查看: 27882|回复: 129
[每日一码] (2)计算AcDbBlockReference准确的包围盒
 火 [复制链接]
发表于 2014-12-5 00:14:16 | 显示全部楼层 |阅读模式
Question
AcDbBlockReference::geomExtents() doesn't return an accurate value for a rotated
AcDbBlockReference. Is there a function that does?
Answer
The following function calculates the extents of an AcDbBlockReference. The
following restrictions apply:
-- Non uniformly scaled blocks containing solids are not supported.
-- Blocks containing AcDb3dPolylines are not supported.
-- Blocks containing AcDb2dPolylines other than of type k2dSimplePoly are not
supported.
Here's the code:
游客,如果您要查看本帖隐藏内容请回复
发表于 2014-12-5 00:21:35 | 显示全部楼层
呵呵,这么快又有好码
发表于 2014-12-5 09:33:25 | 显示全部楼层
为何不用:AcDbBlockReference::geomExtentsBestFit呢?
发表于 2014-12-5 09:37:43 | 显示全部楼层
虽然不懂ARX,回复看看。
发表于 2014-12-5 09:39:24 来自手机 | 显示全部楼层
geomExtents是与轴平行的,这个BestFit是什么情况?
发表于 2014-12-5 09:52:12 来自手机 | 显示全部楼层
很吃力的看了看代码,除了加入属性,polyline没必要explode,对insert也是直接geomExtents
发表于 2014-12-5 10:07:09 | 显示全部楼层
When working in non-WCS coordinate systems, the extents returned from AcDbBlockReference::geomExtents() can be somewhat larger that the actual geometry because AcDbBlockReference::geomExtents() transforms the contained entities' precomputed extents by the block reference's transformation matrix rather than transforming the entities and computing a new box for the transformed entity set. This results in non-world aligned extent boxes for the entities. This is fast, but will provide an "exaggerated" enclosing extents box.
This method works recursively for nested block references. When this method is called on the outermost block reference (the normal case for ARX applications), parentXform should be the identity matrix. For calls on nested block references, parentXform should be the cumulative transformation from the outermost block reference down to the block reference that is referencing the block table record that owns the block reference on which this method is being called.
发表于 2014-12-5 10:39:37 来自手机 | 显示全部楼层
Highflybird 发表于 2014-12-5 10:07
When working in non-WCS coordinate systems, the extents returned from AcDbBlockReference::geomExtent ...
意思就是BlockReference 自个儿 的平行轴(WCS)geomExtents吧
等下我测试一下。  详情 回复 发表于 2014-12-5 11:40
发表于 2014-12-5 11:20:54 | 显示全部楼层
虽然不懂ARX,回复看看
发表于 2014-12-5 11:23:55 | 显示全部楼层
全英文全英文全英文全英文
发表于 2014-12-5 11:40:25 | 显示全部楼层
等下我测试一下。
发表于 2014-12-5 13:19:55 | 显示全部楼层
这个包围盒的生成限制有点多!
发表于 2014-12-5 14:02:13 | 显示全部楼层
好好学习---
发表于 2014-12-5 15:54:57 | 显示全部楼层
测试了一下,geomExtents的确存在问题,得不到真实的box.
单独用这两函数都有问题,可以自己利用这两个函数单独写自己的BOX函数,对一些特殊实体特殊处理。  详情 回复 发表于 2014-12-5 19:55
AcDbBlockReference::geomExtentsBestFit Function Acad::ErrorStatusgeomExtentsBestFit(AcDbExtents& extents,const AcGeMatrix3d& parentXform = AcGeMatrix3d::kIdentity) const;When working in non-WCS coor  详情 回复 发表于 2014-12-5 17:13
发表于 2014-12-5 16:15:39 来自手机 | 显示全部楼层
哪些实体有影响?
不是实体问题。  详情 回复 发表于 2014-12-5 16:33
GMT+8, 2026-11-22 08:40 , Processed in 0.394925 second(s), 41 queries , Gzip On, File On.
