查看: 3188|回复: 7
[他山之石] Autodesk Slide Library Manager Application ( SLM )
已领礼包: 859个
发表于 2014-10-5 19:55:45 来自手机 | 显示全部楼层 |阅读模式
Slm is a utility which helps you to create, edit, and manage AutoCAD slide libraries. It can read any version of AutoCAD slides, or slide libraries. It can also read any slide format (platform dependent such as UNIX, MAC, INTEL), and convert them into PNG transparent images.
Download the installer herehttps://github.com/ADN-DevTech/A ... anager.msi?raw=true
The WPF Slide Control
The ‘Slide' control is a WPF control which displays slides under Windows platforms. It can be used by any other WPF application. It exposes three objects which are:
SlideObject - which gives you access to 'slides'. I.e. SLD
SlideLibObject - which gives you access to Slide Libraries. I.e. SLB
SlideCtrl - the control itself
Install using NuGet:
Create a Wpf Application
Project -> Manage NuGet Packages...
Search and Install 'AutoCAD Slide Control' package
or if the package does not show use the console
Tools -> NuGet Package Manager -> Package Manager Console
On the console, enter: Install-Package AutoCAD.Slide.Control
SlideObject
This class gives you access to 'slide' object.
Add the following line to your code
using Autodesk.AutoCAD.Windows;
You can now use the SlideObject class.
Example
    SlideObject sld = new SlideObject(@"MySlide.sld");
    BitmapImage renderBitmap = sld.Export();
    PngBitmapEncoder encoder = new PngBitmapEncoder();
    encoder.Frames.Add(BitmapFrame.Create(renderBitmap)); // Push the rendered bitmap to it
    using (FileStream outStream = new FileStream(@"MySlide.png", FileMode.Create)) // Create a file stream for saving image
        encoder.Save(outStream);
SlideLibObject
This class gives you access to 'slide library' object.
You can now use the SlideLibObject class.
Example
    SlideLibObject slb = new SlideLibObject(@"acad.slb");
    SlideObject sld = slb._Slides["ZIGZAG"];
    sld.SaveAs("ZIGZAG.sld");
is equivalent to
    SlideObject sld = SlideLibObject.LoadSlideFromLibrary(@"acad.slb", "ZIGZAG");
SlideCtrl
This control allows you to display AutoCAD Slides in a WPF application.
Add the following line to your WPF Window xaml
      xmlns:SlideCtrlNS="clr-namespace:Autodesk.AutoCAD.Windows;assembly=SlideCtrl"
Insert the control in you window like this
      <SlideCtrlNS:SlideCtrl x:Name="preview" />
Example
<Window x:Class="WpfApplication1.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        Title="MainWindow" Height="350" Width="525"
    <Grid>
        <SlideCtrlNS:SlideCtrl x:Name="preview" SlideFileName="MySlide.sld" />
    </Grid>
</Window>
    preview.Slide = sld;
or
    preview.SlideFileName = @"MySlide.sld";
License
Autodesk Slide Control / Slide Library Manager Application are licensed under the terms of the MIT License. Please see the LICENSE file for full details.
Written by
Cyrille Fauvel
Autodesk Developer Network
Autodesk Inc.
http://www.autodesk.com/adn
已领礼包: 3199个
发表于 2014-10-5 20:34:05 | 显示全部楼层
真是及时雨啊,之前论坛下载的cadslide v1.2 号称汉化破解版,根本不是破解版,用了一段时间就用不了,显示30天试用期已到,这是官网地址:http://www.etecad.com ,最新版cadslide v1.5早都有了,还有Etecad File Manager 要149美刀,Autocad Slide Manager 35美刀,网上的crack keygen patch 都搜不到,以前用google还可以搜到一些crack, 百度不指望,折腾了一下午,都没找到一个能用的
不知道大师的这个是不是试用版?
已领礼包: 3199个
发表于 2014-10-5 20:45:59 | 显示全部楼层
不支持在虚拟机上安装,显示处理器类型不被支持,win8.1 上安装总是自动关闭,可能还是不兼容,这个算不错,其它类型的都收费,比如,上贴说的那个,还有slideman也是50美刀
已领礼包: 859个
 楼主| 发表于 2014-10-5 21:11:49 来自手机 | 显示全部楼层
要.Net 4.5 有源码(C#)可以自己编译
自己编译了一个,建立slb只要用资源管理器将sld拖入即可
感觉速度不快,但是独立程序,免费
嗯,如果只是单纯的建立slb可以不用任何工具,我用批处理 slidelib lib< mylist.txt, 用工具只是方便预览与删减  详情 回复 发表于 2014-10-5 21:42
已领礼包: 3199个
发表于 2014-10-5 21:42:02 | 显示全部楼层
嗯,如果只是单纯的建立slb可以不用任何工具,我用批处理 slidelib lib< mylist.txt, 用工具只是方便预览与删减 sshot-5.png slideman.png
这个管理还是很方便的  详情 回复 发表于 2014-10-6 16:49
已领礼包: 859个
 楼主| 发表于 2014-10-6 16:49:03 | 显示全部楼层
lucas3 发表于 2014-10-5 21:42
嗯,如果只是单纯的建立slb可以不用任何工具,我用批处理 slidelib lib< mylist.txt, 用工具只是方便预 ...
这个管理还是很方便的
大师: 这个好像不能在64位WIN10上用? 32位WIN7是可以用的。 请教大师有没有在64位WIN10上用的此类幻灯管理小程序? 谢谢  详情 回复 发表于 2020-1-6 10:12
发表于 2014-10-6 18:33:13 来自手机 | 显示全部楼层
有莫名其妙退出现象
已领礼包: 6881个
发表于 2020-1-6 10:12:45 | 显示全部楼层
csharp 发表于 2014-10-6 16:49
这个管理还是很方便的
大师:
这个好像不能在64位WIN10上用?
32位WIN7是可以用的。
谢谢
GMT+8, 2026-11-4 06:20 , Processed in 0.747424 second(s), 51 queries , Gzip On.
