楼主: lucas3
[已解决] 判断线型的问题
发表于 2015-1-9 19:30:50 | 显示全部楼层
lucas3 发表于 2015-1-9 18:20
大师,重新使用28楼的程序,并将29楼处的替换掉,问题还存在,还是参数太少, 点取消还是要选择对象
  1. (defun c:tt (/ ss dcl fn id klst)
  2.   (defun _make
  3.          (e / r pcen dis lst str xk mr cel p1 p2 p3 p4 cir ln1 ln2)
  4.     (setq lst '((2.5 "M3" 0.06 1.5)
  5.                 (3.3 "M4" 0.08 1.5)
  6.                 (4.2 "M5" 0.1 2.5)
  7.                 (5.0 "M6" 0.12 3.0)
  8.                 (6.8 "M8" 0.16 4.0)
  9.                 (8.5 "M10" 0.2 5.0)
  10.                 (10.5 "M12" 0.24 6.0)
  11.                 (12.0 "M14" 0.28 7.0)
  12.                 (14.0 "M16" 0.32 8.0)
  13.                 (15.5 "M18" 0.36 9.0)
  14.                 (17.5 "M20" 0.4 10.0)
  15.                )
  16.     )
  17.     (setq r    (vlax-get e 'radius)
  18.           pcen (vlax-get e 'center)
  19.     )
  20.     (mapcar 'set '(str xk mr) (cdr (assoc r lst)))
  21.     (setq cel (if (eq (setq lt (vlax-get e "linetype"))
  22.                       "ByLayer"
  23.                   )
  24.                 (vlax-get
  25.                   (vla-item (fy:aclayers) (vlax-get e "layer"))
  26.                   "linetype"
  27.                 )
  28.                 lt
  29.               )
  30.     )
  31.     (setq dis (* r 1.1)
  32.           p1  (polar pcen 0. dis)
  33.           p2  (polar pcen _pi2 dis)
  34.           p3  (polar pcen pi dis)
  35.           p4  (polar pcen (- _pi2) dis)
  36.     )
  37.     (if        (member "isBlock" slst)
  38.       (setq space (vla-add (fy:acblocks) (vlax-3d-point pcen) "*U"))
  39.       (setq space (fy:acms))
  40.     )
  41.     (setq cir (vlax-invoke space 'addcircle pcen r)
  42.           arc (vlax-invoke space 'addarc pcen mr 4.71239 3.14159)
  43.           ln1 (vlax-invoke space 'addline p1 p3)
  44.           ln2 (vlax-invoke space 'addline p2 p4)
  45.     )
  46.     (mapcar '(lambda (x)
  47.                (vlax-put (car x) 'layer "screw")
  48.                (vlax-put (car x) 'color (cadr x))
  49.                (vlax-put (car x) "linetype" (caddr x))
  50.                (vlax-put (car x) "linetypescale" xk)
  51.              )
  52.             (list (list cir 33 cel)
  53.                   (list arc 3 cel)
  54.                   (list ln1 1 "center")
  55.                   (list ln2 1 "center")
  56.             )
  57.     )
  58.     (if        (member "isText" slst)
  59.       (progn
  60.         (setq txt (vlax-invoke space 'AddText str pcen (* mr 0.4)))
  61.         (vla-put-alignment txt acAlignmentTopCenter)
  62.         (vla-put-textalignmentpoint
  63.           txt
  64.           (vlax-3d-point (polar pcen (- _pi2) (* mr 0.17)))
  65.         )
  66.       )
  67.     )
  68.     (if        (member "isBlock" slst)
  69.       (vlax-invoke
  70.         (fy:acspace)
  71.         'insertblock
  72.         pcen
  73.         (vla-get-name space)
  74.         1.
  75.         1.
  76.         1.
  77.         0.
  78.       )
  79.     )
  80.   )
  81.   (if (not slst)
  82.     (setq slst '("isErased" "isText" "isBlock"))
  83.   )
  84.   (setq        dcl  '("screw:dialog{"
  85.                "label = \"参数设置\";"
  86.                " :toggle{ key = \"isErased\"; label = \"删除原线条\";}"
  87.                " :toggle { key = \"isText\"; label = \"显示文字\";}"
  88.                " :toggle { key = \"isBlock\"; label = \"生成块\";}"
  89.                " ok_cancel;"
  90.                "}"
  91.               )
  92.         klst '("isErased" "isText" "isBlock")
  93.         fn   (xd::dcl:make dcl)
  94.         id   (xd::dcl:load fn "screw")
  95.   )
  96.   (xd::Dcl:toggleaction
  97.     klst ;_key 列表
  98.     'slst ;_记录 勾选项 的变量,做全局变量时下次有默认值
  99.     nil
  100.   ) ;_设置 Toggle  并定义 Action
  101.   (fy:begin)
  102.   (if (and (= (xd::dcl:start id fn)
  103.               1
  104.            )
  105.            (setq ss (ssget '((0 . "circle")
  106.                              (-4 . "<or")
  107.                              (40 . 2.5)
  108.                              (40 . 3.3)
  109.                              (40 . 4.2)
  110.                              (40 . 5.0)
  111.                              (40 . 6.8)
  112.                              (40 . 8.5)
  113.                              (40 . 10.5)
  114.                              (40 . 12.0)
  115.                              (40 . 14.0)
  116.                              (40 . 15.5)
  117.                              (40 . 17.5)
  118.                              (-4 . "or>")
  119.                             )
  120.                     )
  121.            )
  122.       )
  123.     (progn
  124.       (if (not (tblsearch "style" "txt"))
  125.         (command ".style"    "txt"         "txt.shx,gbcbig.shx"
  126.                  0.0             1.0         0.0             "n"
  127.                  "n"             "n"
  128.                 )
  129.       )
  130.       (if (not (tblsearch "ltype" "hidden"))
  131.         (vla-load (fy:acltypes) "hidden" "acadiso.lin")
  132.       )
  133.       (if (not (tblsearch "ltype" "center"))
  134.         (vla-load (fy:acltypes) "center" "acadiso.lin")
  135.       )
  136.       (if (not (tblsearch "layer" "screw"))
  137.         (vla-add (fy:aclayers) "screw")
  138.       )
  139.       (mapcar '(lambda (x) (_make x)) (fy:cset->objs))
  140.       (if (member "isErased" slst)
  141.         (command ".erase" ss "")
  142.       )
  143.     )
  144.   )
  145.   (princ)
  146. )
  147. ;|
  148. 设置 toggle 控件
  149. _$klst ---- 控件名或控件名列表
  150. _$symL ---- 值为控件名或控件名列表的变量名
  151.             含有该控件的为勾选,否则不选
  152. |;
  153. (defun XD::DCL:ToggleInit (_$klst _$symL)
  154.   (if (listp _$klst)
  155.     (mapcar '(lambda (x)
  156.                (if (and _$symL (member x (vl-symbol-value _$symL)))
  157.                  (set_tile x "1")
  158.                  (set_tile x "0")
  159.                )
  160.              )
  161.             _$klst
  162.     )
  163.     (set_tile _$klst
  164.               (if (and _$syml (vl-symbol-value _$symL))
  165.                 "1"
  166.                 "0"
  167.               )
  168.     )
  169.   )
  170. )
  171. (defun XD::DCL:ToggleAction
  172.        (_$klst _$symL _$callbackL / _sToggleAction)
  173.   (defun _sToggleAction        (_$key _$symL _$callbackL)
  174.     (action_tile
  175.       _$key
  176.       (strcat "(if (= $value \"0\")"
  177.               "(setq "
  178.               (vl-symbol-name _$symL)
  179.               "(vl-remove $key "
  180.               (vl-symbol-name _$symL)
  181.               "))(if (not (member $key "
  182.               (vl-symbol-name _$symL)
  183.               "))(setq "
  184.               (vl-symbol-name _$symL)
  185.               "(cons $key "
  186.               (vl-symbol-name _$symL)
  187.               "))))"
  188.               (if _$callbackL
  189.                 (strcat "(" _$callbackL ")")
  190.                 ""
  191.               )
  192.       )
  193.     )
  194.   )
  195.   (XD::DCL:ToggleInit _$klst _$symL)
  196.   (if (listp _$klst)
  197.     (while _$klst
  198.       (_sToggleAction (car _$klst) _$symL (car _$callbackL))
  199.       (setq _$klst        (cdr _$klst)
  200.             _$callbackL        (cdr _$callbackL)
  201.       )
  202.     )
  203.     (_sToggleAction _$klst _$symL _$callbackL)
  204.   )
  205. )
  206. ;;将DCL表写出文件
  207. (defun XD::DCL:Make (lst / flname ofile)
  208.   (setq        FlName (vl-filename-mktemp (strcat "FYDCL" ".dcl"))
  209.         oFile  (open FlName "w")
  210.   )
  211.   (foreach fStream lst (write-line fStream oFile)) ;写入文件
  212.   (close oFile) ;_关闭文档
  213.   flname
  214. )
  215. ;;加载 DCL 文件
  216. (defun XD::DCL:Load (flname na / dcl_id)
  217.   (setq dcl_id (load_dialog FlName))
  218.   (if (not (new_dialog na dcl_id ""))
  219.     (progn (alert "对话框加载失败!") (exit))
  220.   )
  221.   dcl_id
  222. )
  223. ;;用于不返回的 DCL
  224. (defun XD::Dcl:Start (id flname / dg)
  225.   (setq dg (start_dialog))
  226.   (unload_dialog id) ;_卸载对话框
  227.   (vl-file-delete FlName) ;_删除DCL文件
  228.   dg
  229. )
大师,刚才说的问题解决了,但是数据方面有问题,只能选中直径为5的圆,其它的圆如,2.5,3.3,4.2, 6.8 ,8.5 ,10.5 ,12,14, 15.5, 17.5 这些圆都选不上, 另外, 5的圆,程序将小径画成直径为3的弧了,标文字  详情 回复 发表于 2015-1-9 20:21
评分
参与人数 1D豆 +5 收起 理由
lucas3 + 5 技术引导讨论和指点奖!
查看全部评分
已领礼包: 3199个
 楼主| 发表于 2015-1-9 20:21:27 | 显示全部楼层
大师,刚才说的问题解决了,谢谢!
已领礼包: 14个
发表于 2016-5-24 17:37:38 | 显示全部楼层
要学的东西太多了  发蒙
GMT+8, 2026-11-2 22:14 , Processed in 0.438516 second(s), 31 queries , Gzip On.
