查看: 2542|回复: 1
[分享] Autodesk Slide Library Manager Application ( SLM )
已领礼包: 859个
发表于 2014-10-5 20:25:17 | 显示全部楼层 |阅读模式
.Net 4.5
https://github.com/ADN-DevTech/AutoCAD-Slide-Library-Manager
Slide Library Manager Application - AutoCAD DevBlogSep 2, 2014
By Virupaksha Aithal
A D N senior manager Cyrille Fauvel write a Slide Library Manager Application for AutoCAD slides/slide Libraries. I thought of sharing the same with all. Please refer the github link https://github.com/ADN-DevTech/AutoCAD-Slide-Library-Manager . This Application is a utility which helps you to create, edit, and manage AutoCAD slide libraries. It can read any version of AutoCAD slides, or slide libraries. It can also read any slide format, and convert them into PNG transparent images.
The Github sample has also has a WPF Slide Control. This ‘Slide' control is a WPF control which displays slides under Windows platforms. This WPF control can be included in any WPF project using NuGet. Please refer README section the Github (https://github.com/ADN-DevTech/AutoCAD-Slide-Library-Manager/blob/master/README.md ).
已领礼包: 112个
发表于 2015-10-10 14:31:08 | 显示全部楼层
马克,谢谢楼主分享
GMT+8, 2026-11-3 18:27 , Processed in 0.429916 second(s), 33 queries , Gzip On.
