查看: 3128|回复: 6
[每日一码] 过一点相切于直线端点
已领礼包: 146个
发表于 2014-9-5 12:33:41 | 显示全部楼层 |阅读模式
已知通过一点相切于一直线的一端点求出圆弧中心点,半径,起始角
  1. (defun tangarctoline (linept1 linept2 arcpt3 / lengtha lengthb lengthc cosa_lgx cal_angle arc_r refrence-point arc_centerpoint
  2.          arc_star-ang arc_end-ang)
  3. ;;;原创,编写:刘国新
  4. ;;;已知通过一点相切于一直线的一端点求出圆弧中心点,半径,起始角,终止角
  5. (if (or (= (angle linept1 linept2)(angle linept1 arcpt3))(= (angle linept1 linept2)(angle linept2 arcpt3)))
  6. nil
  7. (progn
  8. (setq lengtha (distance linept2 arcpt3))
  9. (setq lengthb (distance linept1 linept2))
  10. (setq lengthc (distance linept1 arcpt3))
  11. (if (< (max lengthc lengtha lengthb)(- (+ lengthc lengtha lengthb) (max lengthc lengtha lengthb)))
  12. (if (or (= lengthc 0) (= lengtha 0) (= lengthb 0))
  13. (princ "\n请输入正确的数值!\n")
  14. (progn
  15. (setq cosa_lgx (/ (- (+ (* lengtha lengtha)(* lengthb lengthb))(* lengthc lengthc))
  16.                 (* lengtha lengthb 2)))
  17. (setq cosa_lgx (- (/ pi 2.0) (atan (/ cosa_lgx (sqrt (- 1.0 (* cosa_lgx cosa_lgx)))))))
  18. )
  19. )
  20. (princ "\n请输入正确的数值!\n")
  21. )
  22. (if (> cosa_lgx (* pi 0.5))
  23. (setq cal_angle (- cosa_lgx (* pi 0.5)))
  24. (setq cal_angle (- (* pi 0.5) cosa_lgx))
  25. )
  26. (setq arc_r (/ (/ lengtha 2.0)(cos cal_angle)))
  27. (setq refrence-point (inters arcpt3 (polar arcpt3 (+ (angle linept1 linept2) (* pi 0.5)) 5.0) linept1 linept2 nil))
  28. (if (and (>= (angle linept1 linept2) (* pi 0.5))(< (angle linept1 linept2) (* pi 1.5)))
  29. (progn
  30. (if (> (angle linept1 linept2)(angle refrence-point arcpt3))
  31. (progn
  32. (setq arc_centerpoint (polar linept2 (- (angle linept1 linept2) (* pi 0.5)) arc_r))
  33. (setq arc_star-ang (angle arc_centerpoint arcpt3))
  34. (setq arc_end-ang (angle arc_centerpoint linept2))
  35. )
  36. (progn
  37. (setq arc_centerpoint (polar linept2 (+ (angle linept1 linept2) (* pi 0.5)) arc_r))
  38. (setq arc_star-ang (angle arc_centerpoint linept2))
  39. (setq arc_end-ang (angle arc_centerpoint arcpt3))
  40. )
  41. )
  42. )
  43. (if (> (angle linept2 linept1)(angle refrence-point arcpt3))
  44. (progn
  45. (setq arc_centerpoint (polar linept2 (+ (angle linept1 linept2) (* pi 0.5)) arc_r))
  46. (setq arc_star-ang (angle arc_centerpoint linept2))
  47. (setq arc_end-ang (angle arc_centerpoint arcpt3))
  48. )
  49. (progn
  50. (setq arc_centerpoint (polar linept2 (- (angle linept1 linept2) (* pi 0.5)) arc_r))
  51. (setq arc_star-ang (angle arc_centerpoint arcpt3))
  52. (setq arc_end-ang (angle arc_centerpoint linept2))
  53. )
  54. )
  55. )
  56. (list arc_centerpoint arc_r arc_star-ang arc_end-ang)
  57. )
  58. )
  59. )
  60. (defun c:tarc_lgx (/ cm_lgx ucs_lgx os_lgx arcpt3 ss_lgx start_point end_point linept1 linept2 arc-item loop operate temp result_lgx
  61.       arc_centerpoint arc_r arc_star-ang arc_end-ang myms_lgx )
  62. ;;;原创,编写:刘国新
  63. ;;;已知通过一点相切于一直线的一端点画圆弧
  64. (setq cm_lgx (getvar "cmdecho"))
  65. (setvar "cmdecho" 0)
  66. (command "undo" "BE")
  67. (setq ucs_lgx (getvar "ucsorg"))
  68. (command "ucs" "w")
  69. (setq os_lgx (getvar "osmode"))
  70. (setq arcpt3 (getpoint "\n选取点:"))
  71. (setq ss_lgx (entsel "\n选择一条要相切的直线:"))
  72. (setq start_point (cdr (assoc 10 (entget (car ss_lgx)))))
  73. (setq end_point (cdr (assoc 11 (entget (car ss_lgx)))))
  74. (if (< (distance (cadr ss_lgx) start_point)(distance (cadr ss_lgx) end_point))
  75. (progn
  76. (setq linept1 end_point)
  77. (setq linept2 start_point)
  78. )
  79. (progn
  80. (setq linept1 start_point)
  81. (setq linept2 end_point)
  82. )
  83. )
  84. (setq arc-item nil)
  85. (setq loop t)
  86. (while loop
  87. (if arc-item
  88. (command "erase" (vlax-vla-object->ename arc-item)  "")
  89. )
  90. (if (or (= operate "R")(= operate "r"))
  91. (progn
  92. (setq temp arc_end-ang)
  93. (setq arc_end-ang arc_star-ang)
  94. (setq arc_star-ang temp)
  95. )
  96. (progn
  97. (if (or (= operate "D")(= operate "d"))
  98. (progn
  99. (setq temp linept2)
  100. (setq linept2 linept1)
  101. (setq linept1 temp)
  102. )
  103. )
  104. (setq result_lgx (tangarctoline linept1 linept2 arcpt3))
  105. (setq arc_centerpoint (car result_lgx))
  106. (setq arc_r (cadr result_lgx))
  107. (setq arc_star-ang (caddr result_lgx))
  108. (setq arc_end-ang (nth 3 result_lgx))
  109. )
  110. )
  111. (setvar "osmode" 0)
  112. (setq myms_lgx (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
  113. (setq arc-item (vlax-invoke  myms_lgx 'Addarc arc_centerpoint arc_r arc_star-ang arc_end-ang))
  114. (setq operate (getstring "反转相切[R] ,反转端点[D]"))
  115. (if (or (= operate "R")(= operate "r")(= operate "D")(= operate "d"))
  116. (setq loop t)
  117. (setq loop nil)
  118. )
  119. )
  120. (setvar "osmode" os_lgx)
  121. (command "ucs" "n" ucs_lgx)
  122. (command "undo" "E")
  123. (setvar "cmdecho" cm_lgx)
  124. (princ)
  125. )
,终止角
已领礼包: 859个
发表于 2014-9-5 12:42:45 来自手机 | 显示全部楼层
可以简化
请不吝赐教  详情 回复 发表于 2014-9-5 18:45
已领礼包: 146个
 楼主| 发表于 2014-9-5 18:45:54 | 显示全部楼层
请不吝赐教
没有写完,供参考  详情 回复 发表于 2014-9-5 19:23
已领礼包: 859个
发表于 2014-9-5 19:23:30 | 显示全部楼层
没有写完,供参考,弦中垂线与过线端点的垂线两者交点即圆心,剩下就是判断起始角谁大小了
  1. (defun lnarc (p ln / midp sp ep an _pi2 p1 p2 pc1 pc2)
  2.   (defun midp (p1 p2)
  3.     (mapcar '(lambda (x1 x2)
  4.                (/ (+ x1 x2) 2)
  5.              )
  6.             p1
  7.             p2
  8.     )
  9.   )
  10.   (setq        sp   (vlax-curve-getstartpoint ln)
  11.         ep   (vlax-curve-getendpoint ln)
  12.         an   (angle sp ep)
  13.         _pi2 (/ pi 2)
  14.         p1   (midp p sp)
  15.         p2   (midp p ep)
  16.         pc1  (inters sp
  17.                      (polar sp (+ an _pi2) 1.)
  18.                      p1
  19.                      (polar p1 (+ (angle p sp) _pi2) 1.)
  20.                      nil
  21.              )
  22.         pc2  (inters ep
  23.                      (polar ep (+ an _pi2) 1.)
  24.                      p1
  25.                      (polar p2 (+ (angle p ep) _pi2) 1.)
  26.                      nil
  27.              )
  28.   )
  29. )
谢谢大师,好思路!  详情 回复 发表于 2014-9-5 20:12
已领礼包: 146个
 楼主| 发表于 2014-9-5 20:12:11 | 显示全部楼层
谢谢大师,好思路!
已领礼包: 1094个
发表于 2021-7-5 00:04:08 | 显示全部楼层
感谢楼主分享过一点相切于直线端点!
已领礼包: 756个
发表于 2021-7-5 08:16:39 | 显示全部楼层
感谢楼主和大师分享源码!
GMT+8, 2026-11-3 15:16 , Processed in 0.509051 second(s), 45 queries , Gzip On.
