查看: 1538|回复: 2
[他山之石] Delete all solid hatches
已领礼包: 3199个
发表于 2014-9-26 10:10:18 | 显示全部楼层 |阅读模式
  1. (defun c:delsolhat ( / d )
  2.     (vlax-for b (vla-get-blocks (setq d (vla-get-activedocument (vlax-get-acad-object))))
  3.         (if (= :vlax-false (vla-get-isxref b))
  4.             (vlax-for o b
  5.                 (if (and (= "AcDbHatch" (vla-get-objectname o))
  6.                          (= "SOLID" (strcase (vla-get-patternname o)))
  7.                          (vlax-write-enabled-p o)
  8.                     )
  9.                     (vla-delete o)
  10.                 )
  11.             )
  12.         )
  13.     )
  14.     (vla-regen d acallviewports)
  15.     (princ)
  16. )
  17. (vl-load-com) (princ)
评分
参与人数 1D豆 +5 收起 理由
xshrimp + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2014-9-26 10:47:35 | 显示全部楼层
用这么长吗
(command ".erase" (ssget "x" '((0 . "hatch")(2 . "SOLID"))) "")
楼主的是块内的实体填充也删除的.  发表于 2014-9-26 18:47
GMT+8, 2026-11-6 08:15 , Processed in 0.429436 second(s), 32 queries , Gzip On.
