查看: 3355|回复: 8
[每日一码] 判断一个点是否在圆弧线上或在圆弧线的延长线上
已领礼包: 146个
发表于 2014-8-29 21:54:05 | 显示全部楼层 |阅读模式
  1. (defun inters_point&arc (c-centerpoint c-rad r-start-ang r-end-ang p-point1 show / return_result_lgx interangle-lgx)
  2. ;;;原创,编写:刘国新
  3. ;;;判断一个点是否在圆弧线上或在圆弧线的延长线上
  4. ;;;使用方法如下
  5. ;;;(inters_point&arc (cdr (assoc 10 (setq arc (entget (car (entsel "请选择圆弧\n")))))) (cdr (assoc 40 arc)) (cdr (assoc 50 arc))
  6. ;;;(cdr (assoc 51 arc)) (getpoint "请点选:") "show")
  7. (setq return_result_lgx nil)
  8. (if (= r-start-ang nil)
  9. (setq r-start-ang 0.0)
  10. )
  11. (if (= r-end-ang nil)
  12. (setq r-end-ang 0.0)
  13. )
  14. (setq r-start-ang (atof (angtos r-start-ang 0 8)))
  15. (setq r-end-ang (atof (angtos r-end-ang 0 8)))
  16. (if (and (= r-end-ang 0.0)(= r-start-ang 0.0))
  17. (setq r-end-ang 360.0)
  18. )
  19. (if (or (= c-centerpoint nil) (= c-rad nil) (= p-point1 nil))
  20. (setq return_result_lgx nil)
  21. (progn
  22. (if (equal c-rad (distance c-centerpoint p-point1) 0.0005)
  23. (progn
  24. (setq interangle-lgx (atof (angtos (angle c-centerpoint p-point1) 0 8)))
  25. (if (< r-end-ang r-start-ang)
  26. (if (or (<= interangle-lgx r-end-ang)(>= interangle-lgx r-start-ang))
  27. (progn
  28. (if (/= show nil)
  29. (princ "\n点在圆弧线上!!!\n")
  30. )
  31. (setq return_result_lgx 1)
  32. )
  33. (progn
  34. (if (/= show nil)
  35. (princ "\n点在圆弧线的延长线上!!!\n")
  36. )
  37. (setq return_result_lgx 2)
  38. )
  39. )
  40. (if (and (>= interangle-lgx r-start-ang)(<= interangle-lgx r-end-ang))
  41. (progn
  42. (if (/= show nil)
  43. (princ "\n点在圆弧线上!!!\n")
  44. )
  45. (setq return_result_lgx 1)
  46. )
  47. (progn
  48. (if (/= show nil)
  49. (princ "\n点在圆弧线的延长线上!!!\n")
  50. )
  51. (setq return_result_lgx 2)
  52. )
  53. )
  54. )
  55. )
  56. (progn
  57. (if (/= show nil)
  58. (princ "\n点不在圆弧线上或圆弧线的延长线上!!!\n")
  59. )
  60. (setq return_result_lgx nil)
  61. )
  62. )
  63. )
  64. )
  65. (princ)
  66. return_result_lgx
  67. )
已领礼包: 604个
发表于 2014-8-30 00:22:52 来自手机 | 显示全部楼层
感觉复杂了
请指教。  详情 回复 发表于 2014-8-30 07:56
已领礼包: 12482个
发表于 2014-8-30 07:38:52 | 显示全部楼层
  1. (defun orarc (pt arcen)
  2. (setq ent (entget arcen))
  3. (setq r (cdr(assoc 40 ent)))
  4. (setq pc (cdr(assoc 10 ent)))
  5. (setq dis (distance pt pc))
  6. (if (equal r dis 1e-6)
  7.   (if (osnap pt "NEAR")
  8.    (princ "点在弧上")
  9.    (princ "点在延长线上")
  10.   )
  11.   (princ "点不在弧上")
  12. )
  13. )
  14. ;用法:(orarc (getpoint) (car(entsel)))
不好意思,没有分析你的代码其中(osnap pt "NEAR")是会误判的呀,如果你的点不在圆弧上但在圆弧线的延长线上,但你的点正处于其它图素上,就会误判呀.  详情 回复 发表于 2014-8-30 12:28
这位兄弟,我的使用方法中的提示可能给你一些误解,我这个程序只是计算,在完全没有圆弧和点的情况下,只是给定各个参数来判断的。当然你可以根据给定的各个参数先画出圆弧再来用你的这个代码也是可以的。(我  详情 回复 发表于 2014-8-30 08:04
已领礼包: 146个
 楼主| 发表于 2014-8-30 07:56:17 | 显示全部楼层
请指教。
已领礼包: 146个
 楼主| 发表于 2014-8-30 08:04:31 | 显示全部楼层
      这位兄弟,我的使用方法中的提示可能给你一些误解,我这个程序只是计算,在完全没有圆弧和点的情况下,只是给定各个参数来判断的。当然你可以根据给定的各个参数先画出圆弧再来用你的这个代码也是可以的。(我的使用方法中的提示是想提示如何获得参数?)
已领礼包: 146个
 楼主| 发表于 2014-8-30 12:28:06 | 显示全部楼层
发表于 2016-12-7 16:49:57 | 显示全部楼层
用点到圆心的距离是否等于半径 不就能判断出来吗?
已领礼包: 1094个
发表于 2021-11-6 03:22:45 | 显示全部楼层
感谢分享判断一个点是否在圆弧线上或在圆弧线的延长线上
发表于 2021-11-7 15:47:22 | 显示全部楼层
通过点到圆心的距离是否等于半径即可判断了
GMT+8, 2026-11-3 01:46 , Processed in 0.837841 second(s), 50 queries , Gzip On.
