查看: 1858|回复: 1
[求助] cad取点写入excell
已领礼包: 2759个
财富等级: 家财万贯
发表于 2014-11-5 11:51:59 | 显示全部楼层 |阅读模式
cad程序后启动,excell程序启动,程序能够不能运行;excell程序启动,cad程序后启动,程序能够运行,希望高手能够帮助!
;----cad取点写入excell ptcoo_exell
(defun c:ptcoo_exell ( / appsession msxl_books_name xh tx p msxl_sheets  )
(vl-load-com)
  (setq dmode "SHOW" )
  (if (null (setq xh(getint "\n起始点编号:")))
  (setq xh 1);xh代表序号
(setq appsession (vlax-get-or-create-object "Excel.Application"));excell程序
(setq msxl_books (vlax-get-property appsession 'WorkBooks) );工程
;(setq msxl_books_name  (vlax-get-property msxl_books 'name) );工程名称
(setq msxl_sheets  (vlax-get-property appsession 'WorkSheets) );表
(setq msxl_sheets-count  (vlax-get-property msxl_sheets 'count) );表数量
(setq msxl_act_sheets  (vlax-get-property appsession 'ActiveSheet) );当前表
(setq msxl_books-name  (vlax-get-property msxl_act_sheets 'Name) );当前表名字
(setq msxl_act_cell  (vlax-get-property appsession 'ActiveCell) );当前单元格
(setq msxl_act_cell_text  (vlax-get-property msxl_act_cell 'FormulaArray) );数值
(setq msxl_act_cell_type (vlax-variant-type msxl_act_cell_text ) );数据类型
(setq msxl_act_cell_value  (vlax-variant-value msxl_act_cell_text ) );数据值
;(vlax-dump-object msxl_act_cell [T])
(setq msxl_act_cell_text  (vlax-get-property msxl_act_cell 'Value) );数值
(setq msxl_act_cell_col  (vlax-get-property msxl_act_cell 'Column) );数值
(setq msxl_act_cell_row  (vlax-get-property msxl_act_cell 'Row) );数值
    (SETQ P(GETPOINT"\n选择点:"))
    (while (/= p nil)
     (setq tx (strcat  "J" (itoa  xh) "," "" "," (rtos (car p) 2 4) "," (rtos(cadr p) 2 4) "," "0"))
(setq msxl_act_cell_text  (vlax-put-property msxl_act_cell 'Value2 (strcat  "J" (itoa  xh))) );数值
(setq msxl_act_cell_col  (vlax-put-property msxl_act_cell 'Column  (1+msxl_act_cell_col)) );数值
(setq cell_val(vlax-make-variant (rtos (car p) 2 4)  8))
(setq msxl_act_cell_text  (vlax-put-property msxl_act_cell 'Value2 cell_val) );数值
(setq cell_val(vlax-make-variant (rtos (cadr p) 2 4)  8))
(setq msxl_act_cell_col  (vlax-put-property msxl_act_cell 'Column  (- msxl_act_cell_col 2)) );数值
(setq msxl_act_cell_row  (vlax-put-property msxl_act_cell 'Row (1+ msxl_act_cell_row)) );数值
(if (= (strcase dmode) "SHOW")
(vla-put-visible appsession 1)
(vla-put-visible appsession 0)
);---end if
(princ msxl_act_cell_value)
  (setq xh(1+ xh))
  (princ (strcat "\n 共提取" (itoa xh) "个坐标点"))
已领礼包: 1268个
发表于 2014-11-5 16:21:06 | 显示全部楼层
看着有点晕,你要写出什么格式
GMT+8, 2026-11-6 10:02 , Processed in 0.352395 second(s), 31 queries , Gzip On.
