查看: 1722|回复: 0
[分享] Copy extension dictionary
已领礼包: 859个
发表于 2014-10-15 15:34:24 | 显示全部楼层 |阅读模式
Copy extension dictionary                         By Virupaksha Aithal
Below command shows the procedure to copy the extension dictionary entries from one entity to another. A special logic is placed at the end to set the names of the dictionary same as source object as “DeepCloneObjects” copy the objects with different names in target entity.
[CommandMethod("copyExtDic")]
public void copyExtDic()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    PromptEntityResult surRes =
                ed.GetEntity("Select source entity");
    if (surRes.Status != PromptStatus.OK)
        return;
    PromptEntityResult tarRes =
                ed.GetEntity("Select target entity");
    if (tarRes.Status != PromptStatus.OK)
        return;
    ObjectIdCollection ids = new ObjectIdCollection();
    ObjectId tarId = ObjectId.Null;
    ObjectId surId = ObjectId.Null;
    using (Transaction tr =
            db.TransactionManager.StartTransaction())
        DBObject dbObj = tr.GetObject(surRes.ObjectId,
                                       OpenMode.ForRead);
        surId = dbObj.ExtensionDictionary;
        if (surId != ObjectId.Null)
            DBDictionary dbExt =
                      (DBDictionary)tr.GetObject(surId,
                                    OpenMode.ForRead);
            foreach (DBDictionaryEntry entry in dbExt)
                ids.Add(entry.Value);
        else
            ed.WriteMessage("No dictionary to copy");
            return;
        //find if entiy has
        DBObject target = tr.GetObject(tarRes.ObjectId,
                                          OpenMode.ForRead);
        tarId = target.ExtensionDictionary;
        if (tarId == ObjectId.Null)
            target.UpgradeOpen();
            target.CreateExtensionDictionary();
        tr.Commit();
    IdMapping mapping = new IdMapping();
    db.DeepCloneObjects(ids, tarId, mapping, false);
         (DBDictionary)tr.GetObject(surId, OpenMode.ForRead);
        DBDictionary dbTarg =
            (DBDictionary)tr.GetObject(tarId, OpenMode.ForWrite);
        foreach (IdPair pair in mapping)
            DBObject target = tr.GetObject(pair.Value,
                                              OpenMode.ForRead);
            dbTarg.SetName(
                dbTarg.NameAt(pair.Value),
                dbExt.NameAt(pair.Key));
        tr.Commit();
GMT+8, 2026-11-3 07:36 , Processed in 0.609939 second(s), 28 queries , Gzip On.
