查看: 1610|回复: 0
[分享] Handoverto with Transaction
已领礼包: 859个
发表于 2014-11-3 11:06:40 | 显示全部楼层 |阅读模式
Handoverto with TransactionBy Xiaodong Liang
If you try to handover the object id of a Transaction resident object with a new object, you will receive an error eInvalidContext. In fact, you cannot call the function handOverTo() on Transaction resident objects. This means that you have to switch to common way to open the object (acdbOpenObject).  This also applies to .NET.
bool test()
     ads_name ename;
     ads_point ptResult;
     ads_matrix adsmat;
     struct resbuf *info;
   // select one entity
     int rt = acedNEntSelP(_T("\nselect an entity:"),
         ename,
         ptResult,
         false ,
         adsmat,
         &info);
     if( rt!= RTNORM)
         acutPrintf(_T("\nFailure in acedNEntSelP"));
        return false;
      AcDbObjectId old__ent_id;
      acdbGetObjectId(old__ent_id,ename);
       AcDbCircle* newCircle =
          new AcDbCircle(
          AcGePoint3d(0,0,0),
          AcGeVector3d(0,0,1),
          10);
      // correct usage
       AcDbObject *pObj;
      Acad::ErrorStatus es1 =
          acdbOpenObject(pObj,old__ent_id,AcDb::kForWrite);
       if (pObj == NULL)
         return false;
      Acad::ErrorStatus es =
          pObj->handOverTo(newCircle);
     if (es ==
         Acad::eObjectToBeDeleted)
         newCircle->close();
        delete pObj;
        return true;
     else
         pObj->close();
       return false;
      // wrong usage: with Transaction
      /* AcTransaction *pTrans =
          actrTransactionManager->startTransaction();
      AcDbObject *pObj;
      pTrans->getObject(pObj,
          old__ent_id,
          AcDb::kForWrite);
      if (pObj == NULL)
         return false;
      // will get eInvalidContext
     if (es ==
        delete pObj;
        actrTransactionManager->endTransaction();
        return true;
     else
       actrTransactionManager->abortTransaction();
       return false;
GMT+8, 2026-11-3 08:29 , Processed in 0.727402 second(s), 28 queries , Gzip On.
