查看: 2419|回复: 1
[原创] 练习 相交的Region执行Union
已领礼包: 859个
发表于 2014-7-26 18:40:32 | 显示全部楼层 |阅读模式
  1.         [CommandMethod("GetUnionRegs")]
  2.         public static void GetCurveUnionRegions()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Database db = doc.Database;
  6.             Editor ed = doc.Editor;
  7.             TypedValue[] val = new TypedValue[1]
  8.             {
  9.                 new TypedValue(0, "REGION")
  10.             };
  11.             PromptSelectionOptions pso = new PromptSelectionOptions();
  12.             pso.MessageForAdding = "\nSelect Regions";
  13.             PromptSelectionResult psr = ed.GetSelection(pso, new SelectionFilter(val));
  14.             if (psr.Status != PromptStatus.OK) return;
  15.             using (Transaction tr = db.TransactionManager.StartTransaction())
  16.             {
  17.                 SelectionSet ss = (SelectionSet)psr.Value;
  18.                 ObjectId[] ids = ss.GetObjectIds();
  19.                 try
  20.                 {
  21.                     RegionsUnion(ids);
  22.                 }
  23.                 catch (Exception)
  24.                 {
  25.                     throw;
  26.                 }
  27.                 tr.Commit();
  28.             }
  29.         }
  30.         private static bool RectIntersects(Extents3d first, Extents3d second)
  31.         {
  32.             bool one = second.MinPoint.X < first.MaxPoint.X &&
  33.                 first.MinPoint.X < second.MaxPoint.X &&
  34.                 second.MinPoint.Y < first.MaxPoint.Y &&
  35.                 first.MinPoint.Y < second.MaxPoint.Y;
  36.             bool two = first.MinPoint.X < second.MaxPoint.X &&
  37.               second.MinPoint.X < first.MaxPoint.X &&
  38.               first.MinPoint.Y < second.MaxPoint.Y &&
  39.               second.MinPoint.Y < first.MaxPoint.Y;
  40.             return one | two;
  41.         }
  42.         private static void RegionsUnion(ObjectId[] ids)
  43.         {
  44.             Matrix3d mat = Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem;
  45.             for (int i = 0; i < ids.Length; i++)
  46.             {
  47.                 if (!ids[i].IsNull)
  48.                 {
  49.                     Region fRegion = (Region)ids[i].GetObject(OpenMode.ForRead);
  50.                     using (fRegion)
  51.                     {
  52.                         for (int j = i + 1; j < ids.Length; j++)
  53.                         {
  54.                             Extents3d ext1 = fRegion.GeometricExtents;
  55.                             Region sRegion = (Region)ids[j].GetObject(OpenMode.ForRead);
  56.                             if (!sRegion.IsNull)
  57.                             {
  58.                                 Extents3d ext2 = sRegion.GeometricExtents;
  59.                                 Region tmpfRegion = (Entity) fRegion.Clone() as Region;
  60.                                 Region tmpsRegion = (Entity) sRegion.Clone() as Region;
  61.                                 if (RectIntersects(ext1, ext2))
  62.                                 {
  63.                                     tmpfRegion.BooleanOperation(BooleanOperationType.BoolIntersect, tmpsRegion);
  64.                                     if (!tmpfRegion.IsNull)
  65.                                     {
  66.                                         fRegion.UpgradeOpen();
  67.                                         sRegion.UpgradeOpen();
  68.                                         fRegion.BooleanOperation(BooleanOperationType.BoolUnite, sRegion);
  69.                                     }
  70.                                 }
  71.                             }
  72.                         }
  73.                     }
  74.                 }
  75.             }
  76.         }
已领礼包: 859个
 楼主| 发表于 2014-7-28 07:34:05 来自手机 | 显示全部楼层
问题
1 可能漏掉只有一个公共边的两个形
2 这种循环可能把后面的一个较大形状并到前面从而漏掉一些需合并的,解决办法应该是先按面积排序,以保障较大的形在前
GMT+8, 2026-11-3 13:20 , Processed in 0.433792 second(s), 33 queries , Gzip On.
