查看: 1763|回复: 0
[分享] Iterating AutoCAD system variables using .NET – Part 1
已领礼包: 859个
发表于 2014-7-30 21:53:56 来自手机 | 显示全部楼层 |阅读模式
http://through-the-interface.typepad.com/through_the_interface/2014/06/iterating-autocad-system-variables-using-net-part-1.html
On my flight across to Toronto, I took another look at the “What’s New in AutoCAD 2015” section of the .NET API documentation and decided to dig into the new SystemVariableEnumerator implementation.
I was particularly curious about this feature as there is already a way to get access to system variables via the Autodesk.AutoCAD.Runtime.SystemObjects.Variables collection. As an initial look at these two classes, I decided to put together a couple of simple variable iterator commands that use the same function to print out some information concerning the system variables exposed by each collection.
Here’s the C# code implementing two commands, ESV and ESV2, which use the two mechanisms for getting the list of AutoCAD system variables:
We won’t look at the output to the command-line in this post, as there’s a lot there. Hopefully the format of the data printed to the command-line is obvious from the code.
A big chunk of this code actually “decodes” the type information, returning a System.Type object when it can make sense of the number passed in (which may be a 50xx number or a shorter enumeration, depending on which mechanism has been used).
It’s also worth noting that it wasn’t quite as simple as doing a “foreach” on the new API: it seems there’s a GetEnumerator() method missing which means we can’t simplify our code in that way, unfortunately (hence the long-hand approach using MoveNext() etc.). Hopefully someone will tell me I’ve made a mistake somewhere in my code and that it is, in fact, possible. :-)
The newer enumerator skips over “hidden” system variables – those with an asterisk (“*”) prefix on their name – which do get returned as part of the SystemObjects collection.
The SystemObjects collection does allow you to set the value of a variable, which is pretty interesting. In a future post we’ll take a look at this capability as well as comparing the performance of the two mechanisms, to see which is most efficient
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.ApplicationServices.Core;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Geometry;
  5. using Autodesk.AutoCAD.Runtime;
  6. using System;
  7. namespace SystemVariableEnumeration
  8. {
  9.   public class Commands
  10.   {
  11.     [CommandMethod("ESV")]
  12.     public static void EnumerateSysVars()
  13.     {
  14.       var doc = Application.DocumentManager.MdiActiveDocument;
  15.       if (doc == null)
  16.         return;
  17.       var ed = doc.Editor;
  18.       // Use the existing SystemObjects iteration mechanism
  19.       foreach (var v in SystemObjects.Variables)
  20.       {
  21.         PrintVariable(ed, v);
  22.       }
  23.     }
  24.     [CommandMethod("ESV2")]
  25.     public static void EnumerateSysVars2()
  26.     {
  27.       var doc = Application.DocumentManager.MdiActiveDocument;
  28.       if (doc == null)
  29.         return;
  30.       var ed = doc.Editor;
  31.       // Use the new system variable enumerator
  32.       var sve = new SystemVariableEnumerator();
  33.       while (sve.MoveNext())
  34.       {
  35.         var v = sve.Current;
  36.         if (v != null)
  37.         {
  38.           PrintVariable(ed, v);
  39.         }
  40.       }
  41.     }
  42.     // Helper function to print out the information about
  43.     // a particular variable
  44.     private static void PrintVariable(Editor ed, Variable v)
  45.     {
  46.       var t = GetType(v.PrimaryType);
  47.       ed.WriteMessage(
  48.         "\n{0} ({1}, {2} - {3}): {4}",
  49.         v.Name,
  50.         t == null ? "null" : t.Name,
  51.         v.PrimaryType, v.SecondaryType, v.TypeFlags
  52.       );
  53.       if (v.Range != null)
  54.       {
  55.         ed.WriteMessage(
  56.           " [{0}...{1}]",
  57.           v.Range.LowerBound, v.Range.UpperBound
  58.         );
  59.       }
  60.     }
  61.     // Determine the type of a system variable based on
  62.     // the internal representation
  63.     private static System.Type GetType(short v)
  64.     {
  65.       Type ret = null;
  66.       switch (v)
  67.       {
  68.         case 1:
  69.         case 5001: // RTREAL real number
  70.           {
  71.             ret = typeof(Double);
  72.             break;
  73.           }
  74.         case 2:
  75.         case 5002: // RTPOINT: 2D point X and Y only
  76.           {
  77.             ret = typeof(Point2d);
  78.             break;
  79.           }
  80.         case 3:
  81.         case 5003: // RTSHORT: short integer
  82.           {
  83.             ret = typeof(Int16);
  84.             break;
  85.           }
  86.         case 4:
  87.         case 5004: // RTANG: angle
  88.           {
  89.             ret = null; // Angle
  90.             break;
  91.           }
  92.         case 5:
  93.         case 5005: // RTSTR: string
  94.           {
  95.             ret = typeof(String);
  96.             break;
  97.           }
  98.         case 6:
  99.         case 5006: // RTENAME: entity name
  100.           {
  101.             ret = null;
  102.             break;
  103.           }
  104.         case 7:
  105.         case 5007: // RTPICKS: pick set
  106.           {
  107.             ret = null;
  108.             break;
  109.           }
  110.         case 8:
  111.         case 5008: // RTORIENT: orientation
  112.           {
  113.             ret = null; // Orientation
  114.             break;
  115.           }
  116.         case 9:
  117.         case 5009: // RT3DPOINT: 3D point - X, Y and Z
  118.           {
  119.             ret = typeof(Point3d);
  120.             break;
  121.           }
  122.         case 10:
  123.         case 5010: // RTLONG: long integer
  124.           {
  125.             ret = typeof(Int32);
  126.             break;
  127.           }
  128.         case 11:
  129.         case 5011: // 2D extents of some kind
  130.           {
  131.             ret = typeof(Point2d);
  132.             break;
  133.           }
  134.       }
  135.       return ret;
  136.     }
  137.   }
  138. }
GMT+8, 2026-11-3 15:32 , Processed in 0.378224 second(s), 28 queries , Gzip On.
