查看: 2715|回复: 2
[研讨] 关于 TableStyle 中几个设置有没有Vlisp方法
已领礼包: 1268个
发表于 2014-11-13 15:31:02 | 显示全部楼层 |阅读模式
问题1 : 将 自定义的 TableStyle 如何设置为当前,除了 tablestyle 命令有没有 a/vlisp 方法
问题2:这个页边距是控制每个 Cell 内部文字与 GridLine 距离的,翻遍了手册也没有找到方法设置,对 Table 而言,ARX 提供的方法不比 ActiveX  多,ARX有的 ActiveX 都有
下面代码是创建一个 新 TableStyle 样式,但无法解决上面两个问题,请高手们支支招!
  1. ;|
  2. gridLineType  AcGridLineType enum; the type of the grid line
  3. acHorzBottom       Top or bottom horizontal grid line, based on the flow direction.
  4. acHorzInside       All horizontal grid lines, excluding the top and bottom lines.
  5. acHorzTop          Top or bottom horizontal grid line, based on the flow direction.
  6. acInvalidGridLine  An invalid grid line.
  7. acVertInside       All the vertical grid lines, excluding the farthest left and farthest right grid lines.
  8. acVertLeft         Farthest left grid line.
  9. acVertRight        Farthest right grid line.
  10. rowType  AcRowType enum; the row type
  11. acDataRow
  12. acHeaderRow
  13. acTitleRow
  14. acUnknownRow
  15. |;
  16. (defun XD::Table:createTableStyle (name               textHeight  /
  17.                                    dicts       tableStyle  nTableStyle
  18.                                   )
  19.   (setq        dicts            (vla-get-Dictionaries **XD::DOC**)
  20.         tableStyle  (vla-item dicts "acad_tablestyle")
  21.         nTableStyle (vla-addobject tableStyle name "AcDbTableStyle")
  22.   )
  23.   (vla-setalignment nTableStyle acDataRow acMiddleCenter)
  24.   (vla-setalignment nTableStyle acHeaderRow acMiddleCenter)
  25.   (vla-setalignment nTableStyle acTitleRow acMiddleCenter)
  26.   (vla-settextheight nTableStyle acDataRow textHeight)
  27.   (vla-settextheight nTableStyle acHeaderRow textHeight)
  28.   (vla-settextheight nTableStyle acTitleRow textHeight)
  29.   (vla-setGridVisibility
  30.     nTableStyle
  31.     acHorzTop
  32.     acTitleRow
  33.     :vlax-false
  34.   )
  35.   (vla-setGridVisibility
  36.     nTableStyle
  37.     acVertLeft
  38.     acTitleRow
  39.     :vlax-false
  40.   )
  41.   (vla-setGridVisibility
  42.     nTableStyle
  43.     acVertRight
  44.     acTitleRow
  45.     :vlax-false
  46.   )
  47. )
已领礼包: 1268个
 楼主| 发表于 2014-11-13 16:32:01 | 显示全部楼层
第一个问题找到答案了
系统变量 "CTABLESTYLE"
已领礼包: 1268个
 楼主| 发表于 2014-11-13 16:43:09 | 显示全部楼层
第二个问题:
  (vla-put-VertCellMargin nTableStyle 1.5);_垂直边距
  (vla-put-HorzCellMargin nTableStyle 1.5);_水平边距
E 文还需要加强啊!
代码如下
  1. (defun XD::Table:createTableStyle (name               textHeight  /
  2.                                    dicts       tableStyle  nTableStyle
  3.                                   )
  4.   (setq        dicts            (vla-get-Dictionaries **XD::DOC**)
  5.         tableStyle  (vla-item dicts "acad_tablestyle")
  6.         nTableStyle (vla-addobject tableStyle name "AcDbTableStyle")
  7.   )
  8.   (vla-settextheight nTableStyle acDataRow textHeight)
  9.   (vla-settextheight nTableStyle acHeaderRow textHeight)
  10.   (vla-settextheight nTableStyle acTitleRow textHeight)
  11.   (vla-setGridVisibility nTableStyle acHorzTop acTitleRow :vlax-false)
  12.   (vla-setGridVisibility nTableStyle acVertLeft acTitleRow :vlax-false)
  13.   (vla-setGridVisibility nTableStyle acVertRight acTitleRow :vlax-false)
  14.   (vla-put-VertCellMargin nTableStyle 1.5)
  15.   (vla-put-HorzCellMargin nTableStyle 1.5)
  16.   (vla-setalignment nTableStyle acDataRow acMiddleCenter)
  17.   (vla-setalignment nTableStyle acHeaderRow acMiddleCenter)
  18.   (vla-setalignment nTableStyle acTitleRow acMiddleCenter)
  19.   (setvar "ctablestyle" name)
  20.   name
  21. )
GMT+8, 2026-11-3 07:34 , Processed in 0.404755 second(s), 36 queries , Gzip On.
