查看: 3097|回复: 14
[原创] 求a^N幂方
已领礼包: 1904个
财富等级: 堆金积玉
发表于 2014-11-29 22:15:23 | 显示全部楼层 |阅读模式
;;;求a^N幂方  如(pow 5 10000)将得到6990位的大数
(defun fbin (n)
(setq binlst nil)
(while (> n 0)
    (setq b (rem n 2))
    (setq binlst (cons b binlst))
    (setq n (lsh n -1))
binlst
(defun add (lst1 lst2)
  (setq k1 (length lst1))
  (setq k2 (length lst2))
  (if (> k1 k2)
          (repeat (- k1 k2)  (setq lst2 (cons 0 lst2)) )
          (repeat (- k2 k1)  (setq lst1 (cons 0 lst1)) )
  (setq addlst (mapcar '(lambda (x y) (+ x y)) lst1 lst2 ))
  addlst
(defun lnum (lst n n0)
   (setq lst (mapcar '(lambda (x) (* x n))  lst))
   (setq zlst (reverse lst))
   (repeat n0 (setq zlst (cons 0 zlst) ) )
(reverse zlst)
(defun xc(lst1 lst2)
   (setq n1 (length lst1))
   (setq n2 (length lst2))
   (setq j 1 fflst '(0))
   (if (> n1 n2)
          (while (<= j n2)
              (setq fflst (add (lnum lst1 (nth (- j 1) lst2) (- n2 j) ) fflst))
              (setq j (+ 1 j))
          (while (<= j n1)
              (setq fflst (add (lnum lst2 (nth (- j 1) lst1) (- n1 j) ) fflst))
              (setq j (+ 1 j))
fflst
(defun jinw (blst)
    (while (not (apply 'and (mapcar '(lambda (x) (<= x 9)) blst )))
         (setq hlst (mapcar '(lambda (x) (rem x 10)) blst))
         (setq qlst (mapcar '(lambda (x) (/ x 10)) blst))
         (setq qlst (append qlst (list 0)))
         (setq blst (add hlst qlst))
  blst
(defun sr (a)
   (setq n (strlen a) i 1 lst nil)
   (while (<= i n)
        (setq lst (cons (atoi (substr a i 1)) lst))
        (setq i (+ 1 i))
   (reverse lst)
(defun dc (a b)
  (setq lst1 (sr a))
  (setq lst2 (sr b))
  (setq tenlst (jinw (xc lst1 lst2)))
  (setq str (apply 'strcat (mapcar '(lambda (x) (itoa x)) tenlst ) ) )
  (if (= (car tenlst) 0)
      (setq str (vl-string-left-trim "0" str))
str
(defun pow (x n)
   (setq x (itoa x))
   (if (= (rem n 2) 0) (setq y "1")(setq y x))
   (setq binlst (cdr (reverse (fbin n))))
   (setq xlst (mapcar '(lambda (i) (setq x (dc x x)))  binlst))
   (setq ylst (mapcar '(lambda (i j) (if (= i 1) (setq y (dc y j)))) binlst xlst))
   (last ylst)
(pow 5 10000)
评分
参与人数 2威望 +1 D豆 +15 贡献 +3 收起 理由
Highflybird + 1 + 5 + 3
XDSoft + 10 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2014-11-30 22:05:01 来自手机 | 显示全部楼层
原先没有采用xlst,ylst,而是将其合并,最后直接返回y的方式,代码如下:(mapcar '(lambda (i)  (setq x (dc x x)) (if (= i 1)(setq y (dc y x))))  binlst),但程序运行不正确,返回的y值总是为初始的x字符串,不知什么原因?
已领礼包: 8125个
发表于 2014-12-1 16:28:45 | 显示全部楼层
楼主的帖子 曲高和寡。很佩服楼主用LISP来做高精度和大数计算。毕竟用LISP来做这件事是有点难。
感兴趣而已,就当做表处理函数基础练习题了。其实理解算法就不难了。不知其它语言中大数类怎么高效运算的?或许有更效率的算法。  详情 回复 发表于 2014-12-1 20:04
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2014-12-1 20:04:15 | 显示全部楼层
如果用C++语言的话,用数组方式处理这个问题是比较高效的。 C++里面的快速FFT变换可以用于大数计算。是很方便的。 可惜,AutoLISP中没有数组,用表处理就不那么高效了。  详情 回复 发表于 2014-12-1 22:43
高飞鸟是个爱钻研的孩子,看来楼主也是,楼主的数学功底一定很强吧,希望多在论坛讨论讨论基础理论、算法的东西。  详情 回复 发表于 2014-12-1 20:08
已领礼包: 145个
发表于 2014-12-1 20:08:32 | 显示全部楼层
aimisiyou 发表于 2014-12-1 20:04
感兴趣而已,就当做表处理函数基础练习题了。其实理解算法就不难了。不知其它语言中大数类怎么高效运算的 ...
高飞鸟是个爱钻研的孩子{:soso_e113:},看来楼主也是,楼主的数学功底一定很强吧,希望多在论坛讨论讨论基础理论、算法的东西。
发表于 2014-12-1 20:45:57 | 显示全部楼层
路过。。支持下!
谢谢,说实话我在用lisp解决约瑟夫数圈问题时,关于表处理有个问题一直卡住,后来在你空间得到解答,再次感谢!  详情 回复 发表于 2014-12-1 20:57
发表于 2014-12-1 20:56:36 | 显示全部楼层
看看,学习下!
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2014-12-1 20:57:08 | 显示全部楼层
已领礼包: 7745个
发表于 2014-12-1 20:59:37 | 显示全部楼层
这么高深,真心看不懂了,支持一下
已领礼包: 8125个
发表于 2014-12-1 22:43:50 | 显示全部楼层
FFT需要用到数组,只好作罢。仔细分析,发现lisp效率低是因为不同长度表做加法运算时,短表前补零操作很占时间(尤其是一个表很长,一个表很短),如果能解决这个问题,效率估计有很大提高。  详情 回复 发表于 2014-12-6 18:07
已领礼包: 8125个
发表于 2014-12-1 23:41:54 | 显示全部楼层
[ 本帖最后由 Highflybird 于 2014-12-1 23:47 编辑 ]\n\n如以下代码就是计算 : 2^6972593 &#8722;1 这是一个质数,在2000年的时候,它是被发现的最大的一个质数,当然,现在不再是了。
int m=754974721,N,t[1<<22],a,*p,i,e=4625195,j,s,b,c,U;f(d){for(s
=1<<23;s;s/=2,d=d*1LL*d%m)if(s<N)for(p=t;p<t+N;p+=s)for(i=s,c=1;
i;i--)b=*p+p[s],p[s]=(m+*p-p[s])*1LL*c%m,*p++=b%m,c=c*1LL*d%m;
for(j=0;i<N-1;){for(s=N/2;!((j^=s)&s);s/=2);if(++i<j)a=t[i],t[i]
=t[j],t[j]=a;}}main(){*t=2;U=N=1;while(e/=2){N*=2;U=U*1LL*(m+1)/
2%m;f(362);for(p=t;p<t+N;)*p++=*p*1LL**p%m*U%m;f(415027540);for(
a=0,p=t;p<t+N;)a+=*p<<(e&1),*p++=a%10,a/=10;}while(!*--p);t[0]--
;while(p>=t)printf("%d",*p--);}
代码是如此精炼,但又如此晦涩难懂。编写它的作者在国际Fabrice Bellard凭此获得了2000年的
国际C语言混乱代码大赛(International Obfuscated C Code Contest)大奖。
这段代码就用到了快速傅里叶变换。
已领礼包: 604个
发表于 2014-12-2 13:05:15 | 显示全部楼层
Highflybird 发表于 2014-12-1 23:41
[ 本帖最后由 Highflybird 于 2014-12-1 23:47 编辑 ]\n\n如以下代码就是计算 : 2^6972593 &#8722;1 这是一 ...
当时我也关注到这条消息,当时就奇怪了,一个质素就值得报道
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2014-12-6 18:07:45 | 显示全部楼层
C++里面的快速FFT变换可以用于大数计算。是 ...
可以把你补零的代码贴上来吗,如果用 cons 添加效率不会低的。  详情 回复 发表于 2014-12-6 18:19
发表于 2014-12-6 18:19:27 | 显示全部楼层
aimisiyou 发表于 2014-12-6 18:07
FFT需要用到数组,只好作罢。仔细分析,发现lisp效率低是因为不同长度表做加法运算时,短表前补零操作很 ...
(defun add (lst1 lst2) (setq k1 (length lst1)) (setq k2 (length lst2)) (if (> k1 k2) (repeat (- k1 k2) (setq lst2 (cons 0 lst2)) ) (repeat (- k2 k1) (setq lst1 (cons 0  详情 回复 发表于 2014-12-6 18:24
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2014-12-6 18:24:10 | 显示全部楼层
  (if (> k1 k2)
  addlst
(reverse zlst)
GMT+8, 2026-11-6 09:15 , Processed in 0.594564 second(s), 60 queries , Gzip On.
