查看: 2647|回复: 0
[分享] Exploding nested AutoCAD blocks using .NET
已领礼包: 859个
发表于 2014-11-11 15:18:05 | 显示全部楼层 |阅读模式
Exploding nested AutoCAD blocks using .NET   Some time ago I posted about how to use Entity.Explode() to do something similar to AutoCAD’s EXPLODE command. At the time it was mentioned in the comments that BlockReference.ExplodeToOwnerSpace() had some relative benefits, but it’s taken me some time to code up a simple sample to show how you might use it (Patrick’s recent comment reminded me I ought to, though).
Anyway, to end the week I thought I’d throw together a quick sample. BlockReference.ExplodeToOwnerSpace() doesn’t return a list of created objects, so I opted to capture this using a Database.ObjectAppended event handler and then recursively call our custom ExplodeBlock() function for any nested blocks that get created. We also then erase the originating entity (or entities, if called recursively), just as the EXPLODE command might.
Here’s the C# code:
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Runtime;
  5. namespace Explosions
  6. {
  7.   public class Commands
  8.   {
  9.     [CommandMethod("EB")]
  10.     public void ExplodeBock()
  11.     {
  12.       var doc = Application.DocumentManager.MdiActiveDocument;
  13.       if (doc == null)
  14.         return;
  15.       var ed = doc.Editor;
  16.       var db = doc.Database;
  17.       // Ask the user to select the block
  18.       var peo = new PromptEntityOptions("\nSelect block to explode");
  19.       peo.SetRejectMessage("Must be a block.");
  20.       peo.AddAllowedClass(typeof(BlockReference), false);
  21.       var per = ed.GetEntity(peo);
  22.       if (per.Status != PromptStatus.OK)
  23.         return;
  24.       using (var tr = db.TransactionManager.StartTransaction())
  25.       {
  26.         // Call our explode function recursively, starting
  27.         // with the top-level block reference
  28.         // (you can pass false as a 4th parameter if you
  29.         // don't want originating entities erased)
  30.         ExplodeBlock(tr, db, per.ObjectId);
  31.         tr.Commit();
  32.       }
  33.     }
  34.     private void ExplodeBlock(
  35.       Transaction tr, Database db, ObjectId id, bool erase = true
  36.     )
  37.     {
  38.       // Open out block reference - only needs to be readable
  39.       // for the explode operation, as it's non-destructive
  40.       var br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
  41.       // We'll collect the BlockReferences created in a collection
  42.       var toExplode = new ObjectIdCollection();
  43.       // Define our handler to capture the nested block references
  44.       ObjectEventHandler handler =
  45.         (s, e) =>
  46.         {
  47.           if (e.DBObject is BlockReference)
  48.           {
  49.             toExplode.Add(e.DBObject.ObjectId);
  50.           }
  51.         };
  52.       // Add our handler around the explode call, removing it
  53.       // directly afterwards
  54.       db.ObjectAppended += handler;
  55.       br.ExplodeToOwnerSpace();
  56.       db.ObjectAppended -= handler;
  57.       // Go through the results and recurse, exploding the
  58.       // contents
  59.       foreach (ObjectId bid in toExplode)
  60.       {
  61.         ExplodeBlock(tr, db, bid, erase);
  62.       }
  63.       // We might also just let it drop out of scope
  64.       toExplode.Clear();
  65.       // To replicate the explode command, we're delete the
  66.       // original entity
  67.       if (erase)
  68.       {
  69.         br.UpgradeOpen();
  70.         br.Erase();
  71.         br.DowngradeOpen();
  72.       }
  73.     }
  74.   }
  75. }
GMT+8, 2026-11-3 02:14 , Processed in 0.436495 second(s), 29 queries , Gzip On.
