查看: 2583|回复: 1
[教学] XDGE几何库应用(27)---用圆弧模拟SPLINE
发表于 2014-10-15 20:52:40 | 显示全部楼层 |阅读模式
  1. (defun c:tt ()
  2.   (if (and
  3.         (setq e (car (xdrx_entsel "\n拾取SPLINE<退出>:" '((0 . "SPLINE")))))
  4.         (setq dis (getreal "\n输入玄高距<退出>:"))
  5.         (setq ge (xdge::constructor e))
  6.         (setq ePa (xdrx_curve_getEndParam e))
  7.         (setq pts (xdge::getpropertyvalue ge "getsamplepoints" 0.0 ePa dis))
  8.         (setq pts1 (car pts)
  9.               pas1 (cadr pts)
  10.         )
  11.       )
  12.     (progn
  13.       (xdrx_begin)
  14.       (setq pts (XD::List:SnakePair pts1)
  15.             pas (XD::List:SnakePair pas1)
  16.       )
  17.       (setq i 0
  18.             garcl nil
  19.       )
  20.       (mapcar
  21.         '(lambda (x)
  22.            (setq pmid (xdge::getpropertyvalue ge "evalPoint" (/
  23.        (apply
  24.        '+
  25.        (nth i pas)
  26.        ) 2.0
  27.                                                              )
  28.                       )
  29.                  garc (xdge::constructor "kCircArc2d" (car x) pmid
  30.                                          (cadr x)
  31.                       )
  32.                  garcl (cons garc garcl)
  33.                  i (1+ i)
  34.            )
  35.          )
  36.         pts
  37.       )
  38.       (xdge::entity:make (xdge::constructor "kCompositeCrv2d"
  39.                                             (reverse garcl)
  40.                          )
  41.       )
  42.       (xdrx_entity_setcolor (entlast) 1)
  43. ;;下面代码是测试性能,可以删除
  44.       (setq area1 (xdrx_getpropertyvalue e "area")
  45.             area2 (xdrx_getpropertyvalue (entlast) "area")
  46.       )
  47.       (xdrx_object_regen (entlast))
  48.       (apply 'xdrx_polyline_make pts1)
  49.       (xdrx_entity_setcolor (entlast) 2)
  50.       (princ (strcat "\n原始面积:" (rtos area1 2 3) ".\n圆弧模拟面积:"
  51.                      (rtos area2 2 3) ".误差:" (rtos (* 100 (/
  52.        (abs
  53.        (- area2 area1)
  54.        ) area1
  55.                                                              )
  56.                                                       ) 2 5
  57.                                                 ) "%" "\n折线模拟面积:"
  58.                      (rtos (setq area3 (abs (apply
  59.                                               'xdrx_points_area
  60.                                               pts1
  61.                                             )
  62.                                        )
  63.                            )
  64.                            2 3
  65.                      ) ".误差:" (rtos (* 100 (/ (abs (- area3 area1)) area1))
  66.                                        2 5
  67.                                  ) "%"
  68.              )
  69.       )
  70. ;;;;
  71.       (xdrx_end)
  72.     )
  73.   )
  74.   (princ)
  75. )
玄高距离100的时候的截图
玄高距100时候误差
拾取SPLINE<退出>:
输入玄高距<退出>:100
原始面积:74956697.475.
圆弧模拟面积:74958827.643.误差:0.00284%
折线模拟面积:74019558.882.误差:1.25024%
玄高距50时候误差,就不用截图了,因为红色的圆弧线基本和SPLINE重合了。
拾取SPLINE<退出>:
输入玄高距<退出>:50
原始面积:74956697.475.
圆弧模拟面积:74956363.920.误差:0.00044%
折线模拟面积:74481141.091.误差:0.63444%
本帖被以下淘专辑推荐:
发表于 2014-10-15 21:46:56 | 显示全部楼层
很漂亮啊,能不能考虑改下,把相邻圆弧顶点的一阶导数都连续上,这样就更漂亮了。
GMT+8, 2026-11-26 04:33 , Processed in 0.588426 second(s), 34 queries , Gzip On, File On.
