查看: 2156|回复: 0
[求助] VBA编程求教
发表于 2014-9-23 09:46:34 | 显示全部楼层 |阅读模式
各位前辈:我抄了如下一个已知圆心半径 起点终点的代码。但是不知道它放在VB的窗口代码中 类代码中还是块代码中请指点。谢谢
我在userform1 中 Option Explicit 写下
Public Function AddArcByCenterStartEndPoint(ByVal centerpoint As Variant, ByVal startPoint As Variant, ByVal endPoint As Variant) As AcadArc
    Debug.Assert (VarType(startPoint) = vbArray + vbDouble)
    Debug.Assert (VarType(centerpoint) = vbArray + vbDouble)
    Debug.Assert (VarType(endPoint) = vbArray + vbDouble)
   Dim radius1 As Double, radius2 As Double
   radius1 = math.getdistancebetween2Point(centerpoint, startPoint)
     radius2 = math.getdistancebetween2Point(centerpoint, endPoint)
     Debug.Assert (Abs(radius1 - radius2) < 0.0000001)
    ' 计算起始和终止角度
    Dim startAngle As Double, endAngle As Double
    startAngle = ThisDrawing.Utility.AngleFromXAxis(centerpoint, startPoint)
    endAngle = ThisDrawing.Utility.AngleFromXAxis(centerpoint, endPoint)
    Set AddArcByCenterStartEndPoint = AddArc(centerpoint, radius, startAngle, endAngle)
End Function‘ 这段代码放哪里的?
在click事件中写下
Dim startPoint(0 To 2) As Double, endPoint(0 To 2), centerpoint(0 To 2) As Double
startPoint(0 )=。。。。
。。。。。’'赋值
AddArcByCenterStartEndPoint(centerpoint,startpoint,endpoint)'引 用函数的时候出现红字
请问这是为何 该如何解决?谢谢
GMT+8, 2026-11-25 03:14 , Processed in 0.212985 second(s), 8 queries , Gzip On, File On.
