查看: 1995|回复: 1
[教学] API应用 一个简易的文字替换
已领礼包: 593个
发表于 2014-11-8 20:19:07 | 显示全部楼层 |阅读模式
如将选中文字为下列文字中的任意组合替换为一个 string
"KZ3, KZ12, KZ21, KZ22, KZ23, KZ24, KZ25, KZ26, KZ30, KZ34, KZ42, KZ46, KZ47, KZ48, KZ49, KZ50, KZ51, KZ52, KZ53, KZ54, KZ55, KZ56, KZ57, KZ59, KZ62, KZ64, KZ65, KZ66, KZ69, KZ74, KZ78, KZ79, KZ80"
  1. (defun c:tt (/ e str ss lst)
  2.   (if (and (setq e (car (xdrx_entsel "\n选择要替换文字" '((0 . "text")))))
  3.            (setq str (getstring "\nInput New String: "))
  4.            (progn
  5.              (princ "\n选择替换范围....")
  6.              (setq ss (ssget '((0 . "text"))))
  7.            )
  8.       )
  9.     (progn
  10.       (setq lst        (xdrx_string_split
  11.                   (xdrx_getpropertyvalue e "textstring")
  12.                   ","
  13.                 )
  14.       )
  15.       (mapcar '(lambda (x /)
  16.                  (if (vl-some '(lambda (a) (vl-position a lst))
  17.                               (xdrx_string_split
  18.                                 (xdrx_getpropertyvalue x "textstring")
  19.                                 ","
  20.                               )
  21.                      )
  22.                    (xdrx_setpropertyvalue x "textstring" str)
  23.                  )
  24.                )
  25.               (xdrx_pickset->ents ss)
  26.       )
  27.     )
  28.   )
  29.   (princ)
  30. )
发表于 2018-11-28 13:08:12 | 显示全部楼层
比如我需要将某一个文字替换为123那就只需要把代码中的string更换为123就可以了吗
GMT+8, 2026-11-3 09:43 , Processed in 0.498883 second(s), 31 queries , Gzip On.
