查看: 2121|回复: 0
[分享] Table 拾取点处单元格
已领礼包: 859个
发表于 2014-10-8 16:29:47 | 显示全部楼层 |阅读模式
  1.         [CommandMethod("test2")]
  2.         public void Test02()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Editor ed = doc.Editor;
  6.             Database db = doc.Database;
  7.             Transaction tr = db.TransactionManager.StartTransaction();
  8.             PromptPointResult ppr = ed.GetPoint("Test Point: ");
  9.             if (ppr.Status != PromptStatus.OK) return;
  10.             PromptEntityResult per = ed.GetEntity("Pick Table: ");
  11.             if (per.Status != PromptStatus.OK) return;
  12.             using (tr)
  13.             {
  14.                 try
  15.                 {
  16.                     Point3d pnt = ppr.Value;
  17.                     ObjectId id = per.ObjectId;
  18.                     Table table = (Table)id.GetObject(OpenMode.ForRead);
  19.                     FullSubentityPath[] vv = new FullSubentityPath[] { };
  20.                     var p = Application.GetSystemVariable("VIEWDIR");
  21.                     Point3d pp = (Point3d)p;
  22.                     Vector3d vec = pp.GetAsVector();
  23.                     TableHitTestInfo ww = table.Select(pnt, vec, table.Direction, false, false, vv);
  24.                     int row = ww.Row;
  25.                     int column = ww.Column;
  26.                     Cell cell = table.Cells[row, column];
  27.                     int ic = cell.Contents.Count;
  28.                     for (int i = 0; i < ic; i++)
  29.                     {
  30.                         string str = cell.Contents[i].TextString;
  31.                         ed.WriteMessage("\nRow = {0}, Column = {1}, Text = {2}", row.ToString(), column.ToString(), str);
  32.                     }
  33.                     tr.Commit();
  34.                 }
  35.                 catch (Exception)
  36.                 {
  37.                     throw;
  38.                 }
  39.             }
  40.         }
GMT+8, 2026-11-3 07:24 , Processed in 0.381571 second(s), 28 queries , Gzip On.
