查看: 2838|回复: 2
[分享] 点排序
发表于 2014-9-4 17:17:32 | 显示全部楼层 |阅读模式
通常三维点排序按X、Y简单的Linq语句为
            var q =
                from pt in pts
                orderby pt.X, pt.Y
                select pt;
但是这样没有考虑容差,使用下面的语句也许好些,考虑容差为1e-6
            var q =
                from pt in pts
                orderby Math.Round(pt.X, 6), Math.Round(pt.Y, 6)
                select pt;
下面的代码是按X坐标先分组:
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Windows.Forms;
  9. namespace WindowsFormsApplication1
  10. {
  11.     public partial class Form1 : Form
  12.     {
  13.         public Form1()
  14.         {
  15.             InitializeComponent();
  16.         }
  17.         private void button1_Click(object sender, EventArgs e)
  18.         {
  19.             List<Point3d> pts =
  20.                 new List<Point3d>
  21.                 {
  22.                     new Point3d(10, 10, 0),
  23.                     new Point3d(10, 10.001, 0),
  24.                     new Point3d(20, 9.999, 0),
  25.                     new Point3d(29.999, 10, 0),
  26.                     new Point3d(32.005, 8, 0)
  27.                 };
  28.             var q =
  29.                 from pt in pts
  30.                 group pt by Math.Round(pt.X, 1, MidpointRounding.AwayFromZero);
  31.             foreach (var ps in q)
  32.             {
  33.                 string s = ps.Key.ToString() + "\r\n";
  34.                 s += "{";
  35.                 foreach (var p in ps)
  36.                 {
  37.                     s += p.ToString() + ";";
  38.                 }
  39.                 s += "}\r\n";
  40.                 textBox1.Text += s;
  41.             }
  42.         }
  43.     }
  44.     class Point3d
  45.     {
  46.         public double X, Y, Z;
  47.         public Point3d(double x, double y, double z)
  48.         {
  49.             X = x;
  50.             Y = y;
  51.             Z = z;
  52.         }
  53.         public override string ToString()
  54.         {
  55.             return X + "," + Y + "," + Z;
  56.         }
  57.     }
  58. }
已领礼包: 859个
发表于 2014-9-4 18:00:20 | 显示全部楼层
就用过 pts.OrderBy(p->p.X).ThenBy(p->p.Y).ToList
其它的太高深
 楼主| 发表于 2014-9-5 08:29:01 来自手机 | 显示全部楼层
orderby...thenby...对应的linq语句就是第一条
GMT+8, 2026-11-3 10:19 , Processed in 0.469495 second(s), 35 queries , Gzip On.
