查看: 1752|回复: 0
[分享] Zoom to a Window in Editor using CommandASync
已领礼包: 859个
发表于 2014-10-15 15:36:41 | 显示全部楼层 |阅读模式
Zoom to a Window in Editor using CommandASync                         By Madhukar Moogala
In this post, I will illustrate a sample based on AutoCAD 2015 API Editor.CommandAsync.
Problem: Can I zoom to particular window in an Editor as long as I press esc or cancel to quit?
Answer: Yes, with help of CommandAsync, you can achieve this task.
#region "send Zoom command by callback function"
private static bool ZoomExit = false;
//declare the callback delegation
delegate void Del();
private static Del _actionCompletedDelegate;
// Exit function,check if Zoom command is esc\cancelled
static void
MdiActiveDocument_CommandCancelled(object sender,CommandEventArgs e)
    ZoomExit = true;
[CommandMethod("TestZoom")]
public static void TestZoom()
   var ed = Application.DocumentManager.MdiActiveDocument.Editor;
   var doc = Application.DocumentManager.MdiActiveDocument;
   //esc event
   doc.CommandCancelled += MdiActiveDocument_CommandCancelled;
   // start Zoom command
   Editor.CommandResult cmdResult1 =
   ed.CommandAsync(new object[]{
   "_.ZOOM", Editor.PauseToken, Editor.PauseToken});
   // delegate callback function, wait for interaction ends
   _actionCompletedDelegate = new Del(CreateZoomAsyncCallback);
   cmdResult1.OnCompleted(new Action(_actionCompletedDelegate));
   ZoomExit = false;
// callback function
public static void CreateZoomAsyncCallback()
    //if Zoom command is running
    if (!ZoomExit)
        // AutoCAD hands over to the callback function
    else
        ed.WriteMessage("Zoom Exit");
        return;
GMT+8, 2026-11-3 07:28 , Processed in 0.410932 second(s), 28 queries , Gzip On.
