查看: 2000|回复: 0
[分享] How to enable/disable validation of your custom Options Tab
已领礼包: 859个
发表于 2014-8-1 19:30:59 | 显示全部楼层 |阅读模式
How to enable/disable validation of your custom Options Tab?                         By Philippe Leefsma
In those following posts Kean is showing how to add your own custom tab to the AutoCAD Options dialog:
Adding a custom tab to AutoCAD's options dialog using .NET - Part 1
Adding a custom tab to AutoCAD's options dialog using .NET - Part 2
What those samples aren’t showing, is how you can enable/disable the OK button, so the user will only be able to validate the dialog if his choices are matching your logic.
In order to achieve such a feature, a little hack relying on a couple of Win32 P/Invoked APIs is likely to be needed:
In the sample below, I am using FindWindowEx and EnableWindow to control the OK button, depending on the value provided in a textbox.
public partial class OptionsTabControl : UserControl
    private IntPtr _hWndOkBtn;
    [DllImport("user32.dll", SetLastError = true
    private static extern IntPtr FindWindowEx(
        IntPtr parentHandle,
        IntPtr childAfter,
        string className,
        string windowTitle);
    [return: MarshalAs(UnmanagedType
    static extern bool EnableWindow(
        IntPtr hWnd,
        bool bEnable);
    public OptionsTabControl()
        InitializeComponent();
        // Finds Options dialog
        IntPtr hWnd = FindWindowEx(IntPtr.Zero,
            IntPtr.Zero,
            "#32770",
            "Options");
        // Finds Ok button
        _hWndOkBtn = FindWindowEx(hWnd,
            IntPtr.Zero,
            "Button",
            "Ok");
        EnableWindow(_hWndOkBtn, false);
        tbValidation.Text = "Validate me ...";
    private void tbValidation_TextChanged(
        object sender,
        EventArgs e)
        if (tbValidation.Text.Length == 0)
        else
            bool enabled =
                (tbValidation.Text == "ADN rules!");
            EnableWindow(_hWndOkBtn, enabled);
Complete sample also attached.
AcadOptionsDlg.zip
GMT+8, 2026-11-3 13:20 , Processed in 0.414292 second(s), 28 queries , Gzip On.
