查看: 2798|回复: 1
[分享] Jigging an AutoCAD hatch using .NET (redux)
已领礼包: 859个
发表于 2014-7-30 22:08:01 来自手机 | 显示全部楼层 |阅读模式
http://through-the-interface.typepad.com/through_the_interface/2014/04/jigging-an-autocad-hatch-using-net-redux.html
Many thanks to Holger Rasch who worked out how to fix the code in this previous post. It really doesn’t matter that 3 years have passed, Holger – I have no doubt people will greatly appreciate the fact the code can now run without causing the annoying display issues it produced previously.
Holger made a few adjustments to the implementation to make sure the persistent hatch loop gets added and removed in the right places. Here’s the updated C# code:
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Geometry;
  5. using Autodesk.AutoCAD.Runtime;
  6. using Autodesk.AutoCAD.Colors;
  7. using System;
  8. namespace HatchJig
  9. {
  10.   class JigUtils
  11.   {
  12.     // Custom ArcTangent method, as the Math.Atan
  13.     // doesn't handle specific cases
  14.     public static double Atan(double y, double x)
  15.     {
  16.       if (x > 0)
  17.         return Math.Atan(y / x);
  18.       else if (x < 0)
  19.         return Math.Atan(y / x) - Math.PI;
  20.       else  // x == 0
  21.       {
  22.         if (y > 0)
  23.           return Math.PI;
  24.         else if (y < 0)
  25.           return -Math.PI;
  26.         else // if (y == 0) theta is undefined
  27.           return 0.0;
  28.       }
  29.     }
  30.     // Computes Angle between current direction
  31.     // (vector from last vertex to current vertex)
  32.     // and the last pline segment
  33.     public static double ComputeAngle(
  34.       Point3d startPoint, Point3d endPoint,
  35.       Vector3d xdir, Matrix3d ucs
  36.     )
  37.     {
  38.       var v =
  39.         new Vector3d(
  40.           (endPoint.X - startPoint.X) / 2,
  41.           (endPoint.Y - startPoint.Y) / 2,
  42.           (endPoint.Z - startPoint.Z) / 2
  43.         );
  44.       double cos = v.DotProduct(xdir);
  45.       double sin =
  46.         v.DotProduct(
  47.           Vector3d.ZAxis.TransformBy(ucs).CrossProduct(xdir)
  48.         );
  49.       return Atan(sin, cos);
  50.     }
  51.   }
  52.   public class HatchJig : DrawJig
  53.   {
  54.     Point3d _tempPoint;
  55.     bool _isArcSeg = false;
  56.     bool _isUndoing = false;
  57.     Matrix3d _ucs;
  58.     Plane _plane;
  59.     Polyline _pline = null;
  60.     Hatch _hat = null;
  61.     public HatchJig(
  62.       Matrix3d ucs, Plane plane, Polyline pl, Hatch hat
  63.     )
  64.     {
  65.       _ucs = ucs;
  66.       _plane = plane;
  67.       _pline = pl;
  68.       _hat = hat;
  69.       AddDummyVertex();
  70.     }
  71.     protected override bool WorldDraw(
  72.       Autodesk.AutoCAD.GraphicsInterface.WorldDraw wd
  73.     )
  74.     {
  75.       // Update the dummy vertex to be our 3D point
  76.       // projected onto our plane
  77.       if (_isArcSeg)
  78.       {
  79.         var lastVertex =
  80.           _pline.GetPoint3dAt(_pline.NumberOfVertices - 2);
  81.         Vector3d refDir;
  82.         if (_pline.NumberOfVertices < 3)
  83.           refDir = new Vector3d(1.0, 1.0, 0.0);
  84.         else
  85.         {
  86.           // Check bulge to see if last segment was an arc or a line
  87.           if (_pline.GetBulgeAt(_pline.NumberOfVertices - 3) != 0)
  88.           {
  89.             var arcSegment =
  90.               _pline.GetArcSegmentAt(_pline.NumberOfVertices - 3);
  91.             var tangent = arcSegment.GetTangent(lastVertex);
  92.             // Reference direction is the invert of the arc tangent
  93.             // at last vertex
  94.             refDir = tangent.Direction.MultiplyBy(-1.0);
  95.           }
  96.           else
  97.           {
  98.             var pt =
  99.               _pline.GetPoint3dAt(_pline.NumberOfVertices - 3);
  100.             refDir =
  101.               new Vector3d(
  102.                 lastVertex.X - pt.X,
  103.                 lastVertex.Y - pt.Y,
  104.                 lastVertex.Z - pt.Z
  105.               );
  106.           }
  107.         }
  108.         double angle =
  109.           JigUtils.ComputeAngle(
  110.             lastVertex, _tempPoint, refDir, _ucs
  111.           );
  112.         // Bulge is defined as tan of one fourth of included angle
  113.         // Need to double the angle since it represents the included
  114.         // angle of the arc
  115.         // So formula is: bulge = Tan(angle * 2 * 0.25)
  116.         double bulge = Math.Tan(angle * 0.5);
  117.         _pline.SetBulgeAt(_pline.NumberOfVertices - 2, bulge);
  118.       }
  119.       else
  120.       {
  121.         // Line mode. Need to remove last bulge if there was one
  122.         if (_pline.NumberOfVertices > 1)
  123.           _pline.SetBulgeAt(_pline.NumberOfVertices - 2, 0);
  124.       }
  125.       _pline.SetPointAt(
  126.         _pline.NumberOfVertices - 1, _tempPoint.Convert2d(_plane)
  127.       );
  128.       // Only when we have enough vertices
  129.       if (_pline.NumberOfVertices >2)
  130.       {
  131.         _pline.Closed = true;
  132.         AppendTheLoop();
  133.       }
  134.       if (!wd.RegenAbort)
  135.       {
  136.         wd.Geometry.Draw(_pline);
  137.         if (_pline.NumberOfVertices > 2)
  138.         {
  139.           _hat.EvaluateHatch(true);
  140.           if (!wd.RegenAbort)
  141.             wd.Geometry.Draw(_hat);
  142.           // Take it out, we will create a new one later
  143.           _hat.RemoveLoopAt(0);
  144.         }
  145.       }
  146.       return true;
  147.     }
  148.     protected override SamplerStatus Sampler(JigPrompts prompts)
  149.     {
  150.       var jigOpts = new JigPromptPointOptions();
  151.       jigOpts.UserInputControls =
  152.         (UserInputControls.NullResponseAccepted |
  153.          UserInputControls.NoNegativeResponseAccepted |
  154.          UserInputControls.GovernedByOrthoMode);
  155.       _isUndoing = false;
  156.       if (_pline.NumberOfVertices == 1)
  157.       {
  158.         // For the first vertex, just ask for the point
  159.         jigOpts.Message = "\nSpecify start point: ";
  160.       }
  161.       else if (_pline.NumberOfVertices > 1)
  162.       {
  163.         string msgAndKwds =
  164.           (_isArcSeg ?
  165.             "\nSpecify endpoint of arc or [Line/Undo]: " :
  166.             "\nSpecify next point or [Arc/Undo]: "
  167.           );
  168.         string kwds = (_isArcSeg ? "Line Undo" : "Arc Undo");
  169.         jigOpts.SetMessageAndKeywords(msgAndKwds, kwds);
  170.       }
  171.       else
  172.         return SamplerStatus.Cancel; // Should never happen
  173.       // Get the point itself
  174.       var res = prompts.AcquirePoint(jigOpts);
  175.       if (res.Status == PromptStatus.Keyword)
  176.       {
  177.         if (res.StringResult.ToUpper() == "ARC")
  178.           _isArcSeg = true;
  179.         else if (res.StringResult.ToUpper() == "LINE")
  180.           _isArcSeg = false;
  181.         else if (res.StringResult.ToUpper() == "UNDO")
  182.           _isUndoing = true;
  183.         return SamplerStatus.OK;
  184.       }
  185.       else if (res.Status == PromptStatus.OK)
  186.       {
  187.         // Check if it has changed or not (reduces flicker)
  188.         if (_tempPoint == res.Value)
  189.           return SamplerStatus.NoChange;
  190.         else
  191.         {
  192.           _tempPoint = res.Value;
  193.           return SamplerStatus.OK;
  194.         }
  195.       }
  196.       return SamplerStatus.Cancel;
  197.     }
  198.     public bool IsUndoing
  199.     {
  200.       get
  201.       {
  202.         return _isUndoing;
  203.       }
  204.     }
  205.     public void AddDummyVertex()
  206.     {
  207.       // Create a new dummy vertex... can have any initial value
  208.       _pline.AddVertexAt(
  209.         _pline.NumberOfVertices, new Point2d(0, 0), 0, 0, 0
  210.       );
  211.     }
  212.     public bool RemoveLastVertex()
  213.     {
  214.       // If there's a single vertex, don't attempt to remove the
  215.       // vertex: would cause a degenerate geometry error
  216.       // Returning false will tell the calling function to
  217.       // abort the transaction
  218.       if (_pline.NumberOfVertices == 1)
  219.         return false;
  220.       // Let's remove our dummy vertex
  221.       if (_pline.NumberOfVertices > 0)
  222.         _pline.RemoveVertexAt(_pline.NumberOfVertices - 1);
  223.       // And then check the type of the last segment
  224.       if (_pline.NumberOfVertices >= 2)
  225.       {
  226.         double blg = _pline.GetBulgeAt(_pline.NumberOfVertices - 2);
  227.         _isArcSeg = (blg != 0);
  228.         // We have to sync the hatch with the polyline
  229.         AppendTheLoop();
  230.       }
  231.       return true;
  232.     }
  233.     private void AppendTheLoop()
  234.     {
  235.       var ids = new ObjectIdCollection();
  236.       ids.Add(_pline.ObjectId);
  237.       _hat.Associative = true;
  238.       _hat.AppendLoop(HatchLoopTypes.Default, ids);
  239.     }
  240.     [CommandMethod("HATJIG")]
  241.     public static void RunHatchJig()
  242.     {
  243.       var doc = Application.DocumentManager.MdiActiveDocument;
  244.       var db = doc.Database;
  245.       var ed = doc.Editor;
  246.       // Create a transaction, as we're jigging
  247.       // db-resident objects
  248.       using (var tr = db.TransactionManager.StartTransaction())
  249.       {
  250.         var btr =
  251.           (BlockTableRecord)tr.GetObject(
  252.             db.CurrentSpaceId, OpenMode.ForWrite
  253.           );
  254.         var normal =
  255.           Vector3d.ZAxis.TransformBy(
  256.             ed.CurrentUserCoordinateSystem
  257.           );
  258.         // We will pass a plane to our jig, to help
  259.         // with UCS transformations
  260.         var plane = new Plane(Point3d.Origin, normal);
  261.         // We also pass a db-resident polyline
  262.         var pl = new Polyline();
  263.         pl.Normal = normal;
  264.         btr.AppendEntity(pl);
  265.         tr.AddNewlyCreatedDBObject(pl, true);
  266.         // And a db-resident hatch
  267.         var hat = new Hatch();
  268.         // Use a non-solid hatch pattern, to aid jigging
  269.         hat.SetHatchPattern(
  270.           HatchPatternType.PreDefined,
  271.           "ANGLE"
  272.         );
  273.         // But let's make it transparent, for fun
  274.         // Alpha value is Truncate(255 * (100-n)/100)
  275.         hat.ColorIndex = 1;
  276.         hat.Transparency = new Transparency(127);
  277.         // Add the hatch to the modelspace & transaction
  278.         var hatId = btr.AppendEntity(hat);
  279.         tr.AddNewlyCreatedDBObject(hat, true);
  280.         // And finally pass everything to the jig
  281.         var jig =
  282.           new HatchJig(
  283.             ed.CurrentUserCoordinateSystem, plane, pl, hat
  284.           );
  285.         while (true)
  286.         {
  287.           var res = ed.Drag(jig);
  288.           switch (res.Status)
  289.           {
  290.             // New point was added, keep going
  291.             case PromptStatus.OK:
  292.               jig.AddDummyVertex();
  293.               break;
  294.             // Keyword was entered
  295.             case PromptStatus.Keyword:
  296.               if (jig.IsUndoing)
  297.                 jig.RemoveLastVertex();
  298.               break;
  299.             // The jig completed successfully
  300.             case PromptStatus.None:
  301.               // You can remove this next line if you want
  302.               // the vertex being jigged to be included
  303.               if (jig.RemoveLastVertex())
  304.               {
  305.                 tr.Commit();
  306.               }
  307.               return;
  308.             // User cancelled the command
  309.             default:
  310.               // No need to erase the polyline & hatch, as
  311.               // the transaction will simply be aborted
  312.               return;
  313.           }
  314.         }
  315.       }
  316.     }
  317.   }
  318. }
Here’s the code in action, with none of the former visual artifacts:
Jigging a hatch
Thanks again, Holger! :-)
Update:
After a comment from Robbo, I went ahead and made the generated hatch associative to its boundary by adding a single line of code (“hat.Associative = true;”) once the hatch has been made db-resident. You can, of course, comment out this line to revert to the previous behaviour.
Update 2:
Well that’s strange. It turns out Holger’s code was already setting boundary associativity… not sure how I missed that. Anyway, I have addressed an issue pointed out in the comments (thanks, aks!) where if you hit the spacebar immediately after starting the jig, an exception gets thrown. This has now been fixed in the above code.
已领礼包: 1337个
发表于 2014-7-31 20:20:02 | 显示全部楼层
谢谢分享,长见识了。可惜不懂。
回复 支持 1 反对 0
GMT+8, 2026-11-3 14:08 , Processed in 0.541147 second(s), 34 queries , Gzip On.
