查看: 2934|回复: 2
[教学] XDGE几何库应用(24)---曲线打断
发表于 2014-10-3 16:33:38 | 显示全部楼层 |阅读模式
研究了几天几何库,试着写个教学,望高手指正
用XDGE几何库实现曲线打断(主要功能)的代码
一、单点打断
  1. (defun c:tt1()
  2.     (if (and (setq e (xdrx_entsel "\n拾取要单点打断的曲线<退出>:" '((0 . "*LINE,ARC,CIRCLE,ELLIPSE"))))
  3.              (setq ge1 (xdge::constructor (car e)))
  4.              (setq ge2 (xdge::copy ge1))
  5.              (setq intval (xdge::getpropertyvalue ge1 "getInterval"))
  6.         )
  7.       (progn
  8.           (setq intval (car intval)
  9.                 bounds (xdge::getpropertyvalue intval "getBounds")
  10.                 lower (car bounds)
  11.                 upper (cadr bounds)
  12.                 param (xdge::getpropertyvalue ge1 "paramOf" (cadr e))
  13.                 intval1 (xdge::constructor "AcGeInterval" lower param)
  14.                 intval2 (xdge::constructor "AcGeInterval" param upper)
  15.           )
  16.           (if (xdge::setpropertyvalue ge1 "setInterval" intval1);;设置曲线1的起始、结束参数
  17.              (xdge::entity:make ge1)
  18.           )
  19.           (if (xdge::setpropertyvalue ge2 "setInterval" intval2);;设置曲线2的起始、结束参数
  20.              (xdge::entity:make ge2)
  21.           )
  22.           (xdrx_entity_delete (car e))
  23.           (xdge::free)
  24.       )
  25.     )
  26.     (princ)
  27. )
一、两点打断
  1. (defun c:tt2()
  2.     (if (and (setq e (xdrx_entsel "\n拾取要两点打断的曲线<退出>:" '((0 . "*LINE,ARC,CIRCLE,ELLIPSE"))))
  3.              (setq p1 (getpoint "\n第一点<退出>:"))
  4.              (setq p2 (getpoint p1 "\n第二点<退出>:"))
  5.              (setq ge1 (xdge::constructor (car e)))
  6.              (setq ge2 (xdge::copy ge1)) ;;复制一个
  7.              (setq intval (xdge::getpropertyvalue ge1 "getInterval"))
  8.              (setq param1 (xdge::getpropertyvalue ge1 "paramOf" p1))
  9.              (setq param2 (xdge::getpropertyvalue ge1 "paramOf" p2))
  10.         )
  11.       (progn
  12.           (setq pa1 (min param1 param2)
  13.                 pa2 (max param1 param2)
  14.                 intval (car intval)
  15.                 bounds (xdge::getpropertyvalue intval "getBounds")
  16.                 lower (car bounds)
  17.                 upper (cadr bounds)
  18.                 intval1 (xdge::constructor "AcGeInterval" lower pa1)
  19.                 intval2 (xdge::constructor "AcGeInterval" pa2 upper)
  20.           )
  21.           (if (and (xdge::setpropertyvalue ge1 "setInterval" intval1);;设置曲线1的起始、结束参数
  22.                    (> (xdge::getpropertyvalue ge1 "Length") 0) ;;长度大于0生成
  23.               )
  24.              (xdge::entity:make ge1)
  25.           )
  26.           (if (and (xdge::setpropertyvalue ge2 "setInterval" intval2);;设置曲线2的起始、结束参数
  27.                    (> (xdge::getpropertyvalue ge2 "Length") 0);;长度大于0生成
  28.               )
  29.              (xdge::entity:make ge2)
  30.           )
  31.           (xdrx_entity_delete (car e))
  32.           (xdge::free)
  33.       )
  34.     )
  35.     (princ)
  36. )
两个程序的主要原理都是建立曲线几何模型,然后拷贝复制一个,然后通过设置两个GE曲线的起始、终止参数来实现打断的,主要的几何库打断函数用的是 (xdge::setpropertyvalue ge "setInterval" intval)
本帖被以下淘专辑推荐:
发表于 2014-10-3 18:23:21 | 显示全部楼层
Interval 对 spline 好像不行,闭合的更不行,其他没问题
发表于 2020-11-22 10:40:16 | 显示全部楼层
学习学习!!
GMT+8, 2026-11-22 09:51 , Processed in 0.422159 second(s), 15 queries , Gzip On, File On.
