查看: 2118|回复: 6
[求助] CAD程序为啥乱赋值???
发表于 2014-10-17 10:31:01 | 显示全部楼层 |阅读模式
两个不相干的变量值,分别在两个不同的子程序里
我用一个计算之后,另一个居然会被赋值
神马原因????
  1. (defun c:f1()
  2.   (setvar "cmdecho" 0)
  3.   (f1_dcl)
  4.   (princ)
  5.   )
  6. (defun f1_dcl()
  7.   (setq dcl_id (load_dialog "C:\\Documents and Settings\\huangtuo\\桌面\\图层LISP源文件\\计算.DCL"))
  8.   (new_dialog "f1" dcl_id)
  9.   (action_tile "js_3""(js3)")
  10.   (action_tile "js_1""(js1)")
  11.   (if(not(null r-3)) (set_tile "r_3" (rtos r-3 )))
  12.   (if(not(null kx-3)) (set_tile "kx_3" (rtos kx-3 2 2 )))
  13.   (if(not(null cos-3)) (set_tile "cos_3" (rtos cos-3 2 2)))
  14.   (if(not(null js-r-3)) (set_tile "js_r_3" (rtos js-r-3 2 3)))
  15.   (if(not(null i-3)) (set_tile "i_3" (rtos i-3 2 2)))
  16.   (if(not(null 1.25i-3)) (set_tile "1.25i_3" (rtos 1.25i-3 2 2)))
  17.   (if(not(null r-1)) (set_tile "r_1" (rtos r-1 )))
  18.   (if(not(null kx-1)) (set_tile "kx_1" (rtos kx-1 2 2 )))
  19.   (if(not(null cos-1)) (set_tile "cos_1" (rtos cos-1 2 2)))
  20.   (if(not(null js-r-1)) (set_tile "js_r_1" (rtos js-r-1 2 3)))
  21.   (if(not(null i-1)) (set_tile "i_1" (rtos i-1 2 2)))
  22.   (if(not(null 1.25i-1)) (set_tile "1.25i_1" (rtos 1.25i-1 2 2)))
  23.   (action_tile "accept" "(done_dialog 1)")
  24.   (start_dialog)
  25.   )
  26. (defun js3()
  27.   (setq r-3 (atof (get_tile "r_3")))
  28.   (setq kx-3 (atof (get_tile "kx_3")))
  29.   (setq cos-3 (atof (get_tile "cos_3")))
  30.   (setq js-r-3 (* r-3 kx-3))
  31.   (setq i-3 (/ js-r-3 (* (sqrt 3) cos-3 0.3800)))
  32.   (setq 1.25i-3 (* 1.25 i-3))
  33.   (set_tile "js_r_3" (rtos js-r-3 2 3))
  34.   (set_tile "i_3" (rtos i-3 2 2))
  35.   (set_tile "1.25i_3" (rtos 1.25i-3 2 3))
  36.   )
  37. (defun js1()
  38.   (setq r-1 (atof (get_tile "r_1")))
  39.   (setq kx-1 (atof (get_tile "kx_1")))
  40.   (setq cos-1 (atof (get_tile "cos_1")))
  41.   (setq js-r-1 (* r-1 kx-1))
  42.   (setq i-1 (/ js-r-1 (*  cos-1 0.2200)))
  43.   (setq 1.25i-1 (* 1.25 i-1))
  44.   (set_tile "js_r_1" (rtos js-r-1 2 3))
  45.   (set_tile "i_1" (rtos i-1 2 2))
  46.   (set_tile "1.25i_1" (rtos 1.25i-1 2 3))
  47.   )
上面代码最后一个1.25i_1和1.25i_3这两个值会传值我明明没启动下面的那个js1子程序
但是会被赋值
而且两个变量之间会串值,计算了下面一个1.25i_1会串到上面那个1.25i_3上去
这是神马原因????
附上动态图片演示:
发表于 2014-10-17 10:58:30 | 显示全部楼层
知道什么是全局变量和局部变量吗?
不想受别的影响收集变量作为局部变量
写成全局变量是因为想把对话框内的数据保留下来,因为如果写成局部变量,计算之后值就成nil了 第二次开对话框就没有我上次计算的数据  详情 回复 发表于 2014-10-17 11:11
 楼主| 发表于 2014-10-17 11:11:13 | 显示全部楼层
Free-Lancer 发表于 2014-10-17 10:58
知道什么是全局变量和局部变量吗?
不想受别的影响收集变量作为局部变量
第二次开对话框就没有我上次计算的数据
那另外一个程序就不要用相同的变量名  详情 回复 发表于 2014-10-17 11:22
发表于 2014-10-17 11:22:56 | 显示全部楼层
第二次开 ...
那另外一个程序就不要用相同的变量名
 楼主| 发表于 2014-10-17 11:24:20 | 显示全部楼层
程序本来就没有相同的变量名,所有的变量名称都不一样
不知道为什么还是会串值
发表于 2014-10-24 15:36:58 | 显示全部楼层
这个是程序编写者的问题,不注意任何语言都可能出问题
已领礼包: 12492个
发表于 2014-10-25 08:17:33 | 显示全部楼层
变量名错误。LISP变量命名规则一般要求是字母开头,且不得有下列符号出现:().'";
GMT+8, 2026-11-6 08:13 , Processed in 0.190113 second(s), 45 queries , Gzip On.
