到 119700 个
选择对象:
((-41231.6 -30413.4 0.0) (77723.2 -30413.4 0.0) (77723.2 83616.3 0.0) (-41231.6 83616.3 0.0))
0.057
0.114
GMT+8, 2026-11-3 13:19 , Processed in 0.532873 second(s), 28 queries , Gzip On.
