查看: 1756|回复: 0
[分享] Iterating AutoCAD system variables using .NET – Part 2
已领礼包: 859个
发表于 2014-7-30 21:58:53 来自手机 | 显示全部楼层 |阅读模式
http://through-the-interface.typepad.com/through_the_interface/2014/06/iterating-autocad-system-variables-using-net-part-2.html
In the last post we saw some code to exercise to two available system variable enumeration mechanisms in AutoCAD, SystemObjects.Variables and the new SystemVariableEnumerator class.
Today we’re going to take a closer look at these two mechanisms, briefly comparing their performance and results. I took some code from this previous post to measure elapsed time, deleting the “runs” database to simplify the code once I’d realised the performance was basically comparable.
Here’s the C# code, with the updated ESV and ESV2 commands which now create correspondingly named .txt files in c:\temp, rather than printing the results to the command-line (and with Primary/SecondaryType information ignored, to make the output consistent – and therefore diffable – between the two commands):
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.ApplicationServices.Core;
  3. using Autodesk.AutoCAD.Geometry;
  4. using Autodesk.AutoCAD.Runtime;
  5. using System;
  6. using System.Diagnostics;
  7. using System.IO;
  8. using System.Text;
  9. namespace SystemVariableEnumeration
  10. {
  11.   public class Commands
  12.   {
  13.     public void MeasureTime(
  14.       Document doc, Func<int> func, string name
  15.     )
  16.     {
  17.       // Get the name of the running command(s)
  18.       // (might also have queried the CommandMethod attribute
  19.       // via reflection, but that would be a lot more work)
  20.       var cmd = (string)Application.GetSystemVariable("CMDNAMES");
  21.       // Start a Stopwatch to time the execution
  22.       var sw = new Stopwatch();
  23.       sw.Start();
  24.       // Run the function, getting back the count of the results
  25.       var cnt = func();
  26.       // Stop the Stopwatch and print the results to the command-line
  27.       sw.Stop();
  28.       doc.Editor.WriteMessage(
  29.         "\n{0} found {1} {2} in {3}.", cmd, cnt, name, sw.Elapsed
  30.       );
  31.     }
  32.     [CommandMethod("ESV")]
  33.     public void EnumerateSysVars()
  34.     {
  35.       var doc = Application.DocumentManager.MdiActiveDocument;
  36.       if (doc == null)
  37.         return;
  38.       MeasureTime(
  39.         doc,
  40.         () =>
  41.         {
  42.           int numVars = 0;
  43.           using (var sw = new StreamWriter("c:\\temp\\esv.txt"))
  44.           {
  45.             // Use the existing SystemObjects iteration mechanism
  46.             foreach (var v in SystemObjects.Variables)
  47.             {
  48.               sw.WriteLine(GetVariableInfo(v));
  49.               numVars++;
  50.             }
  51.           }
  52.           return numVars;
  53.         },
  54.         "variables"
  55.       );
  56.     }
  57.     [CommandMethod("ESV2")]
  58.     public void EnumerateSysVars2()
  59.     {
  60.       var doc = Application.DocumentManager.MdiActiveDocument;
  61.       if (doc == null)
  62.         return;
  63.       MeasureTime(
  64.         doc,
  65.         () =>
  66.         {
  67.           int numVars = 0;
  68.           using (var sw = new StreamWriter("c:\\temp\\esv2.txt"))
  69.           {
  70.             // Use the new system variable enumerator
  71.             var sve = new SystemVariableEnumerator();
  72.             while (sve.MoveNext())
  73.             {
  74.               var v = sve.Current;
  75.               if (v != null)
  76.               {
  77.                 sw.WriteLine(GetVariableInfo(v));
  78.                 numVars++;
  79.               }
  80.             }
  81.           }
  82.           return numVars;
  83.         },
  84.         "variables"
  85.       );
  86.     }
  87.     // Helper function to get the information for a particular
  88.     // variable
  89.     private static string GetVariableInfo(Variable v)
  90.     {
  91.       var t = GetType(v.PrimaryType);
  92.       var sb = new StringBuilder();
  93.       sb.AppendFormat(
  94.         "{0} ({1}): {2}", // Skip the additional type info
  95.         v.Name,
  96.         t == null ? "null" : t.Name,
  97.         /*v.PrimaryType, v.SecondaryType,*/ v.TypeFlags
  98.       );
  99.       if (v.Range != null)
  100.       {
  101.         sb.AppendFormat(
  102.           " [{0}...{1}]",
  103.           v.Range.LowerBound, v.Range.UpperBound
  104.         );
  105.       }
  106.       return sb.ToString();
  107.     }
  108.     // Determine the type of a system variable based on
  109.     // the internal representation
  110.     private static System.Type GetType(short v)
  111.     {
  112.       Type ret = null;
  113.       switch (v)
  114.       {
  115.         case 1:
  116.         case 5001: // RTREAL real number
  117.           {
  118.             ret = typeof(Double);
  119.             break;
  120.           }
  121.         case 2:
  122.         case 5002: // RTPOINT: 2D point X and Y only
  123.           {
  124.            ret = typeof(Point2d);
  125.             break;
  126.           }
  127.         case 3:
  128.         case 5003: // RTSHORT: short integer
  129.           {
  130.             ret = typeof(Int16);
  131.             break;
  132.           }
  133.         case 4:
  134.         case 5004: // RTANG: angle
  135.           {
  136.             ret = null; // Angle
  137.             break;
  138.           }
  139.         case 5:
  140.         case 5005: // RTSTR: string
  141.           {
  142.             ret = typeof(String);
  143.             break;
  144.           }
  145.         case 6:
  146.         case 5006: // RTENAME: entity name
  147.           {
  148.             ret = null;
  149.             break;
  150.           }
  151.         case 7:
  152.         case 5007: // RTPICKS: pick set
  153.           {
  154.             ret = null;
  155.             break;
  156.           }
  157.         case 8:
  158.         case 5008: // RTORIENT: orientation
  159.           {
  160.             ret = null; // Orientation
  161.             break;
  162.           }
  163.         case 9:
  164.         case 5009: // RT3DPOINT: 3D point - X, Y and Z
  165.           {
  166.             ret = typeof(Point3d);
  167.             break;
  168.           }
  169.         case 10:
  170.         case 5010: // RTLONG: long integer
  171.           {
  172.             ret = typeof(Int32);
  173.             break;
  174.           }
  175.         case 11:
  176.         case 5011: // 2D extents of some kind
  177.           {
  178.             ret = typeof(Point2d);
  179.             break;
  180.           }
  181.       }
  182.       return ret;
  183.     }
  184.   }
  185. }
When we run the code we see that the ESV command – the implementation using SystemObjects.Variables – returns the results more quickly but finds only 274 (or 275 with AutoCAD 2015 SP1 installed, as we have the new CURSORBADGE sysvar), whereas the ESV2 command finds 912 (or 913 with SP1) in a timespan that’s basically consistent with the fact there are more variables found. So performance isn’t an issue.
It is interesting (and somewhat reassuring) that the new enumerator finds so many more sysvars than the former mechanism. On the one hand the old collection allows you to modify a system variable’s value via the returned object…
  1. [CommandMethod("TOGCB")]
  2. public void ToggleCursorBadge()
  3. {
  4.   var doc = Application.DocumentManager.MdiActiveDocument;
  5.   if (doc == null)
  6.     return;
  7.   var ed = doc.Editor;
  8.   const string curbadge = "CURSORBADGE";
  9.   // Get our CURSORBADGE system variable object
  10.   var cb = SystemObjects.Variables[curbadge];
  11.   // Report its initial value
  12.   ed.WriteMessage(
  13.     "\nInitial value of {0} is {1}.", curbadge, cb.Value
  14.   );
  15.   // Set the new value, toggling between 1 & 2
  16.   // (with too many casts for my liking, but hey)
  17.   cb.Value = (short)((short)cb.Value == 1 ? 2 : 1);
  18.   // And report the new value to make sure it worked
  19.   ed.WriteMessage(
  20.     "\nNew value of {0} is {1}.", curbadge, cb.Value
  21.   );
  22. }
… but on the other hand this is really only for a subset of system variables (and I haven’t yet worked out which subset… I do know the new enumerator skips anonymous sysvars, and yet it still finds more than 3x the number).
In case you want to dig into the sysvars returned by each, here are the results for the ESV and the ESV2 commands. I did my own diff – and the results are returned in a consistent order, in that the ones found by ESV are at the end of the ones found by ESV2 – but I haven’t yet spent much time working out which ones are excluded from the old mechanism and why.
If anyone does look into this, please do post a comment: I’ll also post an update if I find out something further from my side.
GMT+8, 2026-11-3 15:33 , Processed in 0.439606 second(s), 28 queries , Gzip On.
