查看: 2643|回复: 4
[求助] VB.NET下CopyObjects的使用出错
发表于 2014-11-24 20:23:48 | 显示全部楼层 |阅读模式
Private Sub test()
        On Error Resume Next
        Dim blockObj As AcadBlock
        Dim insertionPnt(0 To 2) As Double
        Dim circleObj As AcadCircle
        Dim center(0 To 2) As Double
        insertionPnt(0) = 0.0# : insertionPnt(1) = 0.0# : insertionPnt(2) = 0.0#
        blockObj = acadapp.ActiveDocument.Blocks.Add(insertionPnt, "CircleBlock")   ' 创建块
        center(0) = 0 : center(1) = 0 : center(2) = 0
        circleObj = acadapp.ActiveDocument.ModelSpace.AddCircle(center, 50) ' 在模型空间添加圆
        Dim objCollection(0 To 0) As Object
        objCollection(0) = circleObj                ' 创建对象集合
        Dim retObjects As Object
        retObjects = acadapp.ActiveDocument.CopyObjects(objCollection, blockObj)  ' 拷贝对象到块中,并返回新拷贝的对象
        circleObj.Delete()
        Dim blockRefObj As AcadBlockReference
        insertionPnt(0) = 2.0# : insertionPnt(1) = 2.0# : insertionPnt(2) = 0
        blockRefObj = acadapp.ActiveDocument.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1.0#, 1.0#, 1.0#, 0) ' 插入块到模型空间
    End Sub
retObjects = acadapp.ActiveDocument.CopyObjects(objCollection, blockObj)这一步执行未能成功,返回值是NOTHING,原因是什么???
已领礼包: 1268个
发表于 2014-11-24 20:48:01 来自手机 | 显示全部楼层
是这样用吗?
 楼主| 发表于 2014-11-25 15:41:09 | 显示全部楼层
应该怎么用,请指教
已领礼包: 859个
发表于 2014-11-25 19:04:29 | 显示全部楼层
zzol9970 发表于 2014-11-25 15:41
应该怎么用,请指教
你这是 ActiveX
RetVal = object.CopyObjects(Objects[, Owner][, IDPairs])
.Net 没有这个 method
  1. Sub Example_CopyObjects()
  2.     ' This example creates a Circle object and uses the CopyObjects
  3.     ' method to make a copy of the new Circle.
  4.     Dim DOC1 As AcadDocument
  5.     Dim circleObj1 As AcadCircle, circleObj2 As AcadCircle
  6.     Dim circleObj1Copy As AcadCircle, circleObj2Copy As AcadCircle
  7.     Dim centerPoint(0 To 2) As Double
  8.     Dim radius1 As Double, radius2 As Double
  9.     Dim radius1Copy As Double, radius2Copy As Double
  10.     Dim objCollection(0 To 1) As Object
  11.     Dim retObjects As Variant
  12.
  13.     ' Define the Circle object
  14.     centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
  15.     radius1 = 5#: radius2 = 7#
  16.     radius1Copy = 1#: radius2Copy = 2#
  17.
  18.     ' Create a new drawing
  19.     Set DOC1 = Documents.Add
  20.
  21.     ' Add two circles to the drawing
  22.     Set circleObj1 = DOC1.ModelSpace.AddCircle(centerPoint, radius1)
  23.     Set circleObj2 = DOC1.ModelSpace.AddCircle(centerPoint, radius2)
  24.     ThisDrawing.Application.ZoomAll
  25.
  26.     ' Copy objects
  27.     '
  28.     ' First put the objects to be copied into a form compatible with CopyObjects
  29.     Set objCollection(0) = circleObj1
  30.     Set objCollection(1) = circleObj2
  31.
  32.     ' Copy object and get back a collection of the new objects (copies)
  33.     retObjects = DOC1.CopyObjects(objCollection)
  34.
  35.     ' Get newly created object and apply new properties to the copies
  36.     Set circleObj1Copy = retObjects(0)
  37.     Set circleObj2Copy = retObjects(1)
  38.
  39.     circleObj1Copy.radius = radius1Copy
  40.     circleObj2Copy.radius = radius2Copy
  41.
  42.     ThisDrawing.Application.ZoomAll
  43.
  44.     MsgBox "Circles copied."
  45. End Sub
 楼主| 发表于 2014-11-26 17:45:38 | 显示全部楼层
没有这个method的话运行会报错的啊,可是没看到错误提示
GMT+8, 2026-11-3 06:09 , Processed in 0.478809 second(s), 38 queries , Gzip On.
