查看: 2643|回复: 6
[每日一码] 函数 UcsBoundingBox
已领礼包: 3199个
发表于 2014-12-12 18:20:54 | 显示全部楼层 |阅读模式
by gile
  1. ;; gc:TMatrixFromTo
  2. ;; Returns the 4X4 transformation matrix from a coordinate system to an other one
  3. ;;
  4. ;; Arguments
  5. ;; from to: same arguments as for the 'trans' function
  6. (defun gc:TMatrixFromTo (from to)
  7.   (append
  8.     (mapcar
  9.       (function
  10.   (lambda  (v o)
  11.     (append (trans v from to T) (list o))
  12.   )
  13.       )
  14.       (list '(1. 0. 0.) '(0. 1. 0.) '(0. 0. 1.))
  15.       (trans '(0. 0. 0.) to from)
  16.     )
  17.     (list '(0. 0. 0. 1.))
  18.   )
  19. )
  20. ;; gc:UcsBoundingBox
  21. ;; Returns the UCS coordinates of the object bounding box about current UCS
  22. ;;
  23. ;; Arguments
  24. ;; obj: an entity (ENAME or VLA-OBJCET)
  25. ;; _OutputMinPtSym: a quoted symbol (output)
  26. ;; _OutputMaxPtSym: a quoted symbol (output)
  27. (defun gc:UcsBoundingBox (obj _OutputMinPtSym _OutputMaxPtSym)
  28.   (vl-load-com)
  29.   (and (= (type obj) 'ENAME)
  30.        (setq obj (vlax-ename->vla-object obj))
  31.   )
  32.   (vla-TransformBy obj (vlax-tmatrix (gc:TMatrixFromTo 1 0)))
  33.   (vla-GetBoundingBox obj _OutputMinPtSym _OutputMaxPtSym)
  34.   (vla-TransformBy obj (vlax-tmatrix (gc:TMatrixFromTo 0 1)))
  35.   (set _OutputMinPtSym (vlax-safearray->list (eval _OutputMinPtSym)))
  36.   (set _OutputMaxPtSym (vlax-safearray->list (eval _OutputMaxPtSym)))
  37. )
  38. ;; gc:SelSetUcsBBox
  39. ;; Returns the UCS coordinates of the object bounding box about current UCS
  40. ;;
  41. ;; Arguments
  42. ;; ss: a selection set
  43. ;; _OutputMinPtSym: a quoted symbol (output)
  44. ;; _OutputMaxPtSym: a quoted symbol (output)
  45. (defun gc:SelSetUcsBBox  (ss _OutputMinPtSym _OutputMaxPtSym / n l1 l2)
  46.   (repeat (setq n (sslength ss))
  47.     (gc:UcsBoundingBox (ssname ss (setq n (1- n))) _OutputMinPtSym _OutputMaxPtSym)
  48.     (setq l1 (cons (eval _OutputMinPtSym) l1)
  49.     l2 (cons (eval _OutputMaxPtSym) l2)
  50.     )
  51.   )
  52.   (set _OutputMinPtSym (apply 'mapcar (cons 'min l1)))
  53.   (set _OutputMaxPtSym (apply 'mapcar (cons 'max l2)))
  54. )
for test
  1. (defun c:test (/ ss minpt maxpt)
  2.   (if (setq ss (ssget))
  3.     (progn
  4.       (gc:SelSetUcsBBox ss 'minpt 'maxpt)
  5.       (vl-cmdf
  6.   (if (equal (caddr minpt) (caddr maxpt) 1e-6)
  7.     "_.rectangle"
  8.     "_.box"
  9.   )
  10.   "_non"
  11.   minpt
  12.   "_non"
  13.   maxpt
  14.       )
  15.     )
  16.   )
  17.   (princ)
  18. )
Another one.
  1. ;;;Function: Get BuondingBox
  2. ;;;arg :
  3. ;;;      ss -- Select set or a Ename
  4. ;;;   onseg -- T or NIL , if T then returns the box in UCS , if NIL in WCS
  5. ;;;Support in UCS
  6. ;;;Written by Highflybird
  7. ;;;Edited by GSLS(SS), 2011-02-16
  8. (defun ss-get-boundingbox (ss    onseg   /  Wmat   Umat   i
  9.          ent    obj   minPt  maxPt  minLs  maxLs
  10.          maxX    maxY   minX  minY pts
  11.         )
  12.   (if ss
  13.     (progn
  14.       (if (eq (type ss) 'ENAME)
  15.   (setq ss (ssadd ss (ssadd)))
  16.       )
  17.       (if (and onseg (= (getvar "WORLDUCS") 0))
  18.   (setq Wmat (gc:TMatrixFromTo 1 0)
  19.         Umat (gc:TMatrixFromTo 0 1)
  20.   );_Use gile's nice function
  21.       )
  22.       (setq i 0)
  23.       (setq minPt (vlax-make-safearray vlax-vbdouble '(0 . 2)))
  24.       (setq maxPt (vlax-make-safearray vlax-vbdouble '(0 . 2)))
  25.       (repeat (sslength ss)
  26.   (setq ent (ssname ss i)
  27.         obj (vlax-ename->vla-object ent)
  28.   )
  29.   (if Wmat
  30.     (vla-TransformBy obj (vlax-tmatrix Wmat))
  31.   )
  32.   (vla-GetBoundingBox obj 'minpt 'maxpt)
  33.   (setq minPt (vlax-safearray->list minPt)
  34.         maxPt (vlax-safearray->list maxPt)
  35.         minLs (cons minPt minLs)
  36.         maxLs (cons maxPt maxLs)
  37.   )
  38.   (if Umat
  39.     (vla-TransformBy obj (vlax-tmatrix Umat))
  40.   )
  41.   (setq i (1+ i))
  42.       )
  43. ;_Is there better way to get the other coner points , if it's in 3D UCS ?
  44. ;_Perhaps it'n use 'trans' function ...
  45.       (setq minX (apply 'min (mapcar 'car minLs)))
  46.       (setq minY (apply 'min (mapcar 'cadr minLs)))
  47.       (setq maxX (apply 'max (mapcar 'car maxLs)))
  48.       (setq maxY (apply 'max (mapcar 'cadr maxLs)))
  49.       (setq pts  (list (list minX minY 0)
  50.           (list maxX minY 0)
  51.           (list maxX maxY 0)
  52.           (list minX maxY 0)
  53.     )
  54.       )
  55.       (if Wmat
  56.   (mapcar  (function (lambda (x)
  57.           (trans x 1 0)
  58.         )
  59.     )
  60.     pts
  61.   )
  62.   pts
  63.       )
  64.     )
  65.   )
  66. )
  67. (defun c:test (/
  68.        ss
  69.       )
  70.   ;(svos)
  71.   (if (setq ss (ssget))
  72.     (draw-pl (list (ss-get-boundingbox ss NIL)));_test in UCS return the wcs box
  73.   )
  74.   ;(clos)
  75.   (princ)
  76. )
  77. (defun draw-pl (lst)
  78.   (entmake
  79.     (append
  80.       '((0 . "LWPOLYLINE")
  81.   (100 . "AcDbEntity")
  82.   (100 . "AcDbPolyline")
  83.        )
  84.       (list (cons 90 (length (car lst))))
  85.       (mapcar (function (lambda (x) (cons 10 x))) (car lst))
  86.       (list (cons 70 1))
  87.       (cdr lst)
  88.     )
  89.   )
  90. )
评分
参与人数 1D豆 +10 收起 理由
XDSoft + 10 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2014-12-12 18:35:03 | 显示全部楼层
做什么用的,能给介绍介绍吗?
GILE是谁?
回版主大人,这个不用介绍了吧,你应该一看就懂的,哈哈, Gile 是theswamp 上的一位牛人,分享过很多函数,赞!  详情 回复 发表于 2014-12-12 18:42
已领礼包: 3199个
 楼主| 发表于 2014-12-12 18:42:11 | 显示全部楼层
newer 发表于 2014-12-12 18:35
做什么用的,能给介绍介绍吗?
GILE是谁?
我知道不代表别人也知道啊,所以分享函数最好是说下做什么的,如果有图就更好了。  详情 回复 发表于 2014-12-12 18:44
发表于 2014-12-12 18:44:11 | 显示全部楼层
Gile 是theswamp 上的一位牛人,分享过很多函 ...
上面有英文注释的 ,懂lisp的应该都明白的,你都知道我是一个门外汉,你要我解释,我只能抓狂了  详情 回复 发表于 2014-12-12 18:50
已领礼包: 3199个
 楼主| 发表于 2014-12-12 18:50:36 | 显示全部楼层
上面有英文注释的 ,懂lisp的应该都明白的,你都知道我是一个门外汉,你要我解释,我只能抓狂了{:soso_e118:}
已领礼包: 4044个
发表于 2014-12-12 19:39:51 | 显示全部楼层
当ss中有样条曲线时,结果似乎不正确。
已领礼包: 1094个
发表于 2021-7-30 00:26:03 | 显示全部楼层
感谢楼主分享函数 UcsBoundingBox
GMT+8, 2026-11-3 03:08 , Processed in 0.539069 second(s), 42 queries , Gzip On.
