查看: 2293|回复: 0
[分享] 用未公开的函数acedSetDynInputDisplayMessage来实现动态显示
已领礼包: 859个
发表于 2014-10-19 22:13:38 | 显示全部楼层 |阅读模式
原文见:http://forums.autodesk.com/t5/NET/Dynamic-Input/td-p/1339772
目前AutoCAD未公开实现Dynamic Input的API,要实现和AutoCAD同样的效果,可以使用一个未公开的函数acedSetDynInputDisplayMessage
以下是C#代码:
  1. using System;
  2. using System.Text;
  3. using Autodesk.AutoCAD.Runtime;
  4. using Autodesk.AutoCAD.ApplicationServices;
  5. using Autodesk.AutoCAD.EditorInput;
  6. using Autodesk.AutoCAD.DatabaseServices;
  7. using System.Threading;
  8. using System.Globalization;
  9. using System.Runtime.InteropServices;
  10. #endregion
  11. namespace RSNNAcadApp.Test
  12. {
  13. public class Test
  14. {
  15. //this is an undocumented api exported from acad.exe. Use it at your
  16. own risk.
  17. //
  18. // Setting this flag tells AutoCAD to display the last string output
  19. to the command line
  20. //in the Dynamic Input prompt window (one time only.)
  21. [DllImport("acad.exe",
  22. EntryPoint="?acedSetDynInputDisplayMessage@@YA_N_N​@Z")]
  23. private static extern bool acedSetDynInputDisplayMessage(bool
  24. displayMessageOnce);
  25. private double m_dist; //last distance chosen (per-document)
  26. private bool m_firstTime = true; //first invocation of "test"?
  27. (per-document)
  28. //use a non-static command method so the enclosing class (Test) will
  29. be instantiated
  30. //for each document
  31. [CommandMethod("test")]
  32. public void DoIt()
  33. {
  34. Editor ed =
  35. Application.DocumentManager.MdiActiveDocument.Edit​or;
  36. PromptDistanceOptions opt1 = new PromptDistanceOptions("Abstand
  37. zeigen");
  38. opt1.AllowNegative = false;
  39. opt1.AllowZero = false;
  40. opt1.AllowNone = false;
  41. opt1.UseDashedLine = true;
  42. if (!m_firstTime)
  43. opt1.DefaultValue = m_dist;
  44. PromptDoubleResult res = ed.GetDistance(opt1);
  45. if (res.Status == PromptStatus.OK)
  46. {
  47. m_dist = res.Value;
  48. ed.WriteMessage(String.Format("Abstand = {0}",
  49. m_dist.ToString()));
  50. acedSetDynInputDisplayMessage(true);
  51. }
  52. m_firstTime = false;
  53. }
  54. void MyPointFilter(object sender, PointFilterEventArgs e)
  55. {
  56. e.Result.ToolTipText = String.Format("Abstand = {0}",
  57. m_dist.ToString());
  58. }
  59. }
  60. }
GMT+8, 2026-11-3 15:54 , Processed in 0.523406 second(s), 32 queries , Gzip On.
