查看: 3534|回复: 2
[求助] image...是不是不能设置相对路径...怎么不认??
已领礼包: 2476个
发表于 2014-9-1 12:15:59 | 显示全部楼层 |阅读模式
用大师的程序转绝对路径为相对...居然不认...拜托高手指点下...XR..没问题...IM不认...这是为什么??
(defun LM:XRef:Full->Relative ( dir path / p q ) (setq dir (vl-string-right-trim "\\" dir))
  (cond
    ( (and
        (setq p (vl-string-position 58  dir))
        (setq q (vl-string-position 58 path))
        (not (eq (strcase (substr dir 1 p)) (strcase (substr path 1 q))))
      path
    ( (and
        (setq p (vl-string-position 92  dir))
        (setq q (vl-string-position 92 path))
      (LM:Xref:Full->Relative (substr dir (+ 2 p)) (substr path (+ 2 q)))
    ( (and
        (eq (strcase dir) (strcase (substr path 1 q)))
      (strcat ".\\" (substr path (+ 2 q)))
    ( (eq "" dir)
      path
    ( (setq p (vl-string-position 92 dir))
      (LM:Xref:Full->Relative (substr dir (+ 2 p)) (strcat "..\\" path))
    ( (LM:Xref:Full->Relative "" (strcat "..\\" path)) )
已领礼包: 859个
发表于 2014-9-1 12:37:15 来自手机 | 显示全部楼层
这个是xref,你说的是image
对呀...改路径不都一样吗...??  详情 回复 发表于 2014-9-1 12:39
已领礼包: 2476个
 楼主| 发表于 2014-9-1 12:39:11 | 显示全部楼层
csharp 发表于 2014-9-1 12:37
这个是xref,你说的是image
对呀...改路径不都一样吗...??
GMT+8, 2026-11-6 11:15 , Processed in 0.440821 second(s), 34 queries , Gzip On.
